Old 02-24-2011, 09:09 PM   #1
Dynomutt
Dynomutt's Avatar
Drive shaft lengths
Are the 2 piece drive shafts the same lengths in small block and big block 2wd, LWB's?
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 02-25-2011, 01:34 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Drive shaft lengths
No, due to differences in engine positioning, the shafts are not the same lenght. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-25-2011, 12:25 PM   #3
Dynomutt
Dynomutt's Avatar
Thanks. So the engine sits farther back with the 72 BB mounts?
This was the only thing I didn't mock up since I was using stock parts and it seems to have bitten me.
MARQ
Build Thread
Old 02-25-2011, 12:48 PM   #4
cdowns
cdowns's Avatar
will probally b different yokes too as BB mostly used th400 and SB mostly th350 for auto trannys
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
