Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-20-2011, 01:12 AM   #1
gm71jimmy
71 Jimmy under construction
gm71jimmy's Avatar
71 jimmy build
1971 GMC Jimmy project. Thought i would start a build thread for it. Been slowly working on it for the last 2 years here and there in between other car builds. I am preping the tub now for final paint. Hoping to have it done this summer. But lets start at the begining. Here is what it looks like when i got it home. What a mess! ha ha
More to come.
71 cheyenne 20 lwb 2x4 (daily driver)
72 Jimmy 4x4 drivable project
72 GMC truck 3/4 4x4 lwb (parted for jimmy)
63 Nova ss project
gm71jimmy is offline   Reply With Quote
Old 05-20-2011, 02:36 AM   #2
TruAggression
TruAggression's Avatar
Re: 71 jimmy build
Nice keep the pics and updates coming man!!!!
TruAggression is offline   Reply With Quote
Old 05-20-2011, 01:22 PM   #3
jaros44sr
jaros44sr's Avatar
Re: 71 jimmy build
OK, ya got my interest! Now we need more pics, and plans. Nice start...
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
Jim
jaros44sr is offline   Reply With Quote
Old 05-20-2011, 04:13 PM   #4
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Tear down of the body. Ended up selling everything i was not going to use to buy new parts with. Lots of rust in this thing. The dash was all cut up 100 holes drilled in the floors. Rust and more rust. Rocker boxes look solid. Might be the only piece saveable from the floor.
Found a wreaked truck for doner parts. Going to add factory air to the Jimmy.
63 Nova ss project
Old 05-20-2011, 04:21 PM   #5
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Over the first year of working on it the pains changed several times. from just putting it together enough to drive and use. To fixing the floors and using it as a camp rig. But after getting into it as normal were do you stop.
The end plan is a full show/daily use rig that can go anywere and trun heads.
Primer is dry so more on it later.
New floor pieces that came in for it.
63 Nova ss project
Old 05-20-2011, 05:33 PM   #6
BOHICA
BOHICA's Avatar
Re: 71 jimmy build
Not to be nosey, but if you don't mind my asking, what was the total cost of your floor pieces? I'm going to have to do a total floor replacement on one or two.
BOHICA is offline   Reply With Quote
Old 05-25-2011, 12:16 AM   #7
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
It was $242.00 plus shipping for all the floor metal. I got it from the truck shop.
63 Nova ss project
Old 05-25-2011, 12:34 AM   #8
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
The game plan when completed.
All Original body CST custom. Original 510 Blue color inside and out. Blue interior.
Factory A/C, Tilt steering, Tach dash w/vacumn.
350 custom built engine
700R4 trans 205 T-Case
Custom 37 gallon gas tank
3/4 ton axles Dana 44 frt 14 bolt rear
4:11 gears detrot lockers
Front and rear reciever hitches
33x12.5 BG mud tires on stock 16.5x8 steel wheels
4" all spring lift
Solid rear floor section from parts truck and my factory tilt column i will be using.
63 Nova ss project
Old 05-25-2011, 12:50 AM   #9
BOHICA
BOHICA's Avatar
Re: 71 jimmy build
Not bad. Thanks!
Old 05-25-2011, 12:58 PM   #10
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Made some braces to support the cowl and front section for floor repair. These doors are junk but were used for fitment and will be repaced with a pair of nice cut down truck doors.
Starting to cut out the floor and rust.
63 Nova ss project
Old 05-25-2011, 01:05 PM   #11
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
More front floor work. The rear bed floor and cross bar are rotted
63 Nova ss project
Old 05-25-2011, 01:11 PM   #12
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Found a single wall top for it. It is fair shape has some cracks and will need some repair. But it was the best i could find local. The hatch was shot. But found a nice clean rear hatch with all the hardware for $200.00 nice score.
63 Nova ss project
Old 06-08-2011, 01:27 AM   #13
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Old floor all removed and a little sand blasting to clean up the rust and dirt. The rocker boxes are soild. Some one cut a hole in each one. Will patch them. The B-pillers are rotted. Will fab up some in B-pillers.
63 Nova ss project
Old 06-08-2011, 01:30 AM   #14
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
A lot of fitting cutting and more fitting of the metal.
63 Nova ss project
Old 06-08-2011, 01:36 AM   #15
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Got the front floor braces,kick panel,A-piller and B-piller, and inner rockers all welded in and finished up. Then removed the cut up dash.
63 Nova ss project
Old 06-08-2011, 01:42 AM   #16
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Sand blasted the front cowl windshield section and sprayed it with a cheap epoxy primer so it would not rust for now. And preped the nice A/C dash from my parts truck.
63 Nova ss project
Old 06-08-2011, 06:18 AM   #17
1949gmc
1949gmc's Avatar
Re: 71 jimmy build
Great work! Looking good. Cant wait to see more.
1949 GMC 100
1963 Ford Galaxie 500XL convertible
1963 Ford Country Sedan, original 390 car
1995 GMC 1500 SLE
1998 Chevy Camaro SS Vert- SLP# 0004
1999 Chevy Camaro Z28 6spd Hardtop
2004 Chevy 2500HD CC DMAX LT
2008 Chevy Suburban LTZ
2008 Chevy Trailblazer SS, blue one
2008 Chevy Trailblazer SS, black one
1949gmc is offline   Reply With Quote
Old 06-08-2011, 03:38 PM   #18
jaros44sr
jaros44sr's Avatar
Re: 71 jimmy build
well done...we should refer to your bracing as the benchmark for future builds. Seems to be placed in the right spots, and still allows access for working on the A, B, and rocker boxes, as well as the floor sections! Keeping the forward seat brace is also another good choice...
I nominate you as are new resident sheet metal guru
good luck with your progress, and keep the pics coming
good place to get some inspiration here
thank you for taking the time to post up
SAFETY FIRST
Jim
Old 06-28-2011, 10:46 AM   #19
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Thank you for the comments jaros44sr.
Have not had much time to work on the jimmy the last month. Did get the A/C cut out in the firewall done and the dash part way installed.
All my time has been spent working on a 52 Hudson Hornet lately. This thing is almost done. Then i can get back on the jimmy. Here is a few pictures of the Hornet when i got it and some going together.
63 Nova ss project
Old 06-28-2011, 10:57 AM   #20
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
52 Hornet
63 Nova ss project
Old 06-29-2011, 03:15 PM   #21
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Got some more done on the Jimmy. por-15 the inner rocker boxes and fitted the new used truck doors to make sure everything lined up before welding the floor pans in.
63 Nova ss project
Old 06-29-2011, 03:23 PM   #22
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Use a rear long bed lower section to patch the mangaled sheetmetal on the tail light area. Got it all welded now just need to do some grinding.
The repo tail gate has terrible lines and does not match the bed sides. Would be ok if it was just a nice driver. But this one is a full show rig so will be using a original gate.
63 Nova ss project
Old 06-29-2011, 08:09 PM   #23
1956cameo
1956cameo's Avatar
Re: 71 jimmy build
Great looking work!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 06-30-2011, 12:25 PM   #24
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Bought new rocker box Rear Reinforcement Panels from GMC puals. Then finished making new lower B-pillers. Fitted new lower bed patches. Which have a different line then the originals. So more metal work and forming to get them the right shape.
I had some nice 67 original fenders. So was going to use them and shave the markers but after fitting the front end i found a nice 68 GMC front end on crigslist. With near perfect fenders.
Also fitted the top just to make sure everthing was square.
63 Nova ss project
Old 06-30-2011, 12:34 PM   #25
gm71jimmy
gm71jimmy's Avatar
Re: 71 jimmy build
Working on the floor.
63 Nova ss project
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
