Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 04-15-2011, 09:05 PM   #1
Newtz67
Newtz67's Avatar
Newtz '68 Burb
So we went ahead and picked this up today! Always wanted one, finally got one!
Newtz67 is offline   Reply With Quote
Old 04-15-2011, 09:15 PM   #2
dougo
dougo's Avatar
Re: Newtz '68 Burb
Nice burb and congrats! Any plans to make changes? Love the white walls.
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
Old 04-15-2011, 09:23 PM   #3
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
For now leave as is. Except for the interior which needs a lot of clean up. Mostly we will just clean it up and cruise for now. And thanks btw!
Old 04-15-2011, 09:30 PM   #4
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
I just dropped this thing in my driveway a couple hours ago. I haven't traced it out yet but there there is a handle below the dash just to the right of the steering wheel that says overdrive. Is this for real? It has the original 292 with the three on the tree. If so, how does this overdrive work with the tranny? Thanks.
Old 04-15-2011, 11:20 PM   #5
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Newtz '68 Burb
When you do trace it out, TAKE PICTURES!!!! There have been after market overdrives available since fifties (maybe earlier?) I know that some 4x4s with the t-18 had an overdrive that bolted on
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 04-16-2011, 12:22 AM   #6
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Right on, I will! I'll take some pics tomorrow.
Old 04-16-2011, 12:47 AM   #7
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Newtz '68 Burb
sorry, dana 18... not t-18... correct me if I am wrong. I am thinking of scouts and willys
-Jeremy
Rebuilding an NP205
Old 04-16-2011, 01:19 AM   #8
C/10 King
C/10 King's Avatar
Re: Newtz '68 Burb
Wow Newt, that's gonna look good in my yard.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 04-16-2011, 01:31 AM   #9
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: Newtz '68 Burb
Welcome to the club! We need more pics!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 04-16-2011, 10:55 AM   #10
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Yes sir, yes sir!
Old 04-16-2011, 10:57 AM   #11
vectorit
What?
vectorit's Avatar
Re: Newtz '68 Burb
Congratulations!
From what I can see in the pic, it looks like it is still pretty solid.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-16-2011, 10:58 AM   #12
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Here ya go.
Old 04-16-2011, 11:01 AM   #13
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
A few more.
Old 04-16-2011, 11:06 AM   #14
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Originally Posted by vectorit View Post
Congratulations!
Thanks! It is pretty solid. It has some rust in the normal areas, rockers, kick panels, etc... The body is very straight, except for the one back door, although it has been repainted once, so you never know whats hiding.
Old 04-16-2011, 11:23 AM   #15
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
SPID. A po glued carpet to the whole interior. Any good ideas for getting the glue off? It is pretty dried out, maybe just some hot water and a rough sponge or something...
Old 04-16-2011, 12:07 PM   #16
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Newtz '68 Burb
Check hardware stores and carpet stores... they may have a solvent that works. Should be paint safe. You can also try bug and tar remover. that stuff looks too spread out to try elbow grease and scraping.
-Jeremy
Rebuilding an NP205
Old 04-16-2011, 12:09 PM   #17
71gmcburb
71gmcburb's Avatar
Re: Newtz '68 Burb
i' try a heatgun to try and release the adhesive if thet doesn't work then use a puddy knife, utility knife and elbow grease once the garpet is off use Goop off to get rid of the remaining glue
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 04-16-2011, 01:10 PM   #18
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Thanks guys!
Old 04-16-2011, 02:36 PM   #19
vectorit
What?
vectorit's Avatar
Re: Newtz '68 Burb
I have good luck using these on various stuck on stuff.
Gum Out carb cleaner, and Goof off bug n' tar remover.
I'd start out mild, such as hot water and soap. Then, step it up gradually with various brushes and scotch brite pads.
When you decide to go with the harsh stuff, start out on a spot that is out of site.
I've also removed dried up glue like that with a fine wire brush on a drill, just go along very lightly so as to not damage the paint.
All depends on how dried up it is, crustier the better since it will flake off. If it's still gummy, then you are in for more elbow grease.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 04-16-2011, 03:29 PM   #20
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Thanks Vectorit. Ya it's pretty dry. Hopefully it's not too bad.
Old 04-16-2011, 07:13 PM   #21
CG
BlahBlahBlah
Re: Newtz '68 Burb
Ive had a 67 with overdrive and I have a 69 right now with overdrive. The 67 handle was chrome and said overdrive across it and the 69 handle is black plastic and it says overdrive on it.
I dont remember for sure but I was thinking the spids on them both said overdrive.
Monroe Swap meet May 18-19.
Mike has the same spots for the NW guys he's had forever.
Lunch time BBQ at the spaces.
If you have stuff to sell bring it along.
If you have a question PM stllookn (Mike) here via the board.
https://67-72chevytrucks.com/vboard/...d.php?t=851291
Old 04-16-2011, 10:33 PM   #22
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Newtz '68 Burb
I really want to see pictures of that OD!
-Jeremy
Rebuilding an NP205
Old 04-16-2011, 10:49 PM   #23
C/10 King
C/10 King's Avatar
Thumbs up Re: Newtz '68 Burb
Newt, I love the photos, if you want some stock hub caps give me a call.
C/10 Rene
1971 Short Fleet
Old 04-16-2011, 11:36 PM   #24
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: Newtz '68 Burb
Very nice Newt. BB plans in the future?
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 04-16-2011, 11:37 PM   #25
KevsClassics
TILT COLUMN GURU
Re: Newtz '68 Burb
68??
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
RIP EL JAY
Thread Tools
Display Modes
