Old 04-17-2011, 04:48 PM   #1
Foosified
Foosified's Avatar
SBC 350 Engine Backfire Through Exhaust and Carb
1979 350 block stock crank, pistons, rods. New rings and seals.
I added;
- Vortec heads stock other than new valve springs to allow for larger valve lift on vortec heads from Alex's Parts http://www.alexsparts.com/products/V...YD-ROLLER.html
- Howard's cam and liter kit 110991
.470 lift on int.and exh.
284 deg of duration
108 lsa
- MSD HEI ingnition
- new plugs and wires
- flotech headers
- Edlebrock Performer RPM intake
- Edelbrock 1406 carb
Let me know if you need to know any other info on the engine.
timing is at 12 deg adv.
compression is 155 - 165 psi (checked cold)
Backfiring happens on start up fast idle. Wife says it sounds like a popcorn machine. Pretty sure it is happening on both sides of the engine.
When I kick it down the popping stops, but when I rev up to 1700 - 2000 it comes back and if I hold it and then burb the throttle it sounds like I let off a round from a shotgun.
I have quadruple checked the lifter/rockers for overtightness. 100% sure that is not the problem. I have checked for vacuum leaks everywhere and cannot find any.
Not sure where else to look other than the POS carb, which is a couple years old, but has only seen maybe 5000km's. I had it on this same engine before all the add ons and while it was never tuned up as good as it could have been the previous set up never had a backfire through exhaust issue only the ocassional through the carb. It definatley could use some fine tuning, but I'm not sure if that is what would cause the backfire through the exhaust.
The second issue is the backfire through the carb. This I understand occurs beacuse of a lean condition, correct.
I'm at a loss. i have checked everything I could think of and researched. The only thing I have left to do is take it to a mechanic and bend over while I pull my pants down.
I'm about ready to put an LS motor in and be done with it, but knowing my luck I would have to show a whole bunch of loving too before it would run without issues
Any help is appreciated.
BG
May all your ups and downs be in the back of a Chevy!:
Foosified is offline   Reply With Quote
Old 04-17-2011, 05:16 PM   #2
Gumby
Gumby's Avatar
Re: SBC 350 Engine Backfire Through Exhaust and Carb
Ok what happened???
it ran fine then one day it.......
Or you got done building it up and now it don't run?
new parts aren't always good parts, only time similar was half of the pickup coil in the HEI was bad it seemed. As with a timing light all cylinders would randomly miss. It happened after a intake swap.
Ended up having one built by Dave Ray / AKA IgnitionMan
Kinda like would you buy a Microsoft or Apple computer from a store or get one hand built, programmed and performance tested by Bill Gates or Steve Jobs themselves for about the same price?
http://www.davessmallbodyheis.com/
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 04-17-2011, 05:26 PM   #3
Foosified
Foosified's Avatar
I recently built it up. I broke it in. I have't really driven because of the backfire issue and plus the fact I'm still finishing the body. I recall it backfired once in a while after the initial breakin out one side, but now it seems to have gotten worse and happens out both sides.
If it were a cam or lifter issue why would i have backfiring through the exhaust?
Originally Posted by Gumby View Post
Ok what happened???
Old 04-17-2011, 05:42 PM   #4
Gumby
Gumby's Avatar
never broke in an car engine but wiping out a cam is the biggest worry, ive seen lots of post about to much spring pressure taking them out.
but reading and knowing are two different things.
I just know Ill dread my first cam break in when ever it happens
Old 04-17-2011, 06:38 PM   #5
cableguy0
Popping through the exhaust is generally a rich condition. Raw fuel in the hot exhaust ignites and causes the popping. Popping through the carb is usually a lean condition or improper timing. Did you run a zddp additive and the proper oil during break in? How exactly did you break it in? Did you let the engine idle at all? What oil are you running now?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-17-2011, 07:18 PM   #6
shortbed70
shortbed70's Avatar
Ignition issues? Module getting weak?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-17-2011, 08:23 PM   #7
Foosified
Foosified's Avatar
I followed the cam breakin procedure provided and used comp cam breakin oil and howard's cam zddp additive. used the lube on the cam lifters etc. The oil in there now is meant for new engines, but I can't remember the brand.
Old 04-17-2011, 08:26 PM   #8
Blue Rat
Check your plugs an see if any of them are gas fouled or wet with gas. If so replace them. If you are having trouble with it starting it probably also has been getting to much fuel.
Blue Rat is offline   Reply With Quote
Old 04-17-2011, 08:28 PM   #9
Foosified
Foosified's Avatar
Ignition is all new. Doesn`t mean there couldn`t be an issue with it, but it runs fine when idling. Seems to only pop and backfire when rpm`s are up around 1700 - 2000+ QUOTE=shortbed70;4630515]Ignition issues? Module getting weak?
Posted via Mobile Device[/QUOTE]
Old 04-17-2011, 08:28 PM   #10
cableguy0
Are you using a zinc additive now? its just as important now as it was during break in.,
Old 04-17-2011, 08:31 PM   #11
Foosified
Foosified's Avatar
No trouble with starting and some plugs seem to be ok and others might have a bit of carbon built up (not a lot), so I clean and put back in
Old 04-17-2011, 08:34 PM   #12
Foosified
Foosified's Avatar
no zinc additive, but I`m pretty sure the oil I put in has some in it.
Old 04-17-2011, 09:10 PM   #13
cableguy0
Most oil does not. What kind of oil is it? IM not condemning your cam or engine at this point by any means. Just want to make sure you avoid future issues. The first thing you need to start with is a compression check. Low compression can indicate a worn cam. As someone else said. Pull the plugs and make sure they arent black or wet. Also make sure the carb isnt just dumping fuel. Edelbrocks are extremely sensitive to fuel pressure. Anything over 5.5psi will cause them to run rich/flood.
Old 04-17-2011, 09:48 PM   #14
Foosified
Foosified's Avatar
I'll have to check on the type of oil. I believe it's a mobile 1 product? Compression cold is between 155 -165psi so I believe I'm good there. Fuel pressure gauge tells me I'm 5psi when running. I have to double check the plugs.
Old 04-17-2011, 10:05 PM   #15
Sickty6
Double check your firing order. But sounds like you are losing a couple cam lobes.
Sickty6 is offline   Reply With Quote
Old 04-17-2011, 10:24 PM   #16
Foosified
Foosified's Avatar
Firing order is correct. Just double checked.
Old 04-17-2011, 10:25 PM   #17
Foosified
Foosified's Avatar
Oil doesn't have any zinc additive. Not sure why I thought it did?
Old 04-17-2011, 10:32 PM   #18
cableguy0
Next step. Pull the valve covers off. Roll the engine over by hand and watch the rockers move. Look for any rockers that arent moving as far as the rest of them. Have you checked fuel pressure by any chance? Get a bottle of zinc additive in that engine asap.
Old 04-17-2011, 11:16 PM   #19
Foosified
Foosified's Avatar
I will roll it over and watch the rockers again. Last time I did it everything looked ok. Fuel pressure is 5psi at the carb.
Are you thinking what I'm thinking... Valves are sticking in the valve guides?I will add zinc before I start the engine again and after I check rockers. If the rockers are moving fine I think my issue is probably in the heads and I'm thinking the valve guides. Thoughts?
Old 04-17-2011, 11:38 PM   #20
cableguy0
very doubtful to have valves sticking on a fresh motor. Im thinking more along the lines of a cam starting to wipe out. Its really hard to sit here and guess. But to have a backfire both through the carb and out the exhaust its the most likely suspect. Just for giggles pull the distributor cap and make sure the mechanical advance is actually moving. I know you say your timing is 12 at idle but if you have a timing light capable of showing advance see what timing is at 3k rpm.
Old 04-18-2011, 09:42 AM   #21
Foosified
Foosified's Avatar
The heads I wouldn't say are fresh. They were bought used 15000km approx. on them. When I installed new springs I seem to remember some valves moved more freely than others, but I'm not engine builder, so never thought anything about it. I have a feeling they may be the problem or part of it, as that issue may have caused some detrimental wear on the cam and/or lifters/pushrods.
Old 04-21-2011, 11:18 AM   #22
Foosified
Foosified's Avatar
Turned the engine over and watched all rocker arms move. These all move the same distance visually, so I'm confident that rules out cam or lifter issues.
I'm going to run a vacuum gauge and see if there are any wierd symptoms happening when idling, and running at different RPM's.
Old 04-21-2011, 12:23 PM   #23
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
mobile1 engine oil....as in synthetic? if it is synthetic, get it out of there. also, how did you adjust the valves. kinda sounds like you may have a few valves too tight?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 04-21-2011, 04:57 PM   #24
Foosified
Foosified's Avatar
Dino oil. Valves are adjusted with engine running. Quadruple checked!
Old 04-21-2011, 05:11 PM   #25
belowme51
belowme51's Avatar
I had the same back fireing issue under acceleration from the carb and it turned out that the cam was beating up 1 lifter and eventually made a small hole in the lifter. I would check the lifters and make sure they are ok and if you find one that is bad or getting worn down than pull the cam and replace it and all of the lifters...it only takes one. As far as the motor being a flat tappet motor its crucial to break in properly and keep a zddp (zinc phosphorate) additive in your oil. No synthetics. Just my 2cents from experiance.
belowme51 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
