Old 02-26-2011, 07:50 PM   #1
rhodog77
rhodog77's Avatar
SBC Oil Sending Unit Location......HELP!!!!
Hey Guys,
Can someone tell me where the oil guage sending unit installs on a 1984 SBC.
Im pretty sure the one on top of the motor next to the distributor is the sending location for the dummy light. I think!!!! Its the one with the thread at a 45 degree angle
The gauge read sending unit is located just above the oil filter. I think!!!! Im assuming that thats the stock sending unit sticking out of the block with the 2 prongs????? What is the threaded hole above and tho the back for???? If anyone knows or can help, I would really appreciate some schooling on this. thanks a bunch.
Brian
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 02-26-2011, 09:00 PM   #2
RootBeer 6117
RootBeer 6117's Avatar
Re: SBC Oil Sending Unit Location......HELP!!!!
RH
I have used both locations for the oil sending units.We have a mechanical gauge hooked to the one next to the dist.on the 350 at school.The hole above the sending unit on the side is for the clutch linkage if you have a manual transmission. I think the two prong unit runs the idiot light on the 80's 350's.
RootBeer 6117 is offline   Reply With Quote
Old 02-26-2011, 11:05 PM   #3
rhodog77
rhodog77's Avatar
Originally Posted by RootBeer 6117 View Post
RH
Rootbeer,
thanks for the info. I got to thinking, wouldnt the pressure read the same at both the dummy location and the gauge sending location??? My dad has a 305 and he has his gauge line ran to the location on top, next to the distributor and his guage works fine. The sending unit that came with my gauge set is HUGE, so I think that I will run mine down by the filter to help hide it and hope that works. thanks again!!!!
1970 P10 Stepvan
Old 02-27-2011, 12:13 AM   #4
RootBeer 6117
Originally Posted by rhodog77 View Post
Rootbeer,
thanks for the info. I got to thinking, wouldnt the pressure read the same at both the dummy location and the gauge sending location??? HUGE, so I think that I will run mine down by the filter to help hide it and hope that works. thanks again!!!!
It should be the same and will work fine.
Old 02-27-2011, 12:58 AM   #5
mr48chev
mr48chev's Avatar
Normally one uses the hole at the back of the block by the distributor. That is the only one I have ever used.
The later blocks could be drilled for oil pressure there though. It looks like someone took out the sending unit an put in a pipe plug in the top photo and I would check that pipe plug to make sure it was tight if I didn't use that spot for the sending unit.
I checked Autozones part location thingie and http://www.autozone.com/autozone/rep...essure+Switch#
They do show two pronged oil pressure switches like the one in your photo for a lot of 79 and up engines though.
Old 02-27-2011, 01:25 AM   #6
tmoble
power to the fuel pump relay goes through that 2 prong sender. no oil pressure, no fuel. There's a bypass that gives power to the relay for 2 seconds when you turn the ignition on and all the time the starter is engaged.
tmoble is offline   Reply With Quote
Old 02-27-2011, 11:06 AM   #7
rhodog77
rhodog77's Avatar
I looked back over the autozone website and looked and the oil switches.
http://www.autozone.com/autozone/par..._105906_0_5835
The description on all the oil switches say that they will "either activate the oil light of move the gauge to the extreme." So it does sound like either location will work.
thanks for all the help guys.
1970 P10 Stepvan
Old 02-27-2011, 02:46 PM   #8
sweet70beast
sweet70beast's Avatar
I like to use the one by the dist. The one by the filter gets the oil pressure first but if there is a problem with the engine oiling somewhere in the system this port wouldn't see it. The one by the dist get the pressure last so if there is a problem it is easy to catch and shut the engine down before damage sets in.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 02-27-2011, 05:07 PM   #9
rhodog77
rhodog77's Avatar
beast,
that some good info!!! I installed the sending unit today. I went ahead and put it in the top location by the distributor. It was easier to use that location and it seems that most are doing the same.
thanks to everyone for the info and tips. hopefully this will help someone as well.
appreciate it!!!!
1970 P10 Stepvan
Old 02-27-2011, 06:31 PM   #10
Richard H.
Spanked once
Richard H.'s Avatar
Actually they are the same galley. The bottom one sometimes is used for oil temp as well.
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 02-27-2011, 07:27 PM   #11
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
True, both positions will work. However if you plan on using the one behind the dist. you might want to put the sensor in before you drop your engine in. Because you want to position the engine as far back to the firewall as possible you will find your hands are not small enough to screw it in after the engine is bolted in. I had to put mine above the oil filter. The good news is, it works just fine there.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 02-27-2011, 07:36 PM   #12
lakeroadster
I just installed an Autometer sending unit a couple weeks ago on my 350 SBC. I used the port by the distributor and ended up using a 2" long 1/8" pipe nipple and a coupling to space the sending unit up to clear the manifold.
I was able to get it installed with the motor in my '65 C10.
lakeroadster is offline   Reply With Quote
Old 02-27-2011, 11:13 PM   #13
BigJock
I've just installed my new gauges and opted for the port at the distributor,but as others have said it can be tight at the firewall.
The aftermarket sender is pretty big.
Got 'er done though.....
I'd post a pic of mine but I still haven't sussed out how too!
BigJock is offline   Reply With Quote
Old 02-27-2011, 11:39 PM   #14
Dan Bowles
AD Addict
I have the one by the oil filter for the gauge and have one up above the timing cover in the front for the power to the fuel pump. I plugged the dizzy one to clean up the top.
Dan Bowles is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
