Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 11-18-2010, 11:13 AM   #1
AverageJoe
Big cam in 350 tbi, high idle...
Okay i just got a lunati voodoo cam in my 350 5 speed and its tbi. My idle is really high and its only lopes when you are on the brake and rolling in 1st, once i throw it in neutral the revs increase ALOT. How can i get my idle to drop for the cam to take effect on idle in neutral? People dont believe i have a cam and its pissing me off somewhat. Something to do with a remapped computer? Bypass it? help please. I dont want to go carbed at this time
AverageJoe is offline   Reply With Quote
Old 11-18-2010, 11:27 AM   #2
scotts62
One day...
scotts62's Avatar
Re: Big cam in 350 tbi, high idle...
Man your giving that computer a headache, the computer is compensating for the cam and trying to smooth it out because in a sense it thinks it has a miss. You will have to have the computer reworked to make it even run right. How big of a cam is it?
Scott
93 crew cab build
Project 62
Old 11-18-2010, 11:37 AM   #3
benoit454
Chris
benoit454's Avatar
x2 custom computer chip to even run right, maybe it'll lope then not sure. If not you gonna end up going carb probably if a tune won't do it.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 11-18-2010, 11:43 AM   #4
scotts62
One day...
scotts62's Avatar
Tbichips.com
Scott
93 crew cab build
Project 62
Old 11-18-2010, 11:51 AM   #5
ChevyTech
The TBI trucks do not tolerate much of a cam change without a GOOD custom chip and some tuning.
If you attempt this you better have a scan tool that reads data and know how to use it, or be lucky so things work out.
You need to check the minimum air rate
Check for vacuum leaks
Check the IAC count with the engine warm and all accessories off
You need to know what the desired RPM the chip is programmed for.
Where did you get the custom chip from?
Old 11-18-2010, 12:28 PM   #6
AverageJoe
Its the factory chip, its a 91 model. It runs perfect besides a bad throttle response (rich it seems)
Old 11-18-2010, 12:30 PM   #7
AverageJoe
i believe its .489 lift 268 duration
Old 11-18-2010, 03:22 PM   #8
scotts62
One day...
scotts62's Avatar
Ouch. Yeah anything more than an RV cam will need work and more money.
Scott
93 crew cab build
Project 62
Old 11-18-2010, 06:26 PM   #9
AverageJoe
Yeah i guess ill just have to wait and switch intakes and go carb'd
Old 11-18-2010, 06:43 PM   #10
63chevyll
gets board easy.......
63chevyll's Avatar
why not mess with a chip? If everything works good
63chevyll is offline   Reply With Quote
Old 11-18-2010, 08:25 PM   #11
AverageJoe
id probably have more power with 4bbl carb, i know this tbi is killing my motor right now. its not stock,
Old 11-18-2010, 10:37 PM   #12
scotts62
One day...
scotts62's Avatar
True but if it is tuned right you will like the injection way better than a carb.
Scott
93 crew cab build
Project 62
Old 11-18-2010, 10:45 PM   #13
bigbadjohn84
dude, that cam is tiny. you have some issues elsewhere. I am running a 383 with .510 lift in mine, well .522 with the 1.6 rockers. you need to check a few things. number one, with larger cam, more air is sucked into the cylinders by the longer valve cycle. as stated before, you need to check min idle setting, reset the IAC, be sure timing is set at 0 with timing port unplugged unless you are running advance in your timing set. these are simple starts. what intake are you running? which throttle body? have you increased the fuel pressure?
bigbadjohn84 is offline   Reply With Quote
Old 12-10-2010, 10:36 PM   #14
cris well
i'm thinking about doing the same thing with a 305 with a lopey cam in it.
it's a 90 and i'd be using the stock 350 throttle body that is on it now. should i up the fuel pressure on it or should the smaller cubes be ok with the 350 TBI?
how do i check min idle setting and reset the IAC? sorry i don't know anything about TBI systems.
cris well is offline   Reply With Quote
Old 12-10-2010, 11:35 PM   #15
scotts62
One day...
scotts62's Avatar
Just had better read up on cam swaps if your going to keep a "stock" TBI, if you start throwing big cams in a stock TBI truck and think it will run right, it wont..
Scott
93 crew cab build
Project 62
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
