Old 10-28-2010, 07:12 PM   #1
X Baldwin Motion
X Baldwin Motion's Avatar
Dual Tanks ? 84 Silverado
greetings, I recently acquired an 84 Silverado long bed with the dual tanks, what are the capacities of these tanks?
The rocker switch to change from left to right tank makes a clicking sound from right to left but not the other way. The gauge also goes berserk on the right tank. I am not really sure if the switch is functioning properly. Is there a schematic available that shows me gas tanks, plumbing and switching ? Is this switch prone to problems ?
Thanks in advance for the help.
Chris
X Baldwin Motion is offline   Reply With Quote
Old 10-28-2010, 08:53 PM   #2
Number21
Number21's Avatar
Re: Dual Tanks ? 84 Silverado
Don't know about your electrical issue but they should be 20 gallon tanks. Short beds got 16 gallon and I think some long beds did too? If they're really long under the truck, with no space on either end, then they're 20 gallon.
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 10-28-2010, 08:59 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
LWB trucks can have either 16 or 20 gallon tanks. Mine has 16's sadly, and it is obvious when you look underneath that you have a good sized gap between the tank and rear wheel well.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 10-28-2010, 09:05 PM   #4
palposity
palposity's Avatar
I would check the ground on the right tank if the guage is only acting up for that one. Once you verify that you have a good ground, then inspect your switch.
The ground should go from the sending unit on top of the tank to the frame next to the tank.
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE
DD--2007 Duramax DRW CCLB LT3
palposity is offline   Reply With Quote
Old 10-28-2010, 09:43 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
im going to second Palpositys comments here hes on the money
Bob
1979 Chevrolet C20 LWB
1980 Chevrolet C10 SWB
1998 Chevrolet K2500 LWB
1971 Chevrolet Monte Carlo
1966 Ford Mustang
2018 Subaru Forrester (wifes ride)
2014 Ram Bighorn SLT 4X4 Longbed Diesel
1992 Ford Superduty flatbed tow truck
2004 Dodge reg cab swb 2wd
2014 Harley Davidson Heritage Softtail
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-28-2010, 09:50 PM   #6
tucsonjwt
Not sure about that clicking sound - my 83 dual tank makes a slight buzzing motor type sound when switched from left to right. Could you define what "going beserk" means, exactly? Does the other tank function properly? If so, then I would suspect the sending unit in the bad behaving tank. Are you actually able to suck gas out of both tanks and run the truck when you select left or right? If so, then the selector switch and valve under the cab are working. If you search here and elsewhere on the net you can get a lot of tips on diagnosing gas gauge problems.
If you need a selector switch - less than $20.
If you need a sending unit - $40-$160, depending on aftermarket (Spectra) or OEM (AC/Delco). Aftermarkets will cause the gas gauge needle to bounce when you drive the truck.
tucsonjwt is offline   Reply With Quote
Old 10-29-2010, 06:41 PM   #7
X Baldwin Motion
The "going beserk" (needle flipping from way past full back to empty) seems like behavior from a short or bad ground, I'll check that first this weekend.
The clicking or buzzing sound upon switching the tanks only happens in one direction, not both. I am not sure if it is actually switching because even though I have filled the right side tank,(been running on the left since I got the truck last week) I have not been in a position to chance running out of gas. I'll check the ground then then try to run on the right side. Thanks for the help.
2004 Silverollover
1985 Custom Deluxe long bed 305 3 on tree
1997 w/t 1500 V6 auto 4wd
1984 Silverado THE BEAST
2015 Silverado "Great White"1987 K20 dump and plow
1968 K20 327 long bed 4spd big blue 68K20 SuburPan 4spd "the squirrel"
Old 10-29-2010, 07:22 PM   #8
palposity
palposity's Avatar
Let us know how it works out for you. And welcome to the forum!
Old 10-29-2010, 10:58 PM   #9
MikeJones16
MikeJones16's Avatar
I have a simular electrical issue..
My speedo, gas gauge, and all the other little gauges do the same thing when i turn the driving lights on
MikeJones16 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
