Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 04-22-2011, 07:54 AM   #1
63sbssbbw
UCA63
63sbssbbw's Avatar
Rust removal...the easy way
AKA How to treat that irreplacable part
In my quest to save a heater control valve from a '63(one year only and not reproduced afaik) I discovered this cool process on another forum and thought I'd share.
Things you'll need:
Battery charger 2-10 amps(older ones work best as the newer ones won't let you short it out).
Plastic tub(large enough to submerge your part)
2 electrodes,long enough to protrude out of tub(chunks of rebar work good)
A piece of wire(from part to negative electrode)
Washing soda(1 Tblsp per gallon)
Water.
This HCV was siezed solid and disassembling it wasn't really an option(its put together VERY well),I figured I had nothing to lose, my only concern was what this process would do to the copper components.
Some before and after pics:
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 04-22-2011, 07:57 AM   #2
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: Rust removal...the easy way
One more pic
This piece works like brand new
I'm too compudumb to do a link,Maybe some one could
Its from the Stovebolt forum
T
member#7816
'61 GMC in progress
Old 04-22-2011, 01:02 PM   #3
RCbowtie69
RCbowtie69's Avatar
Looking good,good job on the controls
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 04-22-2011, 11:37 PM   #4
chrismoore701
chrismoore701's Avatar
would like to see some pics of the set up
Chris
_______________________________
1979 Chevy Stepside SPORT
2009 Chevy Silverado, 30 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-23-2011, 12:44 AM   #5
Jeffs70
Jeffs70's Avatar
very interesting and would like to also see pictures of the setup.
Jeffs70 is offline   Reply With Quote
Old 04-23-2011, 01:27 AM   #6
dicer
2 questions,
1 what is washing soda?
2 how long was it hooked up to the juice, and in the tub?
1 more where do you get the washing soda?
dicer is offline   Reply With Quote
Old 04-23-2011, 01:36 AM   #7
Jeffs70
Jeffs70's Avatar
Originally Posted by dicer View Post
2 questions,
I believe Washing soda is same as baking soda?
Old 04-23-2011, 05:59 AM   #8
tazattitude
tazattitude's Avatar
Very cool. Would be nice to see a step by step "how-to" with pics!
TAZ
Custom Classic Trucks Magazine Feature Truck (February 2012 - 7 pages)
Monthly Updates 1/11 | 2/11 | 3/11 | 4/11 | 5/11 |6/11 | 7/11 | 8/11 | 9/11 | 10/11 | 11/11 Done!
tazattitude is offline   Reply With Quote
Old 04-23-2011, 07:06 AM   #9
63sbssbbw
UCA63
63sbssbbw's Avatar
Thanks guys
I will get some pics of my set up,I have it set up at work
It took about 15 hours(over night),as you can see by pic 5,it could've used a repositioning and a few more hours as this process is "line of sight" related.
One is only limited by the size of your plastic tub( I have heard of guys using kids wading pools LOL) .
Washing soda can be purchased at your grocery store,in the cleaning aisle.
Once the part is done,srub clean with water,blow dry with compressed air or hair dryer or put in oven (my part has rubber seals so too much heat was out of the question) and prime right away as flash rust will set in right away.
I doused my part wth WD 40,worked the moving parts,rinsed with contact cleaner,redouse with WD 40,drip dry and bag for future install.
This whole process is laid out in the Tech Tips section on the Stovebolt website.
If someone could do a link to it for me,I would appreciate it, thanks .
T
member#7816
'61 GMC in progress
Old 04-23-2011, 10:41 AM   #10
rendus
rendus's Avatar
how to: http://antique-engines.com/electrol.asp
previous thread: http://67-72chevytrucks.com/vboard/s...d.php?t=385635
rendus is offline   Reply With Quote
Old 04-23-2011, 10:47 AM   #11
chas350
No, it is not the the same as baking soda
Arm & Hammer makes it, so it is often confused with baking soda, but Washing Soda is what you need its used as a laundry detergent booster.
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 04-23-2011, 10:52 AM   #12
rendus
rendus's Avatar
You can make washing soda with baking soda:
Take baking soda, spread it out onto a cookie sheet and bake it in the oven at a little over 300 degrees for an hour or so it will drive away a water and CO2 molecule thus making washing soda.
Old 04-23-2011, 02:22 PM   #13
63sbssbbw
UCA63
63sbssbbw's Avatar
Thank you for the links rendus,
You're the man
T
member#7816
'61 GMC in progress
Old 04-23-2011, 11:05 PM   #14
HuggerCST
HuggerCST's Avatar
Good info.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 04-24-2011, 01:35 PM   #15
treveiger
treveiger's Avatar
saving this
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 04-24-2011, 10:30 PM   #16
primrrd
primrrd's Avatar
I saw a link where a guy made a large trough to do the same to derust an entire frame!
cool process!
here are a few links that I had saved:
http://www.spaco.org/Blacksmithing/R...cDerusting.htm
http://www.icehouse.net/overland/derusting.html
http://www.oldspower.com/vb/showthread.php?t=44075
primrrd is offline   Reply With Quote
Old 04-25-2011, 02:02 AM   #17
1964c-10
1964c-10's Avatar
another great way to remove rust is to use muratic acid. mix it as strong as you want, i usually mix it 1 to 3 with water. it can be found at farm supply stores for about $6/gal. all you have to do is mix it, drop parts in and wait until they come up clean, the stronger the mix the less time it will take. when the part is clean, remove it and rinse throughly. then dry with oven or towels to help stop flash rust.
WARNING- do not get an acid on your skin, it is nasty stuff and will burn holes in clothing and skin if not handled properly. wet any concrete you are working on to neutralize acid on contact. It will break up concrete if it is allowed to soak in.
Before and After acid
2003 Serria K1500
1998 Camaro
1964 C10 long fleetside bed, small back window, 3 on the tree
1964 C20 custom cab, long fleetside bed, big back window, 4 on the floor
Disclaimer- anything posted is only based on my personal experience, opinions, and advice given by others. There are no implied or written warranties or guarantees with anything posted on this website.
1964c-10 is offline   Reply With Quote
Old 04-25-2011, 03:40 AM   #18
Jeffs70
Jeffs70's Avatar
Great Idea. I used to handle Muratic Acid quit a few years ago and it can be nasty stuff but sure does a great job.
Old 04-25-2011, 05:58 AM   #19
Zeke
Active Member
I saw this on TV, power block I think, so tried this with a rusty steel rim a couple of months ago, sorry no pics, and it worked great. Got all the rust out of the nooks and crannies. Bought the biggest and cheapest plastic tub from wally world and used a piece of conduit I had laying around for the positive side. Best part is there's no nasty chemicals to get rid of, dumped the rusty water in an obscure part of the yard and nothing died. Do this in a well ventilated area as just like a battery it puts off hydrogen gas.
Wife likes it too because I can do all the honey-do's while de-rusting parts.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 04-26-2011, 03:41 PM   #20
99-LS1-SS
99-LS1-SS's Avatar
Is the "after" picture painted? Also, what do you pure the mixture into? A plastic bucket or what? Thanks.
99-LS1-SS is offline   Reply With Quote
Old 04-26-2011, 03:51 PM   #21
1964c-10
1964c-10's Avatar
the after picture isn't painted. it was taken right after i rinsed it off.
it's just clean 45yr old steel
i have used a 5 gallon plastic bucket to dip in which works great for small parts
now i am using a 50 gal plastic livestock water tank to dip in. it's just big enough to fit two 15" rims in side by side
2003 Serria K1500
1998 Camaro
Old 04-26-2011, 03:52 PM   #22
99-LS1-SS
99-LS1-SS's Avatar
Cool, thanks for the quick reply. I didn't know if the acid would eat through the plastic or not.
Old 04-26-2011, 03:53 PM   #23
99-LS1-SS
99-LS1-SS's Avatar
Actually, I have one more question. How many times can you use the acid? Meaning, how many consecutive parts can you dip in it without having to change it?
Old 04-26-2011, 04:14 PM   #24
1964c-10
1964c-10's Avatar
i'm not sure how many parts you can dip, it probably depends on the size. i havent dumped any acid yet that has quit working usually i get the job done before the acid needs changed
the current batch i'm using has been mixed for about 2 months and i have been dipping parts on and off over that time period. it still is working very well.
2003 Serria K1500
1998 Camaro
Old 04-26-2011, 04:32 PM   #25
99-LS1-SS
99-LS1-SS's Avatar
Thanks again. So, IF I do this in my driveway, I can wet the ground all around the bucket and the acid won't eat through the driveway? Does water neutralize it completely or dilute it?
Sorry for so many questions.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
