Old 04-01-2011, 12:20 PM   #1
HillfromTn
HillfromTn's Avatar
swapping a 350 for the tired inline 6
New guy question. Looked through the forum and didn't find the answer, so here goes. What do I need as far as motor mounts to swap my inline 6 with a sb 350? I can fab a crossmemeber for the turbo 350 trans and run an aftermarket shifter so that's not a problem. Thanks, Doug
HillfromTn is offline   Reply With Quote
Old 04-01-2011, 11:59 PM   #2
Captainfab
60-66 Nut
Re: swapping a 350 for the tired inline 6
What year of truck and which 6 cylinder? If you have a '63-'66 with a 230/250, you don't need to change anything. Just get new motor mounts, bolt them up to the 350 and drop it in. You might be able to remover the mounts themselves from the 6 cyl brackets, but I can't say for certain. If you have a '63-'66 with a 292 6 cyl then you will need at the least a passenger side frame bracket, as the 292's had offset motor mounts. In the '63-'66's the 230/250 6 cyl and the V8's used the same motor mount brackets and in the same location.
If you have a '60-'62 and want to install a V8, you can use the V8 motor mount brackets from either the '63-'66's or the '67-'72's. But you will have to add a filler piece on top of the frame as the '60-'62 frames are shorter in height. The '67-'72 small block brackets would be a closer fit than the '63-'66's
If you have the '63-'66, there is no need to fab a trans crossmember. Just get one from a '63-'87 truck with an auto trans, slide it in the frame, drill some holes, and bolt it in.
Old 04-02-2011, 12:02 AM   #3
GMC4wheels71
For curiosity's sake, what's wrong with the 6 to make it "tired"? Those engines would run till the cows come home.
GMC4wheels71 is offline   Reply With Quote
Old 04-02-2011, 01:48 AM   #4
rbar
rbar's Avatar
It's been since 1988, but when I pulled my inline 6 out of my 66 and put in a 327, I didn't have to get anything for it. The six cylinder had three pieces to the motor mount, you just pull out the middle piece and it's a match. The clutch linkage had an extra piece reaching to the block that I just had to remove, and the bell housing all mounted up the same. I am fairly sure I didn't have to do anything with the throttle linkage either. My 6 was a knockin' and I was 18 and wanted a 327.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 04-03-2011, 02:30 AM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: swapping a 350 for the tired inline 6
I'm looking for all the mounting hard wear for my 1972 nova 250 inline 6.
I miss not seeing the inline 6 in trucks.Every time i go looking at trucks they have V8 or big blocks.
Now days with gas getting up there the 6's are starting to come back into fashion.Slide a 700R4 with a offhandhouser intake with a 4 bb carb and your done.
Here is the picture of the inline 6 i need the frame mount and the mounts on the block .I have a 1968 longhorn that had the 396 with 400 with Air and power steering Looking to convert it over to 1/2 ton with front disc brakes.
I'm looking for the AC ( air conditioning ) brackets as well for the inline 6 250
stsalvage is offline   Reply With Quote
Old 04-03-2011, 03:03 AM   #6
murdoc
murdoc's Avatar
fine looking 250 man! good luck finding all the a/c brackets for it. I myself have been looking for the same for years. If you run into a pile of em some where be sure to let me know, I'll do the same for you
murdoc is offline   Reply With Quote
Old 05-05-2011, 05:07 PM   #7
Real_McCoy
Real_McCoy's Avatar
Don't mean to highjack the thread, but kind of related...
I am picking up an I6 this weekend. The guy is not sure if it is 250 or 292, but is from a mid-80s p/u.
I have two 66 LWB C10s.
One has an I6 already with a 3 spd. It has a blown head gasket.
The other has no motor or tranny. It has dual exhaust and was set up for auto transmission.
I have a THM350. Don't know if it is good or not. It was one my step-dad had when he passed away. It was in the shed behind the garage and no one knows anything about it.
Can I mate the I6 with the THM350? Does it need to be long or short tail shaft? Will the crossmember from earlier mod support this setup assuming previous setup was a 350/350?
I want to get the second truck running so I can get the inspection done and get it titled before I sink a large sum of cash into it. If I dont put this in the white truck, it will replace the engine in the red with the blown head gasket.
Thoughts? Comments?
Thanks in advance.
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline   Reply With Quote
Old 05-05-2011, 06:13 PM   #8
lakeroadster
Originally Posted by stsalvage View Post
Now days with gas getting up there the 6's are starting to come back into fashion....
I really like straight sixes too, but its a common misconception to say that your truck will get better gas mileage with a straight six vs. a V-8, especially a bone stock 6. Their mileage was pretty awefull. I drove a 230 I-6 with a monojet carb for 15 years. Super dependable, but not good mileage.
Dollar for dollar V-8 components are less expensive and more available, rebuild costs are less and if you look at the total package the V-8 saves you money once you add up all these costs.
And for resale, more people want the V-8, that's a given. Look at this poll: http://67-72chevytrucks.com/vboard/s...d.php?t=459050
That being said if you want the straight six go for it. And I am not saying you can't go with aftermarket carb's., aluminum intakes, exhaust headers, 6 speed overdrive trannies and highway gearing to squeeze out better mileage. Point is if you look at the total build cost, the V-8 is the most economical choice for a truck that will be used as a truck.
That's pretty much why V-8's are still being sold in trucks today, and straight 6's aren't. It is also why there is a > 4:1 ratio of people on this board with V-8's vs. I-6's.
lakeroadster is offline   Reply With Quote
Old 05-05-2011, 06:24 PM   #9
kieth
kieth's Avatar
We used motor mounts from a 91 burb and had to notch the frame on my 66 gmc, they did not just bolt in. after notching the frame flange everything worked very well, we had no issues with the distributor (had to notch the frame slightly for headers.
Here is a picture scroll thru to see the final result. The holes in the front crossmember had to be redrilled also.
http://kieth.smugmug.com/Trucks/66-G...305_KyUKk-A-LB
Kieth
kieth is offline   Reply With Quote
Old 05-05-2011, 07:42 PM   #10
slepysal
slepysal's Avatar
My 250 has , long tube headers, an Offy intake with a 2bbl 350cfm Holley and runs great. But Lakeroadster is spot on about the gas , the lil six is thirsty !
The hop up parts are expensive not cheap but diffrent
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Headers with dual exhaust and bellflower tips. 3 speed on the floor and finally power disc brakes !
"Excuse the chips,dents and scratches, I drive my truck."
slepysal is offline   Reply With Quote
Old 05-05-2011, 09:52 PM   #11
enick72
enick72's Avatar
I like my I6 but my fuel milage sucks. I already added a T5 and I'm sure that I could do a few more things but I have a tuned port L98 to drop in place. I figure the V8 will work less and with fuel injection and driven correctly it should be quite a bit better. I'm glad you asked the question because I was just about to start searching.
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 05-05-2011, 10:54 PM   #12
Rich 5150 69
Rich 5150 69's Avatar
A stock 350 with a quadrajet, dual exhaust and a 700r4 or even a turbo 350 will get better MPG that a six. just because of the torgue factor. we are pushing 3800 lbs plus guys.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-06-2011, 12:44 AM   #13
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Put a Pontiac motor in it and you'll have all the torque you will ever want and more.
It's a bolt in.
Then again, you could do what everyone else is doing....
Chris from lovely Downtown Apache Junction AZ.
Master machinist
Advanced fabricator
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 GMC Dually construction on hold
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID RA-V 2X4 fed 1200+ HP Pontiac
Soon to be the fastest Non-Chevy Powered Super truck in the South West U.S. and Maybe even the world... Buhhhwwaaahahahaha...
66-PMD-GMC is offline   Reply With Quote
Old 10-23-2011, 08:30 AM   #14
rockdogg2020
Here is where you can find ac brackets for the six. http://www.oldairproducts.com/catalo..._69000008.html
rockdogg2020 is offline   Reply With Quote
Old 10-19-2015, 01:18 PM   #15
curvedglass
It's a bolt in.
Speaking of different -
Would an Olds 403 bolt up? I have a 300hp Mondello 403 with a TCI Streetfighter 200R4 in another car that I wouldn't mind tearing down for my truck.
I like different. that is why I drive a 52 year old truck as my daily driver!
curvedglass is offline   Reply With Quote
Old 10-19-2015, 05:39 PM   #16
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I did find a few threads :
Copy and paste this in your Internet address bar.
"Olds 403" site:67-72chevytrucks.com/vboard/
66 Service truck build:
Old 10-19-2015, 11:07 PM   #17
66-PMD-GMC
66-PMD-GMC's Avatar
I had a 79 GMC with a factory olds motor.. absolute bolt in..
Master machinist
Advanced fabricator
Projects..
Old 10-20-2015, 09:53 PM   #18
Monte's62
HillfromTn, I don't know if this will help you but here is a pic of the mounts I have in my 62 running a 327/350 combo. Notice the crossmember was cut out.
Monte's62 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
