Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 01-25-2011, 04:46 PM   #1
CPA-DVM
CPA-DVM's Avatar
The painting of hubcaps
So, as I get my wheels all sorted out here this spring, it comes time to deal with my rather rough looking hubcaps.
I have the four original hubcaps that my truck came with. They are chromed and should look like the top two. As you can see the other 2 don't. The chrome is still nice on all four, and since I need to refinish half of them, I figure I might as well do all four.
How do I go about doing this? I don't have a lot of painting experience.
I figure I can tape off and mask and then rattle can, but I don't anticipate that holding up very well. I have seen alot of really nice looking original hubcaps on here, some painted and some chromed. I figure at least a few of you have had to do this.
Thanks for the input.
1969 C-20 Longhorn
All original - 34xxx miles
Planning a full frame off starting later in 2010 and through early 2011, and beyond...
CPA-DVM is offline
Old 01-25-2011, 11:28 PM   #2
oem4me
oem4me's Avatar
Re: The painting of hubcaps
You asked, so here goes. I restored a set of similar caps a few years ago, and went all-out for a FACTORY look. They came out spot-on perfect, but it was a bunch of work.
1st, start with straight set of hubcaps and polish them up good. 2nd, take molds off a good cap using body filler and mold release. 3rd, shape your molded "plugs" to exactly fit what you DO NOT want to paint. Saw, sand, file, or do whatever works for you to get just the right fit. Plan your painting in stages, and create plugs for each stage or color.
4th, clean the metal well and paint away with good quality paint. Rattle cans are fine provided it's good paint and the tip atomizes well. You can soak the can in hot water to warm the paint and increase pressure if needed. A heat gun works too, but don't over do it.
Next, enjoy hubcaps that don't have hard or crooked tape lines and display just the right amount of factory paint "bounce" on the edges.
like I said, it's a bunch of work.. so you decide how you want it to look.
oem4me is offline
Old 01-26-2011, 05:50 AM   #3
Sicklajoie
The Niner
Sicklajoie's Avatar
I've read this three times. You lost me after the polishing part...
"A good racer is one whose head is in communication with his balls." - Richie Evans
"There was only one place you'd find Cale Yarborough's name toward the back: The phone book." - Mike Joy
1969 C/20 Custom Camper - Hugger Orange
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: http://www.hotrod.com/cars/featured/...et-c20-driven/
Sicklajoie is offline
Old 01-26-2011, 08:40 AM   #4
cdowns
cdowns's Avatar
i'd tape off what you want to b chrome then steel wool to remove old paint and prep for painting/ remove the tape/wipe down with wax&grease remover then retape and paint with quality rattle can paint remove tape polish chrome and call it good to go
cdowns is offline
Old 01-26-2011, 10:43 AM   #5
oem4me
oem4me's Avatar
Sorry, let me try again. If you cover the hubcap or just part of the hubcap with a mold release and then smear a medium thick coat of body filler over that area, you can pop the hardened blob of filler off and have a perfectly formed "plug" to cover the area you do not wish to paint, but you must first carefully define the edges of the plug by sanding and shaping the rough blob. You then have a pre-formed "mask" that can be used a hundred times with no taping and better results. if you make the necessary plugs for each stage or color of paint, you can paint all four (or more) hubcaps perfectly in the time it would take you to do one poorly by using tape.
does this make sense?
oem4me is offline
Old 01-26-2011, 12:40 PM   #6
dougo
dougo's Avatar
I polished, cleaned the caps, then used painters vinyl tape (not wide, about 1/4, or 1/2 wide) to mask off the edges (vinyl tape is the the easiest to mask, it's flexible, and you get a clean edge), then roughen the area to paint with a course pad (3M pad), clean the area to be painted, then masked off the rest of the caps/area that I did not want to paint.
I painted the black first, let that set. Then, painted the red second. I used paint thinner around the edges of the red - a cloth, finger tip to remove any over spray (best to do this when the red is still wet). Obviously you're going with a different color, but you get the picture.
I spent a lot of time prepping, masking to get good, clean lines. I also used good paint with a good tip (rattle can). I have a local automotive shop that will mix good paint in a can, with a good tip.
I had an NOS cap to use as a reference and to also match paint colors.
So - if you want to rattle can - that's what I did. Here are the pics of how they came out.
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline
Old 01-27-2011, 11:45 PM   #7
CPA-DVM
CPA-DVM's Avatar
Thanks guys. I asked at the local NAPA and Advance and they can both match in their spray cans. As for the tape, all I can find is Frog Tape which is like blue painters tape but green and has something that leaves cleaner lines. Where do I find this vinyl tape and what does it look like? (I am picturing electrical tape and I know that's not right.)
Also should the black on these be flat and the blue gloss, cause thats what it looks like?
1969 C-20 Longhorn
CPA-DVM is offline
Old 01-28-2011, 12:54 AM   #8
dougo
dougo's Avatar
I will take a picture of the tape for you. It is a little like electrical tape, but because it's narrow its much, much easier to mask/work with. I will post pic on Saturday of the tape so you know what to look for.
Doug
dougo is offline
Old 01-28-2011, 12:33 PM   #9
dougo
dougo's Avatar
Got a lead on the tape for you....
Google: "1/4"x36 Yd Plastic Tape" (scotch makes it). You can buy it online... this is the tape you want - it's much easier to work with on masking off the lines for the black part.
-doug
Doug
dougo is offline
Old 01-28-2011, 12:47 PM   #10
cdowns
cdowns's Avatar
i'd ask at NAPA or if you have an autopaint supply store//should b abli to find 1/4 or even1/8 tape at either place// the custom painters i know dont use plastic tape for thier graphics or flame jobs
cdowns is offline
Old 01-31-2011, 01:22 PM   #11
oem4me
oem4me's Avatar
I'll put up a few pics of what I was talking about in my earlier post. Doing it this way IS a fair amount of work, but I'm a kind of nut for details like soft edges and just slightly off-registered factory production work. ....plus, I can do a million more with little effort.
Each mold covers what you don't want to paint.
oem4me is offline
Old 01-31-2011, 08:17 PM   #12
67swb72klb
67swb72klb's Avatar
think the tape u are talking about is called fine line tape
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline
Old 03-27-2011, 06:40 AM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'd consider powdercoat instead of paint for durability.
Kevin -
My Instagram
Tx Firefighter is offline
Old 03-28-2011, 01:00 AM   #14
slikside
slikside's Avatar
Not to hijack, but I keep hearing about powdercoating and 2 things come to my mind since I'm not all that familiar with it
1) Since these caps "pop" on to secure themselves to the rims, won't the powdercoating chip off when you need to pop the caps on and off to remove wheels??
2) Even if you p.c., won't you still have to paint the details to make it look stock ie, colored bowtie, and black cog appearance??
slikside is offline
Closed Thread
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
