02-24-2011, 07:03 PM | #1 |
Needs a Big Block
Project: Tall Grass
Hey guys, been around here for a while, but Finally getting around to the rebuild of my slammed 66 er 64
My buddys have been calling it project tall grass, as one of my favorite sayings goes, throw it in the tall grass never to be seen again. any one with a farm knows wha I mean. the truck has sat idle for a two long. as it sits now its on a frame with a 3" Z and 10" notch and a two link. never really happy with that im now starting fresh using a dropmember , pb arms, notch and 4 link. here she is before the z 1.5 sectioned crossmember spindles and bagged . in action after the Z and some 20's
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 Last edited by Slammed66; 02-24-2011 at 07:34 PM. |
02-24-2011, 07:14 PM | #2 |
Needs a Big Block
Re: Project: Tall Grass
jump ahead. here she is laying in the tall grass
so fast forward a bit, I finally bought a house. crudely finished the garage with some insullation some osb and a couple coat of paint . and here we are today. sitting idle collecting debris and dust while the new frame gets thown together
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
02-24-2011, 07:29 PM | #3 |
Needs a Big Block
The Bullet. carb,d 5.3 to a th400.
02-28-2011, 12:25 AM | #4 |
Needs a Big Block
Got a bit more work done today........
mounted the 4 link brackets I got from Porterbuilt removed all previous leaf and 10 bolt junk this frame came with, the truck was prostreet. then I spent an hour battling the shock mount crossmember and the crooked crossmember, the c notch was boxed in on the inside and welded to the crooked one, took some serious grinding and beating but its all out now. NOTCH TIME!!! Hmmmmm leave it , and bury this thing over some 35inch all terrains??? Nahhhh trim it to fit, if your wondering, the notches came from porterbuilt, and it they look lower than usual its beacuse they are, I want to put em as low as I can to keep the maximum bedspace , and im limited in tire size being a step side. so this is all for now More tommarow.
02-28-2011, 12:43 AM | #5 |
Registered Loser
Very cool! I'm really starting to like them bagged steppers.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
02-28-2011, 12:53 AM | #6 |
Needs a Big Block
Thanks me too, I was going to go fleet side. But, I used up my box when I turned this>>
into this!! after that I figured it was born a stepper, might as well leave it alone.
02-28-2011, 01:01 AM | #7 |
Registered Loser
Wow, that's quite a transformation! And I thought I was crazy for bagging a 3/4 ton.
02-28-2011, 01:13 AM | #8 | |
Hell yeah!!!
Stock is good but custom is the sh*t! |
03-18-2011, 02:11 AM | #9 |
Needs a Big Block
well, im back from work, and ive got both the rear notches welded in , I just need to trim out the frame and cap them,... I forgot to take pics. Ill grab some in the am, but for now, some new parts showed up!!! things are getting exciting now
03-18-2011, 05:08 AM | #10 |
looked pretty good before... cant wait to see it finished.. btw ur utility truck looks pretty hood to!!!
03-22-2011, 10:42 PM | #11 |
Needs a Big Block
Thank guys you've both got some sick trucks..
not much progresss but burn in one notch , hung some more front junk, still need to buy a rack and install the notches.. baby steps.... took a couple pics of the old frame and my lack luster z. thats it for now, off to work for a week then 26 hours of driving and portland swap meet Booooya !!!!!!!
03-23-2011, 12:49 PM | #12 |
Just here to tinker
That truck is gonna be sweet man. I am hoping to make it to the Portland swap meet as well.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
03-23-2011, 06:36 PM | #13 |
Needs a Big Block
Thanks Cort. Your last truck was awsome I loved the look, can't wait to see how your burb progresses!!!!
Hopefully you can make the swapmeet looks like your a bit closer than me lol Posted via Mobile Device
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 Last edited by Slammed66; 03-23-2011 at 06:37 PM. Reason: I suck at spelling |
03-24-2011, 11:52 PM | #14 |
Cool man. Looks great.
04-05-2011, 10:02 PM | #15 |
Any updates? Pics of your swap meet finds?
04-05-2011, 11:53 PM | #16 |
chevy only
duuude glad your back this is one of my most favorite trucks!! killer job on both
CHEVY ONLY... Nothin Else ! |
04-08-2011, 12:05 AM | #17 |
Needs a Big Block
Wow thanks dino, that means alot coming from you!!
I just finished another set at work and im headed back home in the am, so progress pics soon and maybe some of my parts scoress from portland.. The lil red 66 gmc has moved to a new home a while ago, im pretty stoked to see Dave AKA Notch1988 take it all the way!!!! build thread dave lets go!!!!!
04-15-2011, 03:05 PM | #18 |
Needs a Big Block
Update?? dont mind it I doooooooo.
Got the notches in 4 links mounted and tacked, gotta check on the proper way to set up and mount the brackets on the diff. also tacked up the watts link. gotta get a couple tubes bent for the notch that I can attatch my upper bag mounts to, then shocks cycle it and finish weld everything. Portland was awsome, bought, a mint grille support, new tailgate a roll pan, new steering wheel, a traffic light lol, a set of rims and a front bumper for my 06. New parts have started rolling in too, yesterday these showed up!!!! and fedex left this on my porch this morning!!!!! unisteer power rack, ohhh yeaahh
04-15-2011, 03:16 PM | #19 |
Needs a Big Block
Also not sure if I made the right move or not, as the torque thrusts looks awsome on everything, especially my truck. but I have a verbal sale , of my 17's to PHAT TONY, they'll look great hes building a killer 72 2wd blazer
pics of his ride can be found in here... http://67-72chevytrucks.com/vboard/s...ad.php?t=39938 Ive always wanted a 18's and 20's combo , and im gonna get this thing on the road this year , so boyds or intros werent in the budget, so I ordered up a set of 18x8 and 20x10 eagle 225's the front are back ordered, but they claim theyll be out this month sooo we'll see... if they show up ill be puuumped, should look good!!!!
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 Last edited by Slammed66; 04-15-2011 at 03:17 PM. |
04-16-2011, 08:34 AM | #20 |
ya those should look really nice!!! looking good man
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
04-16-2011, 02:02 PM | #21 |
Registered Loser
Dang, I'm really diggin' those rims! I'm still torn between big rims or steelies.
Were the upper arms on the wrong side in the first pic of the new front set-up?
04-16-2011, 11:30 PM | #22 |
Needs a Big Block
Yep hahaha, you noticed eh
Burnt I'n the rack notches test fit the rack, then broke it down. Got most of my pieces, primed and painted. Pics tommarow after I get more painted and some reassembled. Play safe tonight kids!!! Posted via Mobile Device
04-17-2011, 12:08 AM | #23 |
DAMN!!! Lookin good Matt!
One of my favorite trucks too. |
04-17-2011, 02:04 AM | #24 |
Is the steering wheel going on a stock column? If so, will you post a pick of what the adapter looks like and give me a rough idea of how deep it is? Your truck is really coming along. I can't wait to see the progress pics.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
04-17-2011, 11:28 AM | #25 |
PROJECT 7DEUCE
Im in.......... I have always wanted a step side and this one looks like its gonna be pretty damn nice..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Thread Tools | |
Display Modes | |
