Nobaddaze's 82 C10 Cruiser Build
Ok I guess its time to start a build thread on my new project. I came across this pickup through a buddy and decided to go for it. Its an 82' short bed with stock 350 and turbo 400. The object is to build a nice c10 thats not too over the top but I will still enjoy. I started the truck in the summer of 2010. so here goes...
The day I took it home... ![]() ![]() Starting teardown with some new shoes! ![]()
Re: Nobaddaze's 82 C10 Cruiser Build
More Teardown
![]() stripping out interior. thought this might be a nice touch... ![]() PST Polygrafite suspension kit
Picked up a front clip from 79' because i like it a whole lot better. Got off of craigslist for 60 bucks...
![]() Created a template from posterboard to shave firewall... ![]() Stripping firewall to prep for some "shaving" ![]() ![]()
SHAVED
Just the way i like em...I left the stock junction block for harness for ease on reassembly. but i did eliminate the section where e-brake cables and speedo cables come through to clear my tires.![]() Replaced fromt driver rocker corner due to rust damage. I used an LMC Rocker panel. not sure how happy i am with the part but you wont see anyways... ![]() When i tried to shift out or park for the first time i about ripped the shifter mechanism out of the floor (wood screws holding it in) so i waterjet out a sandwich plate setup out of .125 mild steel and welded bottom plate to underside of floor.
closed up with a little mud
![]() Belltech Flip Kit with c-notches welded in ![]()
and sadly here is how she sits right now.
![]() Plans are hopefully to new a newer gen gm motor. got my eyes on a 6.0. Fire engine red paint. clean stock interior. then go cruizin ![]() ![]() ![]()
Nice work so far
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 73 Factory BB SWB 2WD -- The Slow Build 90 K2500 Suburban -- Stock for now 77 Scottsdale SWB 2WD -- SOLD "I'll miss ya ol yeller" 01 HD FLHR 97 HD XLH -- SOLD |
![]() Join Date: Dec 2010
Looking great man! Keep up the work & keep posting new pics!!!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
![]() Join Date: Jul 2010
You stole that clip....nice work sofar
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
thanks guys...now its up to my wallet to determine whats up next
Good to see you finally started a thread! I know you got all this talent hidden inside now its just a matter of time and money! it will be bithcen for sure!
ohh yeah thanks for the wheels you'll never get em back! hahaha |
small update today. frame is off to gorilla industrial coatings for a "lava black " powdercoat job. Included all springs, steering arms, and misc brackets. my brother used this company and color on his 68 chevelle frame and it turned out amazing.
i cant wait. usually takes about a week to get back.![]()
#13 |
Great start man
Posted via Mobile Device |
#14 |
looks like a great start so far!.....nice hauler too!
#15 |
Nice start!
I like the dolly you used under your crossmember.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030
#16 |
thanks! that dolly has saved my back countless times now.
#17 |
so a small update today. met a guy on craigslist ended up trading an old set of hedman hedders and 80 bucks for a complete shortbed. bed has dual tank fuel doors, no rust, and the best part is its strait with no bondo. no pictures yet. This new bed saves me a ton of time because my old bed needed some serious work, someone used fiberglass and a gallon of bondo to do some repairs before i got it.
#18 |
![]() Join Date: Apr 2009
u stole that
#19 |
nice work
#20 |
sweet! nice deal! I noticed you still have a dirt tire on..... sunday???? hhhhmmmmm???
#21 |
BMFP-im going camping with elaines friends this weekend. im definately itchn to go though.
on another note- i got the new bed torn apart, my old bed torn apart, layed all the parts out on my lawn and picked the best pieces from both beds and made a frankenstein bed that is pretty much ready for final body work. then i got rid of all the spare crap that i had laying around through craigslist and the scrap yard. now my garage and side yard is nice and clean!!! Hopefully my frame is coming back sometime this week and i can start the actual "build" process of this truck!
#22 |
Nice!
#23 |
WOO HOO!!! My frame is done at powdercoat and it looks awesome. cant wait to get it home and start to put her back together!!!!!
#24 |
Rad!
#25 |
here is a question for some of you "guru's" out there. when i went to pull my cab off, 3 of the 4 mounting bolts ended up stripping on me. my front drivers bolt is seized. the two rear bolts just spin and i can hear the nut inside my cab spinning. so i ended up just cutting them off with the sawzall through the mounts. so now i have about 1.5 inches of seized bolts sticking out of my mounts. any ideas on how to fix it?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
