Old 03-13-2011, 07:46 PM   #1
Duramax605
Lightbulb 1971-1972 2wd to 4wd Conversion
I am looking to convert a 1971 longhorn to 4wd. Now i know most people will say to switch out the frame for a 4x4 frame but cant do that. Chevy NEVER made a 4x4 longhorn from the factory. (Actually called GM and cost me $75 for them to research all vins in that year). How difficult is this and what will i need other than the obvious 4x4 parts (transfer case, i have np205 already bolted to a np203 drive, new transmission, front leaves). This will be my first project and i'm already working on it as you can see with the transfer case. I also have a motor which should feel at home in the truck (motor that came out was a 400 sbc) I have a 406 to go in with dual predator carbs and about 3000 into the bottom end. Any help would be greatly appreciated thanks in advance guys!!! CHEVY POWER
Duramax605 is offline   Reply With Quote
Old 03-14-2011, 10:17 AM   #2
YBNORML
YBNORML's Avatar
Re: 1971-1972 2wd to 4wd Conversion
Hopefully one of the mods will move this over to the 4x4 section for you. Lots of info over there for this kinda swap.
Jason.
Please note : Any items I have posted for sale are also listed locally and listing may end at any time.
72' 2WD Blazer
99' CCSB
http://67-72chevytrucks.com/vboard/s...d.php?t=566848
Old 03-17-2011, 10:27 PM   #3
msgross
msgross's Avatar
there's one being built... look in the 4x4 build section..
find a donor truck to steal parts (axles, crossmembers, spring hanger etc..) off of
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-22-2011, 09:39 AM   #4
71veronica
71veronica's Avatar
Dieselwrencher is building one ask him
71veronica is offline   Reply With Quote
Old 03-22-2011, 09:52 AM   #5
Dunenutt
Newbee
Dunenutt's Avatar
I bought an 85 blazer for $500, and took it apart. Most of the parts "almost" bolt right in. I used everything but the 2 frame rails, and 1 crossmember. You will HATE rivets when you are done! Just bolt it back together with a bunch of 7/16" grade 8 bolts. The biggest PITA is smashing the 2wd E-brake cable pockets, where the front shackles mount.
Do a search for "Legacy build", that is my build (just a longbed, not a longhorn). Any questions, just ask, I'll try to answer, possibly with pictures.
Dunenutt is offline   Reply With Quote
Old 03-23-2011, 12:18 PM   #6
Mike C
Mike C's Avatar
The Longhorn already has 2 1/2" rear springs which helps. Not sure if all the brackets are same height as the 4x4 ones, but the other 2x4 trucks have 2 1/4" rears which make lift springs almost impossible for the back. The Longhorn frame is the same 40" width as the 4x4 trucks and not the 42.5" of the 2x4 trucks.
In the front you should be able to use spring mounts off a 4x4, just cut the rivets, and bolt onto your frame. I would tack weld the nuts to the bolts after torquing them down to act more like rivets. You will need the crossmember and braces from a 4x4 as well since the motor is mounted significantly further back in order to have a reasonable length and angle to the front driveshaft.
Sometime in the future I'll peer at my parts Longhorn frame and make sure all of the holes are already in it, but if not, they could be drilled pretty easily. Rear shackle hanger shouldn't be that much work.
A donor 4x4 truck seems the best (read fastest and most economical way) to do this. This would give you rear spring mounts as well if it turns out the 2x4 Longhorn front hangers are different than the 4x4 longbed hangers.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-23-2011, 12:22 PM   #7
Mike C
Mike C's Avatar
LOL, Plasma Cutter. I will NOT grind another rivet. This will also make eliminating the parking brake cable brackets pretty straightforward.
44 Willys MB
52 M38A1
64 Corvette Coupe
1971, 4x4, conversion, frame, longhorn
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
