Old 03-31-2011, 02:34 AM   #1
Dino Driver
Dino Driver's Avatar
1960 Chev build.....slow build.
Fresh out of the Marines in 1989 I decided I wanted to build a truck. I learned how to drive in a relatives 1965 Chev P/U back in Nebraska when I was 14. We were miles from anywhere and had been driving for over 30 minutes. My cousin points a well worn white truck in the field and says drive it home and don't kill it cuz you probably won't get it started again, oh, and I hope you remeber how to get back beings that it was my first time in that place. That was a start of a love affair with 60's vintage trucks! When I bought this truck I thought it was the coolest thing around and now I look at the pics and wonder what was I thinking!
Dino Driver is offline   Reply With Quote
Old 03-31-2011, 09:27 AM   #2
CVA59
Re: 1960 Chev build.....slow build.
It still is a cool truck. All these old trucks are cool to me no matter the condition. I guess they are like a fine wine, just get better with age.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 04-01-2011, 12:24 AM   #3
Captainfab
60-66 Nut
Welcome to the forum
What are the plans for your truck?
Old 04-01-2011, 01:32 AM   #4
Dino Driver
The first set of pics I put up are from 1989. He looks great after 2 days of scrub brush and elbow grease. A friend knew I was looking for a truck of this era and called me late one afternoon telling me he found one but we had to move quick. We got halfway out to the guys place when we saw them on the road, pulling it with a rope. Apparently the owner of the property told the guy to get rid of the truck that had been sitting under the cedar tree for 6 years. I ended up getting the truck for a $100 but I had to take over duties as the pilot. My neighbors were not happy with me, nor was my father, who told me I could not park it on the property. It took me a couple of weeks to sort out the electrical problems and with the help of a neighbor we drug the truck around the neighborhood while I dropped the clutch to get it started. It would not start by cranking the starter. It had a 235, 6 cylinder which didn't take long for me to find it was really tired. After doing some background checking I found that the second owner of the truck was a friend of mine from bowling. The guy I got the truck from never registered it and only bought it for the tires he never used and were by then, cracked out. So I am the third owner. In the glove box was every registration ever put on the truck, including the temp registration from when they drove it off the lot brand new!
Old 04-01-2011, 02:08 AM   #5
Dino Driver
After some research I proceeded to get a mouse motor (283) as my first build. It came out ok but I knew this was not the last motor I was going to put into the truck. My first mistake was to ditch the 235 6 cylinder. I had all original parts and accessories as the pics above show, I even had the toilet paper oil filter and oil bath air filter.
Old 04-01-2011, 09:13 AM   #6
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Great Truck!! Semper Fi!!!
LeftCoast32 is offline   Reply With Quote
Old 04-06-2011, 09:17 AM   #7
structures
structures's Avatar
Nice truck keep us up to date.
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 04-22-2011, 02:49 AM   #8
Dino Driver
After looking at my poor truck outside, covered with snow I decided to get back to working on it.
Old 04-22-2011, 02:54 AM   #9
Dino Driver
After taking most everything apart I found my job was going to be more difficult than I expected. The rusty floors got more holy!
Old 04-22-2011, 03:00 AM   #10
Dino Driver
I'm glad there are a lot of options for tins but some things weren't available when I started so I had at least one difficult panel to make from scratch, drivers side footwell panel.
Old 06-24-2011, 12:26 AM   #11
Dino Driver
Getting some sheet metal progress.
Old 06-24-2011, 12:49 AM   #12
Dino Driver
I found a guy who had the small hump peice for what I thought was cheap. Once I got the engine and tranny I wanted I wasn't sure the small hump was going to fit anymore. I am putting a 1964 frame under my 1960 cab and to see if the small hump will work I had to cut the front cab mounts off and weld them onto the '64 frame.
Old 06-24-2011, 12:53 AM   #13
Dino Driver
Doing the layout turned out to be interesting. I took a bunch of measurements from the donor 60' frame before cutting the cab mounts off and I verified the my measurements with the factory assembly manual...they don't match. fortunately the measurements between the 2 frames do so I went with my notes.
Old 07-04-2012, 03:27 PM   #14
Straw Rube
Straw Rube's Avatar
They do look like brothers!
http://67-72chevytrucks.com/vboard/s...d.php?t=495311
1960 Chevy Apache C-10
2006 Chevy Pickup K-20
Straw Rube is offline   Reply With Quote
Old 08-25-2014, 11:44 PM   #15
Dino Driver
I spent a good portion of a day going through Modges build and looking at updates of Bomp's build. Modges talks about the death of a thread and he's right on the money. I have pushed my truck around the garage for better than 2 years, mainly because I have a new lady in my life. Fortunately she and her 17 yr old son are into trucks as well so that removes one bad thing from the Modge list. I have a bunch of work to redo since I was impatient and didn't do things correctly. The that gets me the most is the floorboard I did with the rocker panel out only to find I shrunk the floor by 1/4" and the new rocker won't fit on. In one of my sessions to teach the youngin about cars/trucks we got onto the subject of differentials and drive lines. The video was incredible but it didn't cover a couple of things. They say that if the output of the tranny and the input of the Diff are at different angles that portions of the driveline will travel faster than others. So my question is, if you have a slip joint on a 2 piece driveline does this problem go away? With the setup I have going I think a 1 piece driveline is out.
Old 08-26-2014, 05:47 PM   #16
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Talkin' bout me & Bomp behind our backs eh? LOL!
THANKS ALOT!
I think that what you are referring to in regards to the driveshaft angles is...Now let me see if I can explain this properly...If the tip angle from your transmission to the driveshaft is at 5 degrees downward, then your tip angle from the rear-end to the driveshaft must also be at 5 degrees but upward, otherwise it can create vibrations or premature wear on the u-joints.
The angles must match each other.
To be honest, I have no idea what the advantages are with a 2-piece driveshaft...Except more u-joints to replace. LOL!
I see no reason that you cannot use a 1-piece driveshaft!
Modges'66 is offline   Reply With Quote
Old 08-26-2014, 07:00 PM   #17
1963c-10
Post Whore
1963c-10's Avatar
Glad to see the build back under way!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-26-2014, 09:52 PM   #18
Dino Driver
The driveline issue came up because of this corny trainer video: https://www.youtube.com/watch?v=T4P75ZQvpws
Modges: Nice skills! Body work is my downfall....might have to destroy some panels before I figure it out.
Thanks for the support 1963c-10!
Old 08-26-2014, 09:53 PM   #19
pdxhall
pdxhall's Avatar
Hey fellow Portlander. When you said slow build you really meant it. It's good to see you back at it. Good luck.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-23-2015, 09:19 PM   #20
Dino Driver
I was finally able to find a nice bed for my truck for a good price. Met LT1 Burb and he is a well skilled craftsman! Unfortunately he informed me that the low hump weld in panel will not work with the 4L80E tranny I have so I have to find another bolt in high hump panel since I got rid of the original one already.
Old 05-16-2015, 08:22 PM   #21
Dino Driver
So, along with finding out that I got rid of a part I now need to replace I decided to start fixing floor/sill on drivers side....again. Not liking making mistakes. Also in need of information about steering columns. I would like to retail the stock column which needs to be rebuilt but also would like to convert from 3 speed to automatic. Anyone in the Portland Oregon area know of a qualified shop?
Old 05-17-2015, 01:21 AM   #22
Captainfab
60-66 Nut
I seemed to have missed this before....what can you tell me about the engine mounts you are using? I recognize the frame brackets and the engine mount itself, but not the piece on the block.
Old 05-17-2015, 02:16 AM   #23
Dino Driver
The engine mounts came as a kit from EC. They are work nicely but template would have been beneficial.
Old 05-17-2015, 11:15 PM   #24
Bomp
Bomp's Avatar
Glad you are back at it. Like how you're willing to go back and re-fix things. Glad to know Im not the only one so picky.
Bomp is offline   Reply With Quote
Old 03-17-2016, 03:55 AM   #25
badherb
badherb's Avatar
Cool Re: 1960 Chev build.....slow build.
a little more specific please. I have an LS and the mounts I used are a cobble of different items. those look very sharp! are the perches from a 70s chevy truck? Thanks keep up the good work!!!
badherb is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
