Old 11-08-2010, 01:49 PM   #1
Rich916
Rich916's Avatar
NorCal Cruiser
Ok, so im starting a build thread.
First let me introduce myself. My name is Rich and I live in Rancho Cordova, (near Sacramento) CA. I have been lurking around this forum for a wile and trying to determine what direction I want to take my truck., I can’t believe the amount of information on here.
I came upon this truck on Craigslist. It’s a California “black plate” 71 short/step with a L6 250c.i. and three speed manual column shift. This project will be a D/D typ build and I will be keeping the L6 motor. Plans are to install a static 4/6 drop, c-notch the frame, repair rust, rebuild motor and clean up the Saginaw.
projected 10 month build time.
Im looking forward to getting to know everybody and relying on your knowledge! I will be asking a lot of questions.
Stay tuned...I will update as much as I can.
Rich916 is offline   Reply With Quote
Old 11-08-2010, 01:54 PM   #2
sandnuriz
sandnuriz's Avatar
Re: NorCal Cruiser
Welcome to the site From Bakersfield,Ca.
Great start
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 11-08-2010, 02:00 PM   #3
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Getting Started...
Old 11-08-2010, 02:07 PM   #4
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Moving along...
Old 11-08-2010, 02:13 PM   #5
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Looking for rust!
This will be my first time doing rust repair/Rocker replacement.
Old 11-08-2010, 02:16 PM   #6
Pop's C-10
Pop's C-10's Avatar
Re: NorCal Cruiser
looks clean..
Pop's C-10 is offline   Reply With Quote
Old 11-08-2010, 02:17 PM   #7
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Originally Posted by Pop's C-10 View Post
looks clean..
Not to bad
Old 11-08-2010, 02:19 PM   #8
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Cant get more basic then this!!
Old 11-08-2010, 02:26 PM   #9
C low
C low's Avatar
Re: NorCal Cruiser
wow man all that in one day!! looks good. that is a base model fo sure. yeah i had a ten month plan over a year ago..
C low is offline   Reply With Quote
Old 11-08-2010, 07:29 PM   #10
steppside69
steppside69's Avatar
Re: NorCal Cruiser
Moving fast!!!!
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 11-15-2010, 10:27 PM   #11
SactoJim
SactoJim's Avatar
Re: NorCal Cruiser
Welcome from another Rancho Cordova guy.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 11-15-2010, 10:49 PM   #12
67chevylongbed
67chevylongbed's Avatar
Re: NorCal Cruiser
Nice progress. Welcome from another Sacramento guy (I'm in Carmichael)
Eric
1967 C10 LWB SOLD....
1995 Ford F-250 4x4 Powerstroke, 342k
"Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known."
-Ronald Reagan
67chevylongbed is offline   Reply With Quote
Old 11-16-2010, 02:18 AM   #13
gearys 5600
gearys 5600's Avatar
Re: NorCal Cruiser
Nice start..
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 11-16-2010, 01:18 PM   #14
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Hey thanks Jim & 67chevy. Nice to see some locals.
BTW, Amazing truck you got there SactoJim.
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Old 11-16-2010, 01:34 PM   #15
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Had a little time this past week to get the cab up on a dolly.
Made the dolly out of some scrap 2x4's. Attached some casters and lagged screwed through the cab mount holes.
The cab wasnít as heavy as I expected. My self, my 17yr. Old son and a couple of the neighbor kids managed it.
Old 11-16-2010, 01:47 PM   #16
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Iím getting ready to tackle my rust. So far looks like Rocker, possible inner rocker, some floor patch and small amount on the firewall.
I wire wheeled my drip seals...Looks ok.
Altogether happy with the lack of rust.
Old 11-23-2010, 11:18 AM   #17
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Ok, so now im venturing into some rust repair. Cutting out the rust and making a patch was not to much of a problem.
Old 11-23-2010, 11:20 AM   #18
DBear
DBear's Avatar
Re: NorCal Cruiser
nice job bud....I like the basic stuff.
DBear is offline   Reply With Quote
Old 11-23-2010, 11:31 AM   #19
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Now this is embarrassing!
I havenít welded in a long time and my only experience with welding is arc.
I really debated posting this but I decided to post up the good with the bad.
I ended up pulling out the patch and starting over.
I need some advice...I noticed on other post that most patch work is a multitude of spot welds as opposed to welding a continuance bead.
What is the problem? Am I to close? To hot? Just need more practice?
Old 11-23-2010, 01:44 PM   #20
1956cameo
1956cameo's Avatar
Re: NorCal Cruiser
To me it looks like you may still have weak metal on the cowl. Even though you cut out the rust holes there still could be thin/pitted metal behind what you see. If that is true it will cause the welder to burn thru very easily. You may need to cut the cowl out wider to get to solid metal. You could also have your welder turned up too high. I don't know a whole lot about welding so I am sure someone else will be able to help you much more than me.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 11-23-2010, 01:58 PM   #21
superflysteiny
superflysteiny's Avatar
Re: NorCal Cruiser
Welcome to the board I am in orangevale.
superflysteiny is offline   Reply With Quote
Old 11-23-2010, 02:08 PM   #22
Bruce88
Bruce88's Avatar
Re: NorCal Cruiser
You didnít say what type of welder youíre using? MIG with gas or shield core wire, what size wire. Most welders have a chart to set up the welder for different size metal that youíre welding, this just gets you in the ball park and may need minor adjustments in wire speed or power. If I remember right that area is 18 gauge metal.
One thing that Iíve found a great help is backing up the seam with a copper backing plate. You can find some at Eastwood (hand held or magnetic) or go to the hardware store and pick up some copper tubing flatten it in a vice and have someone hold it in place when welding (make sure to wear gloves when holding it, it gets hot) You might find some additional tips on my build thread (post # 76 and more thru out the build) http://67-72chevytrucks.com/vboard/s...=318544&page=4
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 11-23-2010, 02:56 PM   #23
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Thank you Bruce and 1956cameo,
The welder is a Harbor freight purchase with shield core wire. I new when purchasing it wasnít going to be the ideal set-up but im hoping it will get the job done. Looks like I need to read up on all the settings. Bruce, I will try the copper backing. Great idea! Thanks for the advice guys, ill let you know how the rest of the repairs turn out.
Old 11-23-2010, 02:58 PM   #24
Rich916
Rich916's Avatar
Re: NorCal Cruiser
Im following/followed your build threads. Amazing work bro!
Old 11-23-2010, 03:21 PM   #25
DBear
DBear's Avatar
Re: NorCal Cruiser
should not have a problem with an inexpensive mig welder....use .024 wire and just spot weld it all the way around the seam.....JUST ALTERNATE EACH SPOT WELD TO THE OTHER SIDE....THIS WILL KEEP IT FROM WARPING THE METAL.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
