Old 11-16-2010, 08:30 PM   #1
69 GMC forever
69 GMC forever's Avatar
Front spindle interchange Question
Hey Gang
This has most likely asked before but I wanna know what other GM product front spindle will fit 69 GMC upper and lower control arms . Trying to do a cheaper disc brake up grade.. they want almost 1.000 buck here for a up grade kit Iam sure there has to be a cheaper way . any one got the answers
when the smoke clears all your gunna see are my Tail lights
69 GMC forever is offline   Reply With Quote
Old 11-16-2010, 08:37 PM   #2
spike38
spike38's Avatar
Re: Front spindle interchange Question
I took the front suspension from a 72 c10, To use in my 68 stepside.
But I believe you can go as high as an 86 or 87
Spike
spike38 is offline   Reply With Quote
Old 11-16-2010, 08:58 PM   #3
hugger6933
With a lower control arms from a 3/4 ton truck73-87 you can use spindles from a 88-98 c2500 [without C6P] 7200gvw. Those spindles are capable of taking either 5 lug rotor or 6 lug rotors. you will need the upper balljoint from the same model as the spindle and rotors and calipers. The late model balljoints have the same bolt pattern as the old truck ones so that will be a bolt on. Now back to the 73 -87 lca's they have the same size hole as the balljoint for the 88-98 spindle. So make a list go to the junk yard and get greasy!! Jim
hugger6933 is offline   Reply With Quote
Old 11-17-2010, 01:18 PM   #4
69 GMC forever
THANK YOU for the INFO
Old 11-17-2010, 04:13 PM   #5
raycow
You can keep your present control arms and run stock 71-up spindles just by changing the ball joints. However it will probably be less work to swap the control arms and shafts too. The only problem with doing this is that you run into a mismatch on the tie rod ends. The cheap fix is to grab the center link while you are at the salvage yard picking up the spindles.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
