Old 12-04-2010, 05:37 PM   #1
GM72K10
Next!
GM72K10's Avatar
C30 to K30 dump
Finally found a donor C30 dump for my 86 K30 C&C. They are both model 31003. This was someone else's unfinished 2wd project. Already cleaned out the scrap front end in back and junked that and the old motor. Anyone by chance know what brand dump body this is? Parker by chance? The lift cylinder is in the front unlike the scissor lift I have on my Thiele dump. There are a few dump parts trucks for sale around here this era (this happens to be an 86) and this had the nicest floor of any of them for the price. Its also a 8'6" instead of an 8'0". All hydraulics, pto stuff came with too.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
15 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 12-04-2010, 05:43 PM   #2
GM72K10
Next!
GM72K10's Avatar
Re: C30 to K30 dump
Crummy picture, but the "host" truck.
86 K30 CUCV M1028A1
Old 12-04-2010, 08:06 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: C30 to K30 dump
I'm diggin the spotlights on the host truck. You gonna leave those on there? Looks like you've got your hands full. I've seen dump beds with the manufacturer name stamped on the sides, under the toprail, but somewhere in the middle of the side.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 12-09-2010, 07:55 PM   #4
GM72K10
Next!
GM72K10's Avatar
Re: C30 to K30 dump
Couldn't live without a forklift. Still have no idea what brand the body or hoist is, no markings anywhere. Doesn't really matter I guess. Parker was the fabrication shop that installed the body back in 1986.
86 K30 CUCV M1028A1
Old 12-15-2010, 06:23 PM   #5
GM72K10
Next!
GM72K10's Avatar
Re: C30 to K30 dump
Learned a lot about ptos this week. One from a 2wd won't work on a 4wd because it won't clear transfer case for one thing unless you have a heavy duty one from a big truck. Swap wasn't that hard. Had to make a new cradle for resevoir tank, fix dump "stop" on one side, re attach pivot to rear of host truck after cutting off of donor truck. Found adapter to use 4wd pto with existing pto shafts. Had to remove the old firetruck bubble gum light from cab top so that dump hang over wouldn't hit. Got body mounted today in 20 degree weater. Next step is to re route exhaust on driver side, tail lite and lic. plate lites, etc. All "lite" stuff lol.
86 K30 CUCV M1028A1
Old 12-15-2010, 06:40 PM   #6
70BLAZERX2
Re: C30 to K30 dump
That was a lot easier than mine to do..I used a regular flatbed..was 9 foot,cut down to 8 and put it on a 69 K/20 frame with 87 front dana60 and rear out of a 2003 chevyvan. I ran twin rams outside the frame with a electric/hydraulic pump. works great..has 5500 lbs on it...no problem..
I had am 86 but overloaded it and kinked the frame..well 7300lbs on a ton would do that
next load of gravel i haul in, I will get more pics.
70BLAZERX2 is offline   Reply With Quote
Old 01-29-2011, 04:35 PM   #7
GM72K10
Next!
GM72K10's Avatar
Re: C30 to K30 dump
Gettin closer. Have the controls hooked up, added some fluid, dumps up and down on its own now. Wish this snow would stop or I'd get more done. Still needs exhaust, tail lights, mudflaps, minor stuff.
86 K30 CUCV M1028A1
Old 01-29-2011, 05:35 PM   #8
70BLAZERX2
Re: C30 to K30 dump
I have been working mine like crazy..
5,300 lbs of gravel on this load
Old 03-20-2011, 07:48 PM   #9
GM72K10
Next!
GM72K10's Avatar
Re: C30 to K30 dump
Dump is in use finally. Even took it downtown to move daughter back from college at spring break. This thing rides very well for having 4:56s, stock tires, and being a dually. You can really tell it only has 28K on it, nice and tight. Also Found US ARMY Official Use Only under the layers of paint. Next step is a paint job and better tires. Probably the original frost white for the cab, black for the dump body.
86 K30 CUCV M1028A1
Old 03-20-2011, 07:58 PM   #10
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: C30 to K30 dump
Nice project what did you do with the mirrors on the green doors?
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 03-20-2011, 08:03 PM   #11
GM72K10
Next!
GM72K10's Avatar
Re: C30 to K30 dump
They are on or going back on the current truck after its painted. Right now it has a west coast mirror on the passenger side and a regular pickup mirror on the driver side.
86 K30 CUCV M1028A1
Old 03-20-2011, 11:08 PM   #12
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: C30 to K30 dump
Originally Posted by GM72K10 View Post
They are on or going back on the current truck after its painted. Right now it has a west coast mirror on the passenger side and a aregular pickup mirror on the driver side.
west coast is the tripod style ones?
Old 03-21-2011, 06:11 AM   #13
GM72K10
Next!
GM72K10's Avatar
Re: C30 to K30 dump
To me they are.
86 K30 CUCV M1028A1
Old 03-21-2011, 09:14 AM   #14
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: C30 to K30 dump
To me they are.
oh ok. i have just the regular ones on ine and i'm trying to track down a set of "trucker" style ones for my truck.
Old 05-06-2011, 08:47 PM   #15
GM72K10
Next!
GM72K10's Avatar
Re: C30 to K30 dump
Finally got her painted! No more patchwork paint look. Black gas tank, 4 new rear tires, "newer" front tires from P30 delivery truck. Truck has come a long way in a year. Also removed passenger spot light, has correct matching West Coast Mirrors now. Next is paint for the wheels, door panels, etc. Last pic shows as picked up last May in Pittston Twp. Pa.
86 K30 CUCV M1028A1
Old 05-06-2011, 09:57 PM   #16
78 Chevyrado
Re: C30 to K30 dump
I like it a LOT! See, there's no reason you can't do some serious work in style!
78 Chevyrado is offline   Reply With Quote
Old 05-07-2011, 12:29 AM   #17
Eyegore
What Hump?
Eyegore's Avatar
Re: C30 to K30 dump
How much weight can that carry?
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is online now   Reply With Quote
Old 05-07-2011, 06:19 AM   #18
72freak
Rottenwood Garage Member
72freak's Avatar
Re: C30 to K30 dump
Im sure the owner will chime in....but the normal GVW of a C30depending on the year is about 10,000 - 12,000 pounds. That truck with that bed and being 4x4 it probably weighs???..6000-7000 pounds. So doing the math legally you could haul 2 tons or less.
Depending on the material Im sure it would handle way more than that just not legally.
2001 Chevrolet 2500HD Crew 6.0
1999 Chevrolet Tahoe 4x4
1999 Harley Davidson Electra Glide
1996 Chevrolet C3500 Ex-cab 5.7
1982 Chevrolet C10 short fleet
1980 Toyota Corolla "Rock-n-Rolla"
1972 Chevrolet Ex-cab K-30 Dually Cummmins 5sp
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A, "Hot Rod"
1931 Ford Model A Tudor "Silverback"
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 05-07-2011, 07:01 AM   #19
GM72K10
Next!
GM72K10's Avatar
Re: C30 to K30 dump
72freak you are correct, this is a heavy duty K30, 11,000 GVW, weighs about 7000 empty, so can haul 2 tons legally but will hold more.
86 K30 CUCV M1028A1
Old 05-07-2011, 08:07 AM   #20
RuralRoute C-30
RuralRoute C-30's Avatar
Re: C30 to K30 dump
Great transformation, GM! Nice color too.
Mark
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
Old 06-18-2011, 05:25 PM   #21
GM72K10
Next!
GM72K10's Avatar
Re: C30 to K30 dump
Finally painted the wheels, sandblasted them and painted them with (forgive me) Rustoleum gloss white. Next step is the dump bed, as of now its just touched up with rattle can black but looks good from a distance.
86 K30 CUCV M1028A1
Old 06-18-2011, 05:32 PM   #22
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Re: C30 to K30 dump
how well does it drive with the diesel in it?
Thomas
1984 Chevrolet C-30 Big Dooley Choo Choo Custom 6.2
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 06-18-2011, 05:57 PM   #23
Pop's C-10
Pop's C-10's Avatar
Re: C30 to K30 dump
look good
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 06-18-2011, 06:05 PM   #24
GM72K10
Next!
GM72K10's Avatar
Re: C30 to K30 dump
Drives great, hydraulic clutch is good, better than the mechanical in my K30 dually gas pickup, hauled 3 tons with it the other day, slow but steady. Actually has the best fuel economy of anything I drive, I guess that's not saying much but all I have is 1 ton or bigger trucks.
86 K30 CUCV M1028A1
Old 06-18-2011, 07:02 PM   #25
GmtGmt
GmtGmt's Avatar
Re: C30 to K30 dump
cool, i have driven alot of diffrent 6.2 and one 6.5 but never one in a dually or with a stick shift
Thomas
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
