Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 01-26-2011, 05:39 PM   #1
peglegs
peglegs's Avatar
Phosphoric Acid Rust Neutralizer
found this at my local lumber yard from Ospho a phosphoric acid that prepares rusted surface's for painting it eat all the rust over night, left it black & coated the metal with a semi gloss coating and im concerned about painting now. i contacted the company and the tech said that im ok to coat with my nason (dupont) self etching primer and catylized black enamel just curious if all is well here & that it wont lift but will do a test piece 1st. im curious if anyone has used this b-4 & so far its excellent & user friendly any opinions please, thanks a bunch
1987 chevy 4x4, long bed, 350/400
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 01-26-2011, 06:13 PM   #2
Gobbles
Gobbles's Avatar
Re: Phosphoric Acid Rust Neutralizer
I was always under the impression you had to rinse the acid off after a 30 minute resonance. That was using the POR 15 Metal Ready solution (essentially just phosphoric acid). Anyway, after I rinsed it I applied my POR 15. Different paint in a different scenario but more information may be required.
Did you apply it onto a paint? or onto bare metal?
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 01-26-2011, 06:21 PM   #3
primrrd
primrrd's Avatar
ospho has ben around forever. it and "naval jelly" used to be the 2 options.
i have used it on trailers and implements.
just scuffed it up after it was dry and applied primer / paint.
the horse trailer i did for my nighbor, lasted pretty good and the roof was solid surface rust...
primrrd is offline   Reply With Quote
Old 01-26-2011, 06:48 PM   #4
peglegs
peglegs's Avatar
gobbles, instructions dont indicate any rinsing at all. i applied it to suspension parts with light rust, bare metal with some factory grey paint.
primrrd, thanks i will take your advice & scuff, what primer/paint did u use?
my big concern here is,
Will my self etching primer adhere to this coating?
Old 01-27-2011, 03:32 PM   #5
Houston54
I soak rusty parts in phosphoric acid I buy by the gallon from Home depot. After I remove a part from it I rinse and scrub it. If it is small enough it then goes in the blasting cabinet for further cleaning. If it is larger I hit it with a knotted wire wheel or 80 grit paper to get to clean metal.
I would not apply any primer or other paint product to a acid dipped part after just a rinse.
Houston54 is offline   Reply With Quote
Old 01-27-2011, 07:05 PM   #6
MAK191
on the stuff I purchased it says you can do either way. rinse with water or just let dry to black coating. But no matter how you do it you should clean with a wax and grease remover and scuff it up prior to any paint. And remember this stuff will etch your concrete, they use it for concrete staining. good luck
MAK191 is offline   Reply With Quote
Old 01-27-2011, 07:15 PM   #7
Mallory
Mallory's Avatar
I have always been told you shouldn't put etching primer over any type of acid product.The acid has already etched the metal.
Mallory is offline   Reply With Quote
Old 01-28-2011, 01:56 PM   #8
mrein3
mrein3's Avatar
I have used similar products from both Dupont and PPG. I follow the directions on the bottle. I then squirt epoxy primer on the part. Some of my parts were "treated" more than 10 years ago and suffered no return from the rust.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-31-2011, 11:04 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I was curious of letting a part soak in Phosphoric Acid.
If it has seams, it'd be good to let it soak into all nooks and crannies.
But then, if we're supposed to rinse off before painting, what would be the issue if we didn't get it all rinsed out?
66 Service truck build:
LostMy65 is online now   Reply With Quote
Old 01-31-2011, 11:21 PM   #10
shortbed70
shortbed70's Avatar
I used a product from eastwood called afterblast that leaves a zinc type coating behind and I think it was asid bassed but you sprayed on let it work for a bit then wiped off excess.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 02-01-2011, 02:41 AM   #11
peglegs
peglegs's Avatar
i coated a rusty pipe with the phosphorus & let it dry w/o rinsing off with water, let stand for a few days and applied a catalyzed epoxy self etching primer in one area and a catalyzed primer surfacer to my sample let cure for 3 days now and .....no lifting, crazing & tough as nails. tomorrow i will apply the catalyzed topcoat. im certainly not a pro at this and would really like some feed back on this........from anyone thanks
Old 02-01-2011, 03:02 PM   #12
wiggins
wiggins's Avatar
I did a frame off a a 68' P/u about 15 years ago and I used ospho on everything that had rust. I sanded everything down to bare metal sprayed with ospho, let it dry and then I sanded it back off. Sealed with a PPg etching primer, then a k-36 primer and then PPG paint and clear. Truck still lokks good today.
Preserving American History one truck at a time.
wiggins is offline   Reply With Quote
Old 02-01-2011, 09:19 PM   #13
skip99
skip99's Avatar
picklex is an acid based produst also..
Picklex 20 is used to convert the rust then a primer or rust coating can be applied to protect the surface from the elements.
Rusted metal that is converted using Picklex 20 should NOT be primed using an etch primer. The chemicals in most etch primers are not compatible with Picklex 20. Use epoxy primer if possible.
PPg says NOT to use etch primers over metal treatments..
skip99 is offline   Reply With Quote
Old 02-02-2011, 12:33 AM   #14
LostMy65
LostMy65's Avatar
Okay, So far I'm reading good things about WaxOyl.
So after you kill the Rust, you use WaxOyl which seeps into all the nook and crannies and seals with a semi-soft shell.
Here is a member who has a post about it:
Originally Posted by Lippyp View Post
Waxoyl's website is here http://www.hammerite-automotive.com/waxoyl.htm
Dinitrol is here http://www.dinitrol.co.uk/
Bilt-Hamber is here http://www.bilthamber.co.uk/shoppingbasket.php
Waxoyl comes in cans that can be applied with either a simple pastic pump and tube with a nozzle that fits straight on the gallon cans or it can be applied using a compressor powered gun, same with Dinitrol, the Bilthamber Dynax wax comes in a big aerosol with a built in tube. All of them will benefit from being stood in a bucket of hot water for a while to make sure the wax is as runny as possible, ideally you want a warm day to apply it on so the wax will flow into the nooks and crannys and joints, however do it out of direct sunlight, if a panel is too hot it'll just slide right off! Once it's set then its not a problem. It's a horrible messy job though, drive the vehicle onto a sheet of plastic that you can throw away afterwards, wear some really old clothes and a hat and just be prepared to pump a couple of gallons into all the box sections, inside panels and doors etc (drill holes if neccesary and then plug with little plastic plugs). I know waxoyl and Dinitrol also do an underseal type product in black or clear for use on the underside of the vehicle too.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
