Old 03-24-2011, 09:17 AM   #1
71stub
71stub's Avatar
Big Block Temperature Sensor Questions
I just swapped a454 big block into my 71. Where should I locate the temperature sending unit on the engine? (Currently it is on the drivers side head of the 73 and up motor) And what wire color/connector hooks up to the sender itself? I just bought a brand new engine harness from Brothers so I'm not sure where it goes on this motor.
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB
1967 Custom Short Fleet - 327/4spd
71stub is offline   Reply With Quote
Old 03-24-2011, 09:38 AM   #2
JimKshortstep4x4
Re: Big Block Temperature Sensor Questions
The location on the engine will be good. The small blocks have the sender on the driver's side head between cylinders 1 and 3 so the wiring should work out.
The factory wire for the sender is green.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
