Old 02-21-2011, 09:00 AM   #1
86 Rado
86 Rado's Avatar
90 Checy 4x4 not working
I am new to this whole 4x4 thing and mine is not working. I shift it into 4 wheel drive. but get nothing. What are the most common things I should look at first? I put the truck in neutral and engage 4 wheel drive, sometimes it will grind a little but not allways as I shift it in. It has the floor shifter to engage it. Thank for your assistance.
09 Black Challenger R/T
90 Scottsdale shortbed 4x4
71 Impala Custom
86 Rado is offline   Reply With Quote
Old 02-21-2011, 10:45 AM   #2
jrdv
jrdv's Avatar
Re: 90 Checy 4x4 not working
If I remember correctly, there is an electric actuator that is in the front diff. Check for loose connection or wiring. It will be on the right side of the diff and the wires go to the transfer case.
I know that it has the manual shifter, but it is still electronic.
The solenoid?? in the diff is know to go bad.
Hope this helps a little.
John
jrdv is offline   Reply With Quote
Old 02-21-2011, 11:43 AM   #3
86 Rado
86 Rado's Avatar
I have learned alot about this in the last hour. Are you talking about replacing the actuator? I can get that at autozone for $87 but I guess I need to check the fuse first.
71 Impala Custom
Old 02-21-2011, 12:57 PM   #4
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
I ran into this with the plow truck a few weeks ago, well the harness got torn out of the truck while I was plowing...
I made a slug that is the length of the actuator when engaged and slid that in then screwed the acutator back into the diff. Works like a charm! Not really the proper fix, but it's a plow truck!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 02-21-2011, 03:42 PM   #5
86 Rado
86 Rado's Avatar
I did go out and check the fuse, lookes good. I put it down in 4L and drove it just a minute. It was definately on low and drover a little different. I could hear the fron end whining somewhat. But lights never lit up. W 2 weeks ago I tried to use it and the front wheels just sat there while the backs were spinning. Does this help any to narrow it down. Been raining all day, so I cant get under it till this crap stops.
71 Impala Custom
Old 02-21-2011, 07:15 PM   #6
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
More than likely your actuator in the front differental is out. Your truck will drive different when it is in low, because of your transfer case. Crawl under it and look at the front end and make sure the wires are hooked up still.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-21-2011, 07:39 PM   #7
propanemudtruck
to test that actuator when it dries up, simply remove it and hook it to a 12 volt power source. If it extends just under an inch at the end, it's working. There are 4 wires, two to confirm it's in 4 wheel and the two that activate the actuator.
-Kevin
Old 02-21-2011, 07:46 PM   #8
86 Rado
86 Rado's Avatar
Is this easy to get to or do I have to remove anything to get to it? I dont have any kind of power source unless I can use my battery charger. Sorry if I sound stupid, just not an electrical or much of a real mechanic for that matter.
71 Impala Custom
Old 02-21-2011, 09:54 PM   #9
onebadbowtie
onebadbowtie's Avatar
just take some wire a hook them to positive and ground posts on your battery in your truck and to the actuator
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 02-22-2011, 07:53 AM   #10
propanemudtruck
It takes a fairly large crescent wrench or channel locks to get around the actuator, but there's room from underneath to spin it out. have fun getting dirty!
-Kevin
Old 02-22-2011, 08:35 AM   #11
86 Rado
86 Rado's Avatar
Thanks for all your help. I will give it a shot. "Have fun getting dirty" come from a mudder, sound like you do. One other thing, does it hurt to drive it while its out or must I reinstall it.
Jerry
71 Impala Custom
Old 02-22-2011, 10:02 PM   #12
propanemudtruck
Wouldn't be the best idea, I great 1" hole for fluid to get out and debris to get in...
It's been a while since I really had a mud truck, but I find ways to get dirty... The weapon of choice was an S10 blazer with 1 ton running gear, 40" tires and an LP powered 366 BBC. Those were the days!
-Kevin
Old 02-22-2011, 10:13 PM   #13
rayfinseats
I agree: MINE WENT BAD ON MY 90 1500 once. Same issue. Easy to change.
rayfinseats is offline   Reply With Quote
Old 02-23-2011, 12:18 AM   #14
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yep there is the actuator in the front diff that can go bad. There is also a cheaper part on the transfer case that can go bad. Its a little sensor/ actuator that is magnetic I believe and it sits on the top of the transfer case. Has a 2 prong that goes into. This was bad on my '88 and the diff actuator was still good. I think I got the part at oreilys and it was like 10$ or 15$. Hope this helps.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-24-2011, 02:20 PM   #15
86 Rado
86 Rado's Avatar
Ok, I was able to check the actuator and it goes out when engaged and back in when not. Seems to function as it should. What should I go to next. Someone said part of differential? Thanks for everyones input.
71 Impala Custom
Old 02-24-2011, 11:03 PM   #16
jrdv
jrdv's Avatar
Only thing to do now is swap in a solid front end!
Old 02-24-2011, 11:26 PM   #17
86 Rado
86 Rado's Avatar
What about that indicator switch?
71 Impala Custom
Old 02-25-2011, 12:03 AM   #18
Hoods69BadBowTie
Chevys Kick A$$
Did you try the one that goes on top of the transfercase like I was talking about in my other post. Here's a link to a pic of it from google http://www.monsterautoparts.com/CHEV...4%20switch.jpg
-LATER
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
