Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 60-66
Closed Thread
Old 11-30-2008, 09:01 AM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
60-66 VIN Decoder
To read further discussion on this topic go here- LINK
Here are some vin number decoders:
For Chevrolet) http://www.americanclassic.com/paint.htm
For GMC) http://www.6066gmcguy.org/VinNumber.htm
jonzcustomshop is offline
Old 11-30-2008, 09:05 AM   #2
jonzcustomshop
1961 crewcab
Re: Where is my 60-66 Chevy or GMC vin number?
Here is a decoder for Canadian 60-66 chev and gmc trucks:
This did not copy and paste like I wanted.
You can also use this link: http://www.oeltd.net/doc/6066gmc/VINs/gmc-canada.htm
pics of the chev and gmc vin tags are at the bottom of this page.
1960 - 1966 Canadian Chevrolet & GMC VIN
Chevrolet Truck
(1) The first digit indicates the model year
(2) The second digit indicates the body style
(3) The third & fourth digits indicate the series
(4) The fifth & sixth digits indicate the model
(5) The seventh digit indicates whether 4, 6 or 8 cylinder
(6) The remaining numbers indicate the particular truck
(7) The last letter indicates the GVW class
GMC Truck
(3) The third digit indicates GMC Truck
(4) The fourth & fifth digits indicate the series
(5) The sixth & seventh digits indicate the model
(6) The eighth digit indicates whether 4, 6 or 8 cylinder
(7) The remaining numbers indicate the particular truck
(8) The last letter indicates the GVW class
Body Style
C - Conventional Cab
P - Step Van / Package Delivery
L - Short Cab / Low Cab Forward
K - Four Wheel Drive
G - Van (lightweight) GVW Class
A - 6,000 & less
B - 6,001 to 10,000
C - 10,001 to 14,000
D - 14,001 to 16,000
E - 16,001 to 19,500
F - 19,501 to 26,000
G - 26,001 to 33,000
H - 33,001 & over
Model / Series Data
1960 - 1961
Chevrolet GMC Body Wheelbase GVW
C1402 C91402 Flat Face Cowl 115 inches 5200 GVW
C1403 C91403 Cab & Chassis
C1404 C91404 Stepside Pickup
C1405 C91405 Panel
C1434 C91434 Fleetside Pickup
C1503 C91503 Cab & Chassis 127 inches 5000 GVW
C1504 C91504 Stepside Pickup
C1534 C91534 Fleetside Pickup
C2502 C92502 Flat Face Cowl 127 inches 7500 GVW
C2503 C92503 Cab & Chassis
C2504 C92504 Stepside Pickup
C2534 C92534 Fleetside Pickup
1962
C1405 C91405 Panel
C1503 C91503 Cab & Chassis 127 inches 5200 GVW
P1342 P91342 Forward Control Chassis 102 inches 5400 GVW
P1345 P91345 Step Van Panel
P2342 P92342 Forward Control Chassis 104 inches 10000 GVW
P2345 P92345 Step Van Panel
P2542 P92542 Forward Control Chassis 125 inches
P2545 P92545 Step Van Panel
P2642 P92642 Forward Control Chassis 137 inches
P2645 P92645 Step Van Panel
C3602 C93602 Flat Face Cowl 133 inches 10000 GVW
C3603 C93603 Cab & Chassis
C3604 C93604 Stepside Pickup
C3605 C93605 Panel
C4102 C94102 Flat Face Cowl 133 inches 14000 GVW
C4103 C94103 Cab & Chassis
C4302 C94302 Flat Face Cowl 157 inches
C4303 C94303 Cab & Chassis
1963
C1402 C91402 Flat Face Cowl 115 inches 5000 GVW
C1405 C91405 Panel
K1403 K91403 Cab & Chassis 115 inches 5600 GVW
K1404 K91404 Stepside Pickup
K1405 K91405 Panel
K1434 K91434 Fleetside Pickup
K1503 K91503 Cab & Chassis 127 inches 5600 GVW
K1504 K91504 Stepside Pickup
K1534 K91534 Fleetside Pickup
K2503 K92503 Cab & Chassis 127 inches 7600 GVW
K2504 K92504 Stepside Pickup
K2534 K92534 Fleetside Pickup
P2342 P92342 Forward Control Chassis 104 inches 8500 GVW
C3604 C93604 Stepside Pickup 7800 GVW
C3605 C93605 Panel
C3803 C93803 Cab & Chassis 157 inches 10000 GVW
1964
G1205 G91205 Panel Body 90 inches 4850 GVW
C1405 C91405 Panel
K1405 K91405 Panel
P2342 P92342 Forward Control Chassis 104 inches 7000 GVW
P2535 P92585 Forward Control Panel Body 125 inches
P2635 P92685 Forward Control Panel Body 137 inches
C3605 C93605 Panel
1965
G1205 G91275 Panel 90 inches 5000 GVW
G1206 G91276/td> Suburban (Std.)
G1226 g91286 Suburban (Custom)
C1405 C91405 Panel
C1406 C91406 Suburban (Panel Doors)
C1412 C91412 W/S Cowl
C1416 C91416 Suburban (End Gate)
K1405 K91405 Panel
K1406 K91406 Suburban (Panel Doors)
K1416 K91416 Suburban (End Gate)
P1342 P91372 Forward Control Chassis 102 inches 5400 GVW
P1345 P91375 Step Van Panel
C2512 C92512 W/S Cowl
P2342 P92372 Forward Control Chassis 104 inches 7000 GVW
P2345 P92375 Step Van Panel
P2535 P92585 Step Van Panel (Sq. Front) 125 inches
P2542 P92572 Forward Control Chassis
P2545 P92575 Step Van Panel
P2635 P92685 Step Van Panel (Sq. Front) 137 inches
P2642 P92672 Forward Control Chassis
P2645 P92675 Step Van Panel
1966
G1206 G91276 Suburban (Std.)
G1226 G91286 Suburban (Custom)
C1405 C91405 Panel
K1405 K91405 Panel
P1345 P91375 Step Van Panel (Sq. Front)
C3605 C93605 Panel
Engines Available
1960-62
235 -6 Cyl. (std.)
283 - 8 Cyl (opt.)
1963
230 - 6 Cyl (std.)
292 - 6 Cyl (opt.)
283 - 8 Cyl (opt.)
153 - 4 Cyl (P1342/P91342)
1964
153 - 4 Cyl (Std. G1205/G91205 & P1342/P91342)
194 - 6 Cyl (Opt. G1205/G91205)
230 - 6 Cyl (Std.)
292 - 6 Cyl (Opt.)
283 - 8 Cyl (Opt.)
1965
153 - 4 Cyl (Std. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1345/P91375)
230 - 6 Cyl (Opt. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1345/P91375)
230 - 6 Cyl (Std.)
292 - 6 Cyl (Opt.)
283 - 8 Cyl (Opt.)
1966
194 - 6 Cyl (Std. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1335/P91385)
230 - 6 Cyl (Opt. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1335/P91385)
250 - 6 Cyl (Std.)
292 - 6 Cyl (Opt.)
283 - 8 Cyl (Opt.)
327 - 8 Cyl (Opt.)
Option engines were not available on all models
Page last updated:
12/19/2003 00:00:00
Old 03-16-2011, 06:36 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Exclamation Re: Where is my 60-66 Chevy or GMC vin number?
This works for Chevys!
http://www.vinwiz.com/
VIN Format: 1960-1964 Chevrolet Truck
Decoding: xxxxxxxxxxxx
Digit Usage VIN Decoded
1 Year 2 1962
2 Type C Conventional (2WD)
3-4 Model 14 1/2-Ton, Standard Wheelbase
5 Body 4 Pickup
6 Plant N Norwood OH
7-12 Sequential Serial # 122375 122375
Pre-1980 VIN decoding
http://www.crankshaftcoalition.com/w...coding#General
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Closed Thread
