Old 02-02-2011, 09:11 AM   #1
CEE1NG_RED
Replacement engine oil dipstick tube...
Where do you guys get your engine oil dipstick tube from that's similar/equal to the quality of the OEM? My 67 came with a 78 c/10 motor/trans (so the previous owner says), but the dipstick tube got detached when I drove it home. The tube resembles this: (http://www.classicchevy.com/chevy-up...1956-1980.html), but I am not sure if this is a quality product. Anyways, how do you guys attach it?? Mine seems to be intact; previous owner put RTV sealant to attach it, but didn't work. Any feedback would be appreciated. I haven't drove it since that incident...
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 02-02-2011, 09:26 AM   #2
truckdude239
truckdude239's Avatar
Re: Replacement engine oil dipstick tube...
Umm i've used the mr gasket it one and stock and i can;t get mine to stay in either i've tried the rtv trick but it seems the hole is to big and the tube to small. So i am goign to wat6ch this and see what every one says
David fuller
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
1987 Ford F-150 302 v8 auto -
1993 ford aerostar dads car
1999 Honda accord 2 door with 238k miles my daily driver
General manager for Marco's Carwash & lube
RIP ESLL
RIP EL Jay
truckdude239 is offline   Reply With Quote
Old 02-02-2011, 09:29 AM   #3
CEE1NG_RED
SO...you havent driven the truck also. Mine spilled a quart of oil out while driving it home; didn't notice it was the engine oil dipstick tube that got popped out of the block. Good thing it didn't mess up my engine!!!
Old 02-02-2011, 12:08 PM   #4
truckdude239
Well i've drove mine with it loose but i dont drive it much i'm interested in the fix for this also
David fuller
RIP ESLL
RIP EL Jay
Old 02-02-2011, 05:27 PM   #5
CEE1NG_RED
So...yours leak as well when driving??? Mine does.
Old 02-02-2011, 10:14 PM   #6
Captainfab
60-66 Nut
Have you checked with your local GM dealer parts department? You should get the dipstick itself to go with the correct tube. The tube should be a semi-tight fit that will require some gentle tapping with a hammer to install into the block. As a general rule any of the aftermarket chromed parts are just made in China crap that doesn't fit right.
'75 K5 Blazer 355, T400/205, D60, 14B FF
'68 RS Camaro
'66 C10 Suburban, 454, T400, 3.42 posi., etc.
'66 C30 cab and chassis, factory AC
'66 C20 former dd
'63 C10 Suburban, future 4x4 project
'63 C10 swb, future pro street project
'63 C60 292, 5 spd,2 spd rear,cab and chassis
Impala SS Rear Disc Brake Brackets For Sale HERE Camaro Calipers HERE D52 Calipers HERE
http://www.dragtrucks.com
Old 02-03-2011, 03:57 PM   #7
Lee H
Lee H's Avatar
+++ Get the real thing and make sure the stick and upper tube are a match.
Also if it leaks that much I'd be willing to bet the lower tube is missing.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-03-2011, 05:37 PM   #8
CEE1NG_RED
There's a lower tube?? How do I check if it's in the engine?? I've never done this before...
Old 02-03-2011, 09:18 PM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Gee I just have 1 big tube. No lower.
Mine leaks too.
John
Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT
1969 Chevy C10 Shortbed TH400
1999 Toyota Tacoma 4x4
oldblue1968chevy is online now   Reply With Quote
Old 02-03-2011, 11:46 PM   #10
LANDC
LANDC's Avatar
I purchased a new dipstick from GM performance parts and they use an o-ring at the base where it goes into the pan. I made sure the o-ring was greased up before I inserted it into the pan. ( Insert crude comment here) And if I remember correctly I used a little RTV above that to assure no water makes it in.
Custom Vehicle, Custom Problems.
LANDC is offline   Reply With Quote
Old 02-04-2011, 12:25 AM   #11
CEE1NG_RED
What's the part#?? Cost? Pics? Is it made for 67-85 Chevy 350 short blocks?
Old 02-04-2011, 03:52 AM   #12
cdowns
cdowns's Avatar
the GM dipstick is good the only other one i will use for a custom look is lokar it fits great no issues
Old 02-08-2011, 12:31 AM   #13
LANDC
LANDC's Avatar
The dipstick I bought was for my bbc 454. But GM Performance Parts should have any dipstick produced for all sbc and bbc blocks. Grab a catalogue and check it out. They may even have an online catalogue. I identified my oil pan and from there found the appropriate dipstick and tube. Wasn't cheap, but piece of mind when it comes engine componentry is priceless.
Old 02-08-2011, 01:09 AM   #14
CEE1NG_RED
Well..I id. the engine block, but how do you id. an oil pan???
Old 02-08-2011, 03:16 PM   #15
LANDC
LANDC's Avatar
By pictures in the Performance Parts Catalogue I visually identified what pan I have. There were many options for my block, and even when I told the GM parts guy what I wanted he was surprised that pan came with my block. So I confirmed the pan and told him the dipstick and tube I wanted. He in turn confirmed that those were the right parts for the pan I had and voila I have a dipstick and tube. And never again will I forget to take them off before hoisting my engine out.
Old 02-08-2011, 04:18 PM   #16
Lee H
Lee H's Avatar
You really only need to match upper tube and dip stick as a set. Example would be 1972 C10 or 1986 Camaro, it doesn't matter which. The only real difference is the length of the tube and dip stick, long or short. Pretty sure you can call GMC Paul and he'll help. That comb will assure the stick is the right distant below the crank throws. Just add oil to right level on the dip stick. Will probably be 4.5 or 5 quarts for an GM pan or who knows for an after market pan.
Old 02-08-2011, 05:42 PM   #17
CEE1NG_RED
...will the oilpan have a serial# or some ID?? I know it looks like an aftermarket, unless the OEM are chrome plated??
Old 02-09-2011, 06:07 PM   #18
CEE1NG_RED
Just found out that my dipstick is "Made in China." Does your OEM one says USA?? Many Chevrolet dealership parts stores have discontinued the upper tube and dipstick, only found one location, but it's a drive!!!
Old 05-23-2011, 02:41 PM   #19
doodah man
doodah man's Avatar
CEE1NG Red, Did you ever find a source for a good replacement? I ordered one from LMC, but haven't tried it. I guess it's the one that everyone is saying will not fit.
Searched GM performance and GM parts direct but didn't find anything yet.
Still got to get the old piece out of the block first...
1972 C-10 Deluxe
350 V8 - 350TH
We're not the jet set
We're the old Chevrolet set
doodah man is offline   Reply With Quote
Old 05-23-2011, 06:15 PM   #20
CEE1NG_RED
...haven't installed mines yet due to my busy schedule. I ended up buying a GM dipstick tube @ Chevrolet and a Lokar one. I think I'm going to be using the Lokar,
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
