11-21-2010, 02:23 AM | #1 |
78K & 79C Jimmys
76 Terry Taurus
Few years back we bought an old 76 trailer where the wifes brother camps
knew it was leakin but didn't know where so we torn out some old ceiling to figure it out roof supports were toast so we went with 2x3 with cut to a curve ends to help water run off instead of 1x2 quite spaced we did 2x3 every 16 down the roof
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 11-21-2010 at 02:28 AM. |
11-21-2010, 02:34 AM | #2 |
78K & 79C Jimmys
Re: 76 Terry Taurus
so after removing the rubber membrane glued to the roof we found the leak
look at the vent for the fridge....they never installed two screws lol did all new wireing put in wires for even surround sound built new cupboards only used the old doors
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-21-2010, 07:37 AM | #3 |
78K & 79C Jimmys
Re: 76 Terry Taurus
we renforced the roof as we felt my 300lbs might be to much for it
we removed the leakin hot water tank(going electric) the bed across the back was a useless super single going to make a king size outa it, by removing cupboards but to do that we had to rip out the old bed and walls down to the floor wife made new covers for the cushions
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 11-21-2010 at 07:43 AM. |
11-21-2010, 07:52 AM | #4 |
78K & 79C Jimmys
Re: 76 Terry Taurus
with the walls not holding much up including the trailer we had stuffed the underbed with everything we could to keep the bed up lol
the upper drop sides and golf clubs plus other bits of wood
11-21-2010, 07:57 AM | #5 |
78K & 79C Jimmys
Re: 76 Terry Taurus
with the wallsand floor torn out we were able to spread out the walls and with 2x4 to the roof pushed the roof back up to where it should be
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 11-21-2010 at 07:57 AM. |
11-21-2010, 08:10 AM | #6 |
78K & 79C Jimmys
Re: 76 Terry Taurus
we built a new floor with 3/4 inch plywood overlapping
if i fall threw the roof don't wana go threw the floor too with the back opened up we slid in the new floor supported to the roof this floor was built in the fall when the camp is closed and the trailer was left with the supports to the roof all winter the next spring we started the back walls
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 11-21-2010 at 08:21 AM. |
11-21-2010, 08:20 AM | #7 |
78K & 79C Jimmys
Re: 76 Terry Taurus
it took three trys to get the angle right to hold the wide back window
1 inch foam Rona's Vermont oak paneling and vola two six foot singles or king size with the table is in if you look at the old pics of the back u can see the difference now
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 11-21-2010 at 08:29 AM. |
11-21-2010, 08:26 AM | #8 |
78K & 79C Jimmys
Re: 76 Terry Taurus
old bed vs new bed
12-04-2010, 09:10 AM | #9 |
78K & 79C Jimmys
Re: 76 Terry Taurus
Bathroom gone,turns out the shower drain was cracked leaking into the floor,nasty
floor replaced up to front bed overlapping .75 inch plywood =1.5 inch floor with no sag the floor is done leaving a key(loose sections to remove and overlap again as only the last 4 feet remain)
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 12-04-2010 at 09:15 AM. |
12-04-2010, 09:20 AM | #10 |
78K & 79C Jimmys
Re: 76 Terry Taurus
most all the work is done out of season,by generator
and this since owned in spring 05 ice on the beach
12-04-2010, 09:31 AM | #11 |
78K & 79C Jimmys
Re: 76 Terry Taurus
better shot of the rear bed
keep in mind this was a super-single across the back now the rear table fits in for a king bathrooms be redone moved the fridge to where it was before see a lot driving up and back lol........
12-04-2010, 09:38 AM | #12 |
78K & 79C Jimmys
Re: 76 Terry Taurus
these are how it is inside this year.
2010 outside the rotten deck was next......8X16 useless for a screen tent
12-04-2010, 09:47 AM | #13 |
78K & 79C Jimmys
Re: 76 Terry Taurus
When the park is open it has a nine hole course
they have over 100 trailers,plus cabins/cottages there are parties, dances, at the lodge or the trailer crawl.......involves lots of booze and no ability to walk needed these guys do a pig roast
12-04-2010, 10:23 AM | #14 |
78K & 79C Jimmys
Re: 76 Terry Taurus
these are some beach and one of a fifth wheel i pulled out later on
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 12-04-2010 at 10:24 AM. |
12-04-2010, 02:46 PM | #15 |
Burnouts are therapeutic
Re: 76 Terry Taurus
great job on the camper, my grandparents use to take us camping in a terry of about the same vintage. Looks like a great place to camp.
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
12-04-2010, 03:13 PM | #16 |
78K & 79C Jimmys
Re: 76 Terry Taurus
thanks the inlaws have 11 trailers plus ours up there,it's 2 hours away
thats why i'm rarely on here summer weekends we put a new deck on this year 24X12 those pics are next
03-07-2011, 09:56 PM | #17 |
78K & 79C Jimmys
Re: 76 Terry Taurus
Spring of 2010 the owners of the park were putting up new hydro/poles
When we opened we decided to build a new deck as this one was gettin soggy and moved when walked on Insides withstood another winter no probs no wonder it's a very weak deck
03-07-2011, 10:04 PM | #18 |
78K & 79C Jimmys
Re: 76 Terry Taurus
with so much family up there the deck base went real quick
03-07-2011, 10:11 PM | #19 |
78K & 79C Jimmys
Re: 76 Terry Taurus
the old deck was 8 feet out and 16 across
new one is 12X24 and up 8 inches higher or one step up new stairs
03-07-2011, 10:22 PM | #20 |
78K & 79C Jimmys
Re: 76 Terry Taurus
i tried to "draw" out my idea.....
realized i'd have to move the under supports as needed for the railing got all the lattuce i needed from pulling out another trailer (leaving site)that was earlier stuck The trailer site fits in the "stat holidays" threw the summer hence the xmas lights up there( i did throw the lights in the tree but they flipped and filled with water,not good!)
03-07-2011, 10:39 PM | #21 |
78K & 79C Jimmys
Re: 76 Terry Taurus
took my time all summer but we like how it turned out
the spindles are 5 inches apart.........i think i made a playpen for my Chihuahua
07-26-2011, 02:33 PM | #22 |
78K & 79C Jimmys
Re: 76 Terry Taurus
so far this year
resealed the deck new gazebo ceiling fan
07-26-2011, 02:43 PM | #23 |
78K & 79C Jimmys
Re: 76 Terry Taurus
July 17th while leaving about 6-7pm a storm blew in
heard a few rumbles of thunder took a pick of a bluejay 4 pm....seems the tree behind it got blasted just after i left people said that the tree tops were twisting snapping up in the wind found one cluster of trees in the bush twisted and snapped off
07-26-2011, 05:25 PM | #24 |
78K & 79C Jimmys
Re: 76 Terry Taurus
Buddy and i took a tour checkin the damage
07-26-2011, 05:30 PM | #25 |
78K & 79C Jimmys
Re: 76 Terry Taurus
seems one trailer was crushed?
hard to tell but the walls are squished down written off was the story goin round hard to make out but the last pic is twisted trees in the forrest
Thread Tools | |
Display Modes | |
