Conventional Tach on LS2
Hey guys,
I bought a cheap Sun Super Tach II to run on my LS2 swap using the tach wire from the ECM (E40). It would not move the needle. I did some research on the web and several people said that you need to put a "pull-up resistor" in the circuit. The conventional tachs are looking for a 12 volt signal with the speed pulse riding on it. The ECM evidently just sends the speed pulse out on the tach wire at low voltage. So I put a 1000 ohm resistor from the tach power wire to the tach signal wire going to the ECM. So that pulls the tach signal up to 12 volts. Works like a champ. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
![]() Join Date: Aug 2010
Re: Conventional Tach on LS2
Interesting...My Auto Meter tach had to be set for 4 cylinder mode to read properly.
67 5.3L Build |
Works like a dream thanks for the info.
Posted via Mobile Device |
My tach reads correctly, but the needle vibrates an awful lot. Any ideas how to make it more stable?
67 5.3L Build |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
"Interesting...My Auto Meter tach had to be set for 4 cylinder mode to read properly.
__________________" 67, that is quite common on the LS motors.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 02-22-2011 at 06:36 PM. |
67, Are you using the ECM tach wire? or do you have it wired up to one of the coils. The signal from the ECM should be very clean, and the tach should work on the 8 cylinder setting.
My tach is very stable, no noise at all. TR
Windy Corner of a Dirty Street
I have mine (8.1L on a P59 ECM) to the ECM tach wire but also had to set it in 4 cyl mode otherwise it was reading 50%. My tach reads smooth and just as accurate as the GM Tech II scan tool.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Dang DirtyLarry, Now you've got me wondering. I will have to check what setting I am using to be sure.
TR
BMW & ASE Master Certified
Ive got an autogauge (by autometer) and its set on 4cyl mode and it reads about 200 rpm more compared to HPtuners reading.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#10 | |
BTW….I love you truck! Man, your swap turned out great! ![]()
Yes, I am using the tach wire, but my harness was done by Speartech, so I'm not sure which wire it is. If everyone else is getting a smooth signal, maybe I'll contact John and see if he has any ideas.
67 5.3L Build |
DirtyLarry,
Thanks for the kind words. I love driving the truck with this swap. Yep, I am using the 4 cyl setting!! Sorry, I read the switch wrong. If I get a chance this weekend I will put a scope on that signal and see what it really looks like. 67, Maybe the signal is just marginal and the gage is dropping "tops" making the needle erratic. Does your harness use a pullup resistor? Maybe that is the issue. TR
#13 | |
67 5.3L Build |
#14 |
I took a look at the tach signal that the ECM is putting out on the tach wire. This is for the E40 ECM so I don't know about other ECMs. The tach wire is used to drive the OE tach in the vehicle.
The ECM puts out a low voltage square wave that is two cycles or "tops" per engine revolution. That is the same as the number of times a 4 cylinder fires per revolution. So that is why we have to use the 4 cylinder setting to get the correct RPM. (V8 fires 4 times per rev.) The first picture is the signal from the ECM. So the (-1.5 V) voltage is probably too low to fire the traditional tachs that are looking for around 12 volts. The second picture is the signal with the pullup resistor installed. So now the voltage is up to 10V at the high. So the tach wroks fine. The engine was idling at about 680 RPM or 11.3 rev per second. The frequency of the signal is twice that, around 22 cycles per second. TR
#15 |
Wow, that is some great info. Thanks for posting. I was just curious how you did this. Was it done with an oscilloscope?
67 5.3L Build |
#16 | |
I read up on your swap. Very nice work. Very nice truck. Let me know if you get your cruise control to work. I took the data on the tach line with a cheap USB data aquisition unit. http://www.mccdaq.com/usb-data-acqui...08-Series.aspx I have the 1208FS. It has an oscilloscope mode and a data logger mode. Very handy. TR
#17 | |
67 5.3L Build |
#18 | |
I believe the 1.4 V signal was not from the ECM. The MCCDAQ USB1208FS has a low level output signal at 1.4V. Essentially you were using the DAQ as a pullup for the ECM Hall Effect Signal. I made the same mistake, thinking my O2 sensor was outputting 1.4V. 100$ sensor later, I have confirmation from MCC that Single Ended readings on the DAQ output a 1.4V signal. This can be confirmed by reading the pins directly on the DAQ with a DMM. Mine reads 1.4VDC, 11 micro Amps. I found this stray voltage does not happen when you use differential measurements. Typically Hall Effect sensors ground when the magnet is lined up. If you aren't getting a reading, check the power being applied (pullup circuit). There may be a blown fuse or loose connection Carl |
#19 | |
1. I am not reading the sensors. I am reading the tach signal output from the ECM. Neither of the engine rotation sensors would be suitable for a tach. The crank position sensor is 24 tops per rev and the different tooth lengths give a non constant frequency. The cam position sensor is one cycle per two revs. 2. I was using a single end connection. I went back and measured using a differential setup as you suggested. There is then no signal recorded from the ECM. So, The ECM is grounding the tach signal line at a frequency of 2 times per engine revolution. So to get any signal at all the tach has to supply a voltage on the signal line. With the pullup resistor you then get a 0-12 volt square wave that the tach likes. (As in the graph above just shifted up) Thanks for the tip. TR PS I found this recording of the two engine speed sensors. http://www.ls1tech.com/forums/pcm-di...going-bad.html
#20 | |
I just did an 05 5.3L swap and I am using the stock style 70 tach and it does not read at all from the ECM's tach wire. So if I install the same 1000 ohm resistor like you did it should all work our fine? Can I just put the resistor right at the back of the gauge under the spade connections? Is their a power and a signal side of the resistor? Thanks for any further help on this. Kevin LFD Inc. |
#21 | |
![]() Join Date: Jun 2007
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#22 |
Is this a radio shack resister or? Would you have a part number or description so I can tell them what I am needing? Now I do not have a program for my ECU as I had Street and performance do the flash, will a hand held programer do anything for this?
Kevin LFD Inc. |
#23 |
Rokcrln,
The current draw is very low so a common 1/4 watt 1000 ohm resistor from Radio Shack will work fine. Should be less than $1. There is no + or - to the resistor, mount it either way. It just needs to go across the power and signal wires. Shouldn't matter where. Like Thealien said. With a stock tach from a V8 you will probably need to change the tach calibration with tuner software. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 Last edited by TR65; 03-27-2011 at 10:36 PM. |
#24 |
Future TOTM Winner
This FAQ has been up for a while, but for the sake of information for the masses I felt the need to add to it.
With EFI Live I simply tell the ECM to "pull up" the output of the factory harness wire. Also I correct the pulse calculation so that the wire puts out the correct signal for a standard 8 cyl tach. The reason that people are having a variety of things happen here is most likely due to how the person that flashed the computer set up (or didn't set up) the tach signal.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#25 |
Critter, when the computer is flashed, who would you recommend to have it done correctly?
Tags |
ls2, tach wire, tachometer |
Thread Tools | |
Display Modes | |
