11-17-2010, 12:30 AM | #1 |
Home Built '87
Do these cab mounts need to be repaired??
Hi,
just got my frame back from the sandblaster and saw my cab mounts (rears) looked like they had a bit of cancer there. The edges are quite thin & sharp....I'm wondering if I need to build these up or cut them out and weld new ones/patches in or is it okay as is? Thanks!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
11-17-2010, 01:09 AM | #2 |
Re: Do these cab mounts need to be repaired??
Might as well fix it while you can. Weld in a square piece and cut new hole just make sure you measure twice cut once or have a professional weld it for ya shouldn't cost too much.
11-17-2010, 01:12 AM | #3 |
Gentleman Jim owner x2
11-17-2010, 08:34 AM | #4 |
For sure fix it now. I had the same issue on my 76. I took the mounts off my 83 parts truck and swapped them out. The difference is now the hole diameter is smaller so....... I buy newer front mounting hardware or massage the hole to accept the older style.
11-17-2010, 10:59 AM | #5 |
Robert Olson Transport
those definately need fixing
11-17-2010, 11:04 AM | #6 |
Arrived on a Pale Horse
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
11-17-2010, 02:27 PM | #7 |
Here's an ad on eBay to give you an idea how to fix it pretty easy, probably a good hole saw between 3-4" would do the trick:
repair
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A Last edited by 48cj2a; 11-17-2010 at 02:28 PM. |
