Old 02-17-2011, 11:08 PM   #1
bigo181979
Junior Member
bigo181979's Avatar
Porterbuilt C4 Dropmember who has them/opinions...
Just wondering who all has one? Trying to decide if I go with the C4 member or the regular dropmember...
Who has one and what do you think of it... What are the pro's and con's vs the regular dropmember?
Anyone know if the shockwave's for the C4 unit can lift a big block and 4l80e trans?
bigo181979 is offline   Reply With Quote
Old 02-18-2011, 12:19 AM   #2
Ronm909
67GMC Slammed
Ronm909's Avatar
Re: Porterbuilt C4 Dropmember who has them/opinions...
I gots a regular one and love it...C4 is a sportier set up but wont lay frame.. regular dropmember will totaly lay frame
my dropmembered 67 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383215
Ronm909 is offline   Reply With Quote
Old 02-18-2011, 01:26 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
There's probably only a couple dozen of them out there on the road that I know of (I have sold less than 100 of them). It has a more aggressive camber gain and 9 degrees of caster built in. The C4 components (88-96)significantly decrease the unsprung weight. If you run a shock-wave it will limit the amount of drop. With a 27" tall tire you will still be an inch off the ground when deflated. You can incorporate a coil-over also.
If you are looking for performance, this is a great solution. If you want a slammed truck that lays on a big tire and rides smooth... the regular Dropmember is a great choice.
We have also been working on a performance version of the Dropmember (Dropmember Touring) that uses a coil-over and maintains the C10 spindles and brakes... its main focus is performance as well and will have some cool features/options. Stay tuned...
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-18-2011, 10:29 PM   #4
SCOTI
SCOTI's Avatar
I have a C4 Dropmember for a BBC/4l80e sitting in a box waiting to get dusted off (Vette parts sitting right beside it). Fall 2011 should be the start date on the assembly of those parts....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 02-19-2011, 10:10 AM   #5
Wild83C10
Wild83C10's Avatar
I've got one. It's good so far, but I haven't spent much time tuning it. You can lose 60-100 lbs off the front end (can't remember the exact number) from the stock stuff. It could cost a bit more, but performance cost money right?
C4 Dropmember pics
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-19-2011, 05:47 PM   #6
SCOTI
SCOTI's Avatar
C4 Dropmember pics
I didn't compare the steering units @ the time but I weighed everything else out (C4 vs. stock) & recall about 100# difference. This included 'loaded' upper/lower a-arms, spindles, calipers/rotors (12x1.25" D52 style iron truck stuff vs. 13x1.10" 2-pot alum PBR C4 stuff), 7" bag & Monroe shock.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-21-2011, 09:45 PM   #7
bigo181979
Junior Member
bigo181979's Avatar
Humm, interesting... I was actually looking at the C4 member for the cost savings to be honest.. I can get 2 complete c4 assemblies (arms spindles calipers everything) for $300 through my day job... and can get the shock waves at a break too... Now to get just a brake kit that is comparable would cost me more then the whole c4 assemblies...
But I really want this thing to lay out....
Guess I have some decisions to make!?!?!!
Old 10-29-2011, 04:14 PM   #8
chevychase
chevychase's Avatar
Bumping this older thread to stir it back up...
Joe
chevychase is offline   Reply With Quote
Old 10-27-2013, 11:22 AM   #9
bharrison1
bharrison1's Avatar
i have a chance to get a used dropmember its the bag version.is it possible to switch this to the coilover setup?
bharrison1 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
