Exhuast header recommendations
Any guidelines or recommendations out there for installing headers on a '65 swb with a '79 c10 sbc 350? The truck is lowered with drop spindles and springs. Just not sure if any standard header for the 350 will fit without clearance issues or not.
thanks |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Exhuast header recommendations
There are several options. Which one works for you depends on just what you want or need. There are headers made specifically for the '63-'66 trucks. Those are Hedman # 69260. Then there are headers made specifically for the '67-'87 trucks ('91 for the Suburbans). There are 3 options for those. Hedman 69090 and 69092, and Hooker 2452. All of these are long tube headers. So depending on how low your truck is, they may or may not work for you. There are shorty and mid length headers that will work, but I don't keep track of those. Hopefully someone that knows about those will chime in.
![]() Join Date: Nov 2010
captainfab- do you know if the hooker 2452's will fit with a column shift manual trans?
i read that they will but i'd like to double check thanks
2003 Serria K1500 1998 Camaro 1964 C10 long fleetside bed, small back window, 3 on the tree 1964 C20 custom cab, long fleetside bed, big back window, 4 on the floor Disclaimer- anything posted is only based on my personal experience, opinions, and advice given by others. There are no implied or written warranties or guarantees with anything posted on this website. |
Has anyone had a good experience with a stainless steel header? I'm driving a lowered SWB with a mid 70's 350, manual trans & push rod clutch linkage. I need to redo my entire exhaust system so I would prefer to go stainless & not ever have to touch it again. Preferably 409 or 304 SS. 316 stainless would be great if the price was lower.
Thanks |
I am running early camaro headers with sbc and bags but I'm auto trans floor shift so couldn't say about manual clearance.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
I have Hookers on my '65 with column shift. Truck is not lowered yet though, shouldn't be an issue for me. Only dropping a couple inches when I do.
_____________________________________________ Ray All my life, I've been told I'm a "Bad Influence" |
#7 | ||
It's Better With Nitro
Registered Loser
I'm using Patriot Clippsters on my 63. It lays frame and we only had to pie cut the collecter adapters a little to get the exhaust to clear the ground. My truck has a SBC with a TH350 and a floor shifter.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. 2014 Silverado Ext cab, 5.3, daily driver. Last edited by creep; 04-28-2011 at 11:50 AM. |
Hooker makes a set of headers specifically for 64-66 with 283 V8 and 3-speed manual. I have them on my 64 C10 with 350 and manual 3-speed. They clear all clutch and shifter linkage just fine.
hedman 69640 actually jeep to chevy v8 conversion shorty headers but work perfectly with the cpp or pol tubular mounts or stock
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
60-66 Nut
I haven't used them myself, but I have seen pics of them installed, and they did work. I'll see if I can find that thread.
#12 | |
Then maybe post up the P/N of those Hooker Headers and what motor and trans you are running? If we could get this data for various headers we could build a thread with all the information. That would be great, don't ya'll think?Header Style:Long Tube, Tri-y, ShortyMotor: Thanks, John Last edited by lakeroadster; 04-29-2011 at 10:09 AM. |
#13 |
I had a 66 GMC w/a 283/3 speed column shift w/full length Flowtech headers, fit fine after slightly tweaking the clutch arm. Got Hooker 2452s on two 64's w/column shift autos(one 700r4, one TH350), fit great, both trucks are lowered but not very much(no dragging for me, too old).
#14 |
meowMEOWmeowMEOW
I have a 66 that was a 3 spd column (changed to auto, but still used the 3spd steering shaft/column)/ My tuck sat really low, so I was using some SuperComps
![]() hard to see in the pic but they tuck really nicely. ![]() I don't need them anymore, so if ur interested in a used set let me know.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#15 |
60-66 Nut
Here are a couple pics of the Hooker 2452's installed in a '64 with a 350. This member has since sold the truck, and I haven't seen him around here for some time. He said that the clutch bell crank fit without issue. I believe he had to trim a little off of the front of rod that goes from the bellcrank arm back to the fork.
#16 |
thanks!
#17 |
[=QUOTE=MikeN;4651421]Hooker makes a set of headers specifically for 64-66 with 283 V8 and 3-speed manual. I have them on my 64 C10 with 350 and manual 3-speed. They clear all clutch and shifter linkage just fine.[/QUOTE]
What Hooker Header part number is that? I have a 66' wuth a 350 and a 3 in a Tree, 3 speed that may be in the way of headers... |
#18 |
hooker block huggers
hedman tight tubes hedman block huggers |
Thread Tools | |
Display Modes | |
