![]() Join Date: Apr 2008
Suburban headliners
Any thoughts or experience with fixing headliners while trying to keep original appearance. Repairing the old headliner not working out very well because they are so crumbly.
I thought about abs plastic sheets and perforated vinyl headliner material. Any one try that or see it done? Haskell
68 K-20 Suburban 4x4 383 4 speed tow hooks 70 K-20 Suburban 4x4 350 TH 350 tow hooks |
Re: Suburban headliners
I am interested too! Subscribing.
Daily Driver: Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights |
I tried to fix headliners myself on many vehicles. I just wasted time and money. The bottom line is . Take it to a shop and have someone do it right. I paid 185.00 a few years ago for one to be done.
Never had a problem after that. |
That does seem like a very fair price. Less than I have just assumed.
79/78 Jimmys
in my 88 the headliner is custom
it has thin strips of wood screwed under the trim all around the roof the material is STAPLED in to it there are sections front to back sewn together
John 1976 Terry Taurus http://67-72chevytrucks.com/vboard/s...d.php?t=431859 2002 Fleetwood Prowler 1978 Suburban 4X2 - hit while parked RIPzez 1978 Olds Cutopless - CanadaDayCar http://youtu.be/DgsjkULFiHo 1978 GMC Jimmy 4X4 -350/203 NOT stock Tremclad Fire Redhttp://67-72chevytrucks.com/vboard/s...d.php?t=421767 1979 GMC Jimmy 4X4 -350/203 with plow http://67-72chevytrucks.com/vboard/s...=421767&page=2 1979 GMC Jimmy 4X2 -305/350 stockish http://67-72chevytrucks.com/vboard/s...=1#post5200107 1987 Suburban 4X4 - writeoff hit while parked RIPzez 1988 Suburban 4X4 - writeoff hit while parked RIPzez http://67-72chevytrucks.com/vboard/s...d.php?t=417457 1989 Suburban 4X2 - square igloo/SOLD 2003 Grand Am 2.2 his DD 2005 Malibu 2.2 her DD Love em low,but get me higher |
Here's my headliner i gave to a guy who's been doing interior for a million years, it was 40$ for both pieces and all i did was sweep off old crumbly glue from the original vinyl i had and he did the rest and its perfect
Thanks everybody. I have some ideas now.
TTT
any progress?
The headliner on my 1990 started sagging and I ended up replacing it myself. The end result is that it looks like a factory job. Here's what I did. I bought some headliner of the right color and dimensions from eBay.
http://shop.ebay.com/i.html?_from=R4...All-Categories Our Suburban's are very long so it'll probably take 2 pieces of the headliner material. I then scrapped the old headliner material from the headliner board. I then used contact cement to attach the new material to the old headliner board using a very large brush. The results are very professional looking and probably just like how it came from the factory.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift Last edited by Edahall; 06-04-2011 at 05:26 PM. |
![]() Join Date: Dec 2001
I like what LMC has done....they have a vacumm formed abs sheet to replace the old boards with. See page 101 on their site. this also fixes the sagging since the older fiber board is usually the problem.
yeah, those are nice, but the LMC solution will cost you $500,-...which I think is a lot.
So I am gonna try for a piece of wood against the ceiling and then finishing it of with some carpet matched to the interior color of the car.
#13 |
this page sells them at $350,-
Als in ABS....damn shame I live across the ocean from you guys. http://www.stockinteriors.com/Headli...ils_box_holder
#14 | |
I am going to go with ABS sheets and perforated vinyl headliner material. I will try to post some pics.
#15 |
![]() Join Date: Mar 2011
I found that the local fabric stores have the headliner material with the foam backing attached to it already. that what I plan to do with mine.
#16 |
I still have got to my headliner on the 68 but will still post pics using abs plastic sheets and perforated headliner material.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
