Old 06-04-2011, 09:26 PM   #1
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Exclamation The 1960 - 1966 Chevrolet & GMC Pickups Engine and Tranny Swap Thread
The 1960 - 1966 Chevrolet & GMC Pickups Engine & Tranny Swap Thread.
Alright fellas.....
I thought about starting this thread for all the resources on doing engine/tranny swaps. This could be I6 to V8, Different cubic inch V8 swaps, Big Block Swaps, BBV6 Swaps, and Auto/Manual Tranny Swaps. ChiefRocka, scotts62, Alan's Classic this maybe needs to go to the engine and drive train side of the forum so yaw fellas can make that decision. Guys, add all your resources, info, what you did or need to do or done to your truck. What's needed for the swap. Etc...
Year: 1960, 61, 62, 63, 64, 65, and 66.
Post links to previous threads on the subject as well.
This will be a source for all the new and veterans can have one place to go for info on the topic. Have at it fellas!
Hope this helps and is a good idea!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-04-2011, 09:29 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: The 1960 - 1966 Chevrolet & GMC Pickups Engine and Tranny Swap Thread
Great idea, it would be nice to have all the required information in one place. The following thread covers a small block Chevy in the 60-62 chassis:
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
I'm looking forward to the threads that show installing a big block Chevy, 401 Buick, Chrysler Hemi, Oldsmobile, Pontiac, and other interesting engines.
Old 06-05-2011, 02:02 PM   #3
1Bad62Pro/Street
Talking Re: The 1960 - 1966 Chevrolet & GMC Pickups Engine and Tranny Swap Thread
Examples:
Old 09-07-2011, 09:23 PM   #4
1Bad62Pro/Street
Arrow Re: The 1960 - 1966 Chevrolet & GMC Pickups Engine and Tranny Swap Thread
Bump for the new kids on the block!
Please add all the info you guys have to help others out on a retrofitting ( How To & What To Do) on your Engine & Tranny Swaps.
Old 11-20-2011, 07:35 PM   #5
mcfarlnd
Im doing a LS style 5.3 and NV3500 5 spd. in my 61. Still gathering parts to test fit and mock it up but, here is a good link to help guys make the stand alone wiring harness..
http://www.lt1swap.com/wiringharness.htm
Ill try and update when i get more done and find more info.
mcfarlnd is offline   Reply With Quote
Old 06-27-2012, 10:09 PM   #6
1Bad62Pro/Street
To The Top for the new kids on the block.
Old 06-27-2012, 10:35 PM   #7
100%Chevy
Here's the most common 63/66 engine stands-
Left are the I-6(Not 292)
Center are the V-8
Right are the GMC V-6
Uploaded with ImageShack.us
Mike./
100%Chevy is offline   Reply With Quote
Old 06-28-2012, 05:24 AM   #8
Torqueforce
Center are the V-8
Mike./
I'm swapping the I6 to a 327, the engine has C-shaped mounts on the block already, are the center mounts pictured the only other mounts I need and where can I find them?
Torqueforce is offline   Reply With Quote
Old 06-29-2012, 12:26 PM   #9
100%Chevy
I'm not sure what you mean by "C" mounts,unless it's the later "Clamshell"style.If so,they won't work with the stands pictured.
The rubber mounts on your I-6 are the same as needed for a V-8.
But,you should get the new style interlocking type if yours are original.There was a big stink about these seperating back in the late 60's and GM was forced to make a recall and that's when the stop straps(or torque straps) were installed(free by GM dealers) to prevent the engine from lifting due to the mount seperating.
The ones in the following picture are the new design with the interlocking steel to prevent engine lift when it fails.Carefully compare to your old mounts and replace if yours are the bad ones!Note the dent in the top of the new design mount.
You can find the engine stands by watching the for sale ads here.
Mike.
Old 11-28-2012, 08:51 AM   #10
1Bad62Pro/Street
Exclamation Re: The 1960 - 1966 Chevrolet & GMC Pickups Engine and Tranny Swap Thread
Ohhhh... no activity.
Hmmmmm.
Lets bump it.
There.
Ha ha..
Wait.. Ouch..
Awkward..
Play it cool.
Morning..
Old 11-28-2012, 02:31 PM   #11
steveb64
steveb64's Avatar
I have completed the rebuild of my 500 Cadillac engine and plan on dropping it into my 64 stepside this winter, after the holidays. The truck currently has the 230 6 cylinder. This will be my first swap. I've been reading, talking, and gathering as much info as possible as I plan on doing this swap right.
steveb64 is offline   Reply With Quote
Old 12-01-2012, 06:53 PM   #12
steveb64
steveb64's Avatar
Few more pics. Engine is ready to go in.
Old 12-02-2012, 12:00 PM   #13
CdM
CdM's Avatar
very nice!!
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline   Reply With Quote
Old 12-02-2012, 12:39 PM   #14
bbadfred
bbadfred
bbadfred's Avatar
Headed out tue to check out a 02 chevy truck 5.3/4L60 junk yard pull out for my 66 Suburban. It has "only' 100k miles and is supposed to be super clean. I get every thing to do with the engine and trans, wiring harness, fuse box, pcm, air cleaner and tubes, maf, fuel system ect, throttle cables and pedal, trans cable and neutral safety switch.
bbadfred is offline   Reply With Quote
Old 12-04-2012, 03:14 PM   #15
steveb64
steveb64's Avatar
Thanks CdM. I am having a blast with this truck o' mine.
Old 12-04-2012, 03:58 PM   #16
1963c-10
1963c-10's Avatar
Cant wait to see the Caddy engine installed. What kinda hp/torque are you expecting out of it?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-04-2012, 04:02 PM   #17
jimmydean
jimmydean's Avatar
I "hope" to pull the LT1/4L60E from my Corvette and put them (rebuilt, mild upgrades) into the truck. Of course this means the Vette will need an LS3/T56 to replace it...
While I liked the idea of rebuilding the 327 to 350hp Camaro specs, the LT1 would be a lot more fun and would make room for the LS in the Vette. Win/Win.
Only plans for the LT1 are a mild cam and MSD ignition to replace the OptiSpark OE setup. Right now I am still saving my pennies for my Dropmembers.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-05-2012, 02:58 PM   #18
steveb64
steveb64's Avatar
Hoping for mid 400's hp and mid 500's torque.
Old 12-05-2012, 03:43 PM   #19
Reyals Bemus
Be prepared for massive, massive amounts of stump pulling torque.
Reyals Bemus is offline   Reply With Quote
Old 12-05-2012, 05:40 PM   #20
bbadfred
bbadfred
bbadfred's Avatar
Well checked the 5.3 out and it starts and runs fine and trans works. The antifreeze and reservoir are clean,oil and trans fluid are both clean. Its a super clean rust free 02 truck with a clean frame that appears to have been garage kept,(thats the only way they stay that nice here in Illinois) interior is very clean grey cloth seats. Its too bad it was hit in the front and totaled. I pick everything up next week. 1300 dollars for everything
Old 07-06-2013, 12:53 PM   #21
1Bad62Pro/Street
Wink Re: The 1960 - 1966 Chevrolet & GMC Pickups Engine and Tranny Swap Thread
Get The Right Transmission For Your Project
https://www.youtube.com/watch?v=r0iUcPuav60
http://www.staceydavid.com/
https://www.youtube.com/user/StaceyDavidsGearZ/videos
Old 12-14-2013, 06:57 PM   #22
1Bad62Pro/Street
Bump .. ;-)
Old 06-29-2014, 09:40 PM   #23
1Bad62Pro/Street
Bump:
Old 06-30-2014, 09:11 AM   #24
mcfarlnd
1961 LS (5.3) and NV3500 swap. I used speedway universal motor mounts. I probably went a difficult route but, I wanted the oil pan to be above and behind the crossmember with a truck oil pan and have room to hide my coils behind the motor. I had to build a trans tunnel and cut the firewall. Here is the only picture I have on me at the time. This was a test fit of the motor after the firewall/ trans tunnel modification.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
