Old 03-30-2011, 02:29 PM   #1
unclemnstr1965
6 lug to 5 lug rear axle swap
can i put 1971 5 lug rear axles in to my 1965 chevy c-10? i see on napaonline.com they have an axle set with bearings and seals for $174.00. all the conversion kits i've seen are for 1963-1970. 1963-64 need an axle gear set as well. if the conversion works for a 1970, then why can't you just put a 1971 axles in to a 1965 rearend? any advice?
unclemnstr1965 is offline   Reply With Quote
Old 03-30-2011, 02:43 PM   #2
shortbed70
shortbed70's Avatar
Re: 6 lug to 5 lug rear axle swap
I was wondering this a while back and if memory serves me correctly(don't quote me) #1 the reason they say you need side gears is because early models ran 17 spline spider gears and #2 I believe the 71-2 axles (5lug) are wider than the 64-5-6 model rears. I know also 68-69 gmc axles are wider than 64-5-6. You might check on the "70" 5 lug axles I didn't know they had them that year.
Troy
1998 honda accord my driver (gas milage)
2007 Dodge charger 3.5L
2003 Dodge 2500 HEMI
1965 Chevy Bagged,361 sbc,comp cam 280H,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
shortbed70 is offline   Reply With Quote
Old 03-30-2011, 02:55 PM   #3
unclemnstr1965
you're probably right... i thought 5 lug came out in 1967 for some reason. guess because of the body change. thanks.
Old 03-30-2011, 03:13 PM   #4
Str8axle
Str8axle's Avatar
5 lug started in '71 as far as I know.
Str8axle is offline   Reply With Quote
Old 03-30-2011, 03:43 PM   #5
Slow Build
Slow Build's Avatar
CPP has them.
1960-64 Complete 5-lug Rear Axle Conversion, 30-3/4", kit::
http://www.classicperform.com/Store/...k/6364RACK.htm
1965-69 Complete 5-lug Rear Axle Conversion, 30-3/4",kit:
http://www.classicperform.com/Store/...k/6569RACK.htm
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
I really am slow, once I get started.
Slow Build is offline   Reply With Quote
Old 03-30-2011, 05:39 PM   #6
biohazardbill
I plan on using the following axle shafts on my 65 rear end and then getting 71-72 drums
Clicky
biohazardbill is offline   Reply With Quote
Old 03-30-2011, 08:35 PM   #7
flips72
flips72's Avatar
i just had my original 65 axles redrilled to 5 lug,drums too, just cost 80 bucks for it all. poor mans way out .
flips72 is offline   Reply With Quote
Old 03-30-2011, 09:25 PM   #8
70cst
70cst's Avatar
You are correct
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 cst two tone green, 402BB 400 Automatic, buckets, ac, am-fm, tilt, LWB, 2wd, tach, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-30-2011, 11:28 PM   #9
scrapmetalart
Junior Member
71 axles are longer than your 65 I do believe
I had my 67 axles redrilled & the center turned down for $50. using 71 & up 5 lug drums
scrapmetalart is offline   Reply With Quote
Old 03-30-2011, 11:50 PM   #10
Slow Build
Slow Build's Avatar
I'm guessing the 70 went to a 3/4" longer axles but kept the 6 lug. In 71 they went to 5 lug with the longer axles. CPP lists the 70 axles at 31.5" as compared to the 60-66 axles at 30.75".
Past GM Trucks:
Old 03-30-2011, 11:59 PM   #11
Captainfab
60-66 Nut
1970 was the transition year for the width of the rear differentials, Typically the early '70 rear differentials were the narrower version as the prevoius years. The late '70 differentials were 1.5" wider overall (.750 per side) like the '71 and up differentials. That is why you can't use a '71 and up axles in the '63-early '70 differential housing.
'75 K5 Blazer 355, T400/205, D60, 14B FF
'68 RS Camaro
'66 C10 Suburban, 454, T400, 3.42 posi., etc.
'66 C30 cab and chassis, factory AC
'66 C20 former dd
'63 C10 Suburban, future 4x4 project
'63 C10 swb, future pro street project
'63 C60 292, 5 spd,2 spd rear,cab and chassis
Impala SS Rear Disc Brake Brackets For Sale HERE Camaro Calipers HERE D52 Calipers HERE
http://www.dragtrucks.com
Old 03-31-2011, 08:41 AM   #12
mater63
mater63's Avatar
why dont you just switch the whole housing with axles ? that's what i did on my 63. I took a rear end out of a 72 1/2 ton it bolted right up.
mater63 is offline   Reply With Quote
Old 03-31-2011, 08:55 AM   #13
biohazardbill
Some people need the more narrowed axles for our drops/tire size
Old 04-01-2011, 06:55 AM   #14
63sbssbbw
UCA63
63sbssbbw's Avatar
Yes,that and try to find a '71-'72 5 lug that isn't 700 miles away LOL
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 04-01-2011, 07:35 AM   #15
taank
Why not run the 6 lug?
taank is offline   Reply With Quote
Old 04-01-2011, 07:42 AM   #16
biohazardbill
Alot of people like 5 lug for more wheel choices.
Old 04-01-2011, 10:44 AM   #17
jimmydean
jimmydean's Avatar
Is it really that cheap? I need to call around!
Captainfab, I have a '66 C10 rear. If I have the axles redrilled, could I use one of your disc conversions? I would like to use the Camaro caliper with built in e-brake.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-01-2011, 10:49 PM   #18
Captainfab
60-66 Nut
Yes you can use the Camaro caliper brackets with redrilled axles, but you would need to have the center register turned down to about 3.06" You know I do have the 6 lug rear disc brackets that utilize the Camaro calipers with a 13" rotor. The drawback to those is that you will need a 16" or bigger wheel.
'68 RS Camaro
'66 C20 former dd
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
