04-15-2011, 11:43 PM | #1 |
New harmonic balancer, timing mark wrong - '63 Chevy 230
Hello all,
I replaced my original harmonic balancer on my '63 230 because I suspected the rubber connecting the inner harmonic balancer to the outer pulley was rotted and had caused the balancer to spin, causing the timing mark to be off. I had read this happened to others. Upon closer inspection the rubber was badly rotted, cracked and dried out. When I used a timing gun on the original balancer, I couldn't get it to appear in the right spot next to the advance marks on the motor, however, I was able to find it on the passenger side of the motor at nearly 90 degrees advanced shown on the timing gun. Something was clearly wrong. I ordered a new balancer from Damper Doctor, and after installing it, it appears the timing mark is still way off. I can't get the timing mark to appear in the right location until 70 degrees advanced on the timing gun. I was going off the #1 spark plug wire, fyi. I suspect that the new balancer was not assembled correctly, and the timing mark is still off. Quality wise the rebuilt balancer looks great. However, since the balancer can only be installed one way (because of the keyway on the crank), I can't imagine I could have installed it 'wrong'. The truck runs great, I've set the timing the old fashioned way, by sound and feel, but I'd like to get the timing perfect with my timing gun. Any suggestions? Ideas whats going on? Am I just going crazy?
1963 Chevrolet C10 Stepside 1972 Pontiac GTO 1998 Dodge Viper GTS 1999 Jeep Cherokee XJ 2018 Chevy Camaro ZL1-1LE It's never too early to beef up my obituary |
04-16-2011, 07:24 AM | #2 |
Re: New harmonic balancer, timing mark wrong - '63 Chevy 230
You probably have the 'wrong' balancer. You have a late model set up for a timing probe, the timing tab shifted at some point in the L6's life IIRC.
Two options, call Damper Doctor and see if you can get the 'correct' one, swap them. Second, and more quick and fun, find TDC using a stop thru the plug hole, scribe a mark on the balancer at '0' on the timing tab. Then you know it's right. At the same time you can mark the inner to outer ring so you can check for slippage in 100,000 miles or so.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
04-16-2011, 10:32 AM | #3 |
Active Member
Unless you are a stickler for having the exact balancer you can make a mark with a perm marker, scribe or a timing tape on yours as D13 mentioned.
http://www.summitracing.com/parts/MSD-8985/?rtype=10 |
04-17-2011, 02:31 AM | #4 |
Thanks for the responses. I definitely don't want to have to replace the balancer again, and the new one I have is in perfect shape, except that timing mark is off.
So I think I'll just go with your suggestions, and find TDC of the #1 cylinder, and then place a mark in the appropriate spot on the balancer. Also, placing a mark to check for balancer slippage in the futre is a good idea, and something I didn't think of. Thanks!
04-17-2011, 07:57 AM | #5 |
a custom pointer can b made in a short period of time with some imagination and fabrication skill
