Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 02-21-2011, 11:36 PM   #1
70stroker
70stroker's Avatar
po420 and po430
96 yukon, 4x4, 5.7l.
Its throwing a po420 and po430code. the po420 pops up about every 60 miles or so. the po430 just came up for the first time today. I know its cat efficiency low.
What are some possible causes?
Good starting test procedures?
Any common problems associated with these codes and trucks?
Thanks in advance
70stroker is offline   Reply With Quote
Old 02-24-2011, 07:26 AM   #2
scotts62
One day...
scotts62's Avatar
Re: po420 and po430
Anyone have an idea or need more info?
Scott
93 crew cab build
Project 62
Old 02-24-2011, 12:12 PM   #3
Boog
primer is finer
Boog's Avatar
Re: po420 and po430
Scott there is probably a list of PO codes already posted here somewhere. It might be helpful to make a sticky out of that. Just a suggestion.
I know the PO430 is "catylitic activity below threshold". It means the cat ain't doin as much as it should. It can be a cat just gone bad and it can be something upstream has caused it to go bad. Burning overly rich, burning oil and burning antifreeze can all cause a cat to go bad.
The 02 sensor behind the cat monitors the cat's activity only.
How well does the truck run upon cold startup and when warm? Strong smell of gas when cold? Down on power when warm?
I don't remember what the PO420 code is for.
Scott?
Boog
69 Chevy stepside, 358/T350, 4.10 posi, 4.5/4 drop, rallys, poboy driver
09 Yukon SLT 4wd, 06 GMC crewcab Z71 5.3, 4.10
All GM..'nuff said,
Member of Jr Nation 88
Old 02-24-2011, 07:32 PM   #4
scotts62
One day...
scotts62's Avatar
Re: po420 and po430
Ya if you find it before me pm me and ill make it a sticky to put the the FAQ thread that is a sticky.
I dont remember much codes, its been a bit since i have played with code readers and kept up on all that.
Scott
93 crew cab build
Project 62
Old 02-24-2011, 08:13 PM   #5
bwood
bwood's Avatar
Re: po420 and po430
How does it idle and how does it run at wider throttle openings?
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 02-24-2011, 08:17 PM   #6
bwood
bwood's Avatar
Re: po420 and po430
P0420-Three-Way Catalyst System Low Efficiency Bank 1
P0430-Three-Way Catalyst System Low Efficiency Bank 2
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Old 02-24-2011, 10:15 PM   #7
70stroker
70stroker's Avatar
Re: po420 and po430
yes thats what the codes are, sorry i was a little tired when i first posted and just assumed everyone new what the codes where. Sorry it was my bad.
i have found out I have bad cats. Both rear o2s where crosscounting the same as the fronts, and they shouldnt, the job of the cats are to do away with any rich or what not mixtures and then the rear o2s should steady out and read a good mixture, well they were not.
After we do not have emissions testing I took the cats out and welded in pipe. I sold them at the scrap yard for 40 a piece, then spent 8 dollars and built my own o2 eliminators. Very simple to do, and the codes do not come on anymore.
Thanks for everyones help.
Old 05-16-2011, 11:31 PM   #8
68C15
blood type; Retumbo
68C15's Avatar
Re: po420 and po430
just be ready for insufficient EGR flow codes in the future.
the #1 reason I see P0420 and P0430 is coolant leaking past the intake gaskets. coolant contains silicates. silicates create a coating on the converter substrate blocking it from performing the necessary chemical reactions. it doesn't take a large leak. a very small leak, even vapors, over an extended time will do this.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-17-2011, 09:58 AM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: po420 and po430
GM had a cheesy catalyst media when they first started using Cats, but the media used now is pretty techno-savvy. Whereas the early ones were filled with a palladium-coated ceramic-type ball-shape, the later ones look like honeycomb and are fairly complex in their design. If you look at each end, you'd think that it is a straight-thru flow, but it isn't. The media isn't heavy, but stick it inside the shell and it gains weight.
Hope it all works out for you.
Member Nr. 2770
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
