Old 01-17-2011, 01:02 AM   #1
triophan
noises while driving
I know this is the worst way to diagnose these kinds of things... but I figured I'd throw it out there.
I have a whirring "wow-wow-wow" noise that comes at driving at highway speeds. Its not consistant with engine RPM. And it changes depending on the gear (I THINK i have a TH350).
Also, at idle, it sounds like something is shaking and hitting the trans tunnel. Maybe unbalanced driveshaft?
In the next 2 weeks I will be completely rebuilding the suspension. Mild drop, all new bushings, alignment, possibly new tires, bearings, trying to make sure all moving parts are up to snuff seeing as how this is my daily for now.
Thanks for the input.
-david
triophan is offline   Reply With Quote
Old 01-17-2011, 01:20 AM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: noises while driving
If it's vibrating and banging that bad, it may be bent, not just out of balance. but if it's doing it at idle (with the driveshaft not turning) it's probably something in your transmission. I'm just up the road from you in Sherwood, if you need some help, shoot me a PM. I'm off work until Tuesday.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-17-2011, 01:27 AM   #3
triophan
Sweet... and just now, as I was under it, (still inspecting, seeing if I see any thing new/noticeable) I have a square pan tranny, which I think means I have a 700r4...
Old 01-17-2011, 02:18 AM   #4
triophan
AAAAAnd I dont think the crossmember was moved back when it was swapped... could be the tranny thumping the tunnel? Anyone?
Old 01-17-2011, 08:03 AM   #5
dznucks
dznucks's Avatar
Pics??
How close is the tranny to the crossmember? the tranny isnt going to move hardly at all while driving....if it bolted down properly.
dznucks is offline   Reply With Quote
Old 01-17-2011, 12:08 PM   #6
triophan
I'll see if I can get some pics today. Its rough not knowing the history. What's been swapped, when, how, etc...
