Old 11-11-2010, 10:44 PM   #1
dyno
dyno's Avatar
Will these late model GM wheels fit my 80?
I found a set of these later model 16" GM alloy wheels locally. The lug 6.5 pattern is the same. Will they fit on my 80?
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 11-11-2010, 10:47 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Will these late model GM wheels fit my 80?
yep they will fit fine. You need to get some conversion lug nuts to use the caps though
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 shortened LWB
85 CCSB
90 GMC K30 Crew Dually
cochino12 is offline   Reply With Quote
Old 11-11-2010, 11:01 PM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
these are the lug nuts you would need like this for the center caps http://cgi.ebay.com/ebaymotors/New-9...item53df4430a6
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 11-11-2010, 11:33 PM   #4
dyno
dyno's Avatar
I thought about just using the long chrome lug nuts and slip thru center caps off my old white spoke wheels. The only problem with that is that the stampings on the wheel between the lug nuts will show.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 11-12-2010, 12:33 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Get the late model caps. They will really look good on your truck.
Articles-
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-12-2010, 08:15 AM   #6
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Get the caps it looks so much better.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 11-12-2010, 09:55 AM   #7
48cj2a
48cj2a's Avatar
I have always like those wheels - will they work on a 1 ton 4x4 with 14bolt and 4" D60 hubs?
I imagine the center caps could be hole sawed in the front.
How wide are they?
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 11-12-2010, 10:08 AM   #8
78 Chevyrado
They work on 1 tons too. The 4x4 guys I have seen with those wheels use a hole saw the same size as the emblem in the middle of the cap and they work perfectly.
I think they are 6.5" wide. I have the steel version of those wheels and they are 6.5" wide. look on jeffs pic... see where each lug nut is, theres a little hump on the outer edge of it? well the steel wheel caps dont have that, thats how you can tell them apart.
See on mine the caps are smooth around the outer edge.
To DYNO: if you do buy center caps seperately, they have to be the caps for aluminum wheels, the ones for steel wheels look identical, but they are bigger around where the cap meets the wheel and won't fit on aluminum wheels.
78 Chevyrado is offline   Reply With Quote
Old 11-12-2010, 10:38 AM   #9
dyno
dyno's Avatar
You are right, I need to find the caps if I go this route. Things are starting to add up though...225 wheels, 80.00 lug nuts, 40.00 caps = 345.00.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 11-12-2010, 10:54 AM   #10
48cj2a
48cj2a's Avatar
So are you saying the smooth center caps are for Steelies and the little raised ones are for the Aluminums?
03 Suburban Z71 Z71
Old 11-27-2010, 09:51 AM   #11
78 Chevyrado
^^ That's correct.
Old 11-27-2010, 12:42 PM   #12
James McClure
One shot, one kill.
This is mine with 89 factory slots and caps. I used a 3.5" ( I think) hole saw to allow the hubs to fit thru. Had to get e-bay lug nuts to mount caps. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 11-27-2010, 12:44 PM   #13
Youngbuck7072
Youngbuck7072's Avatar
i would like to see ones without the caps
........................ __
............._______|__\____
............|_({})______({})]
................(O)..........(O)
Youngbuck7072 is offline   Reply With Quote
Old 11-27-2010, 12:47 PM   #14
hitcher
hitcher's Avatar
i have the same alloy wheels on my 1 ton . only problem is i cant find any locking lug nuts for them (9/16) . anyone know where i can find some ?
thanks
hitcher is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
