![]() Join Date: Feb 2001
Big Block on VIN plate - can you tell?
Do the GVW numbers decipher whether a SWB truck had a big block or not?
JQ
Lifetime member - Factory Stock Club!!! 72 Cheyenne Super swb. 402/400,tach,posi,AM/FM, A/C, cruise, 8-track 72 Cheyenne Super (30) Longhorn. 402/400 tilt, tach, am/fm, A/C, cruise... 72 K-5 Blazer - Highlander. 350/350 ps,pb,a/c,tilt, posi. 68 50th Anniversary swb. 66 Custom Cab swb. Factory 327/glide,ps,pb,a/c 60 GMC Custom Cab swb. V6,Overdrive, ps. |
![]() Join Date: Sep 2001
Re: Big Block on VIN plate - can you tell?
In 1972, All domestic 1/2 ton Big Block trucks were required to have both heavy front and rear springs. This requirement enables us to determine if the truck was originally equipped with heavy front and rear springs by viewing the weights on the Gross Weight/VIN plate. If the truck was originally equipped with heavy front and rear springs, The "As-Manufactured" (left-hand figures) Gross Weight for this Vehicle Must be 5400 pounds, the Maximum Front End Ground Weight must be 3100 and The Maximum Rear End Weight at Ground must be either 3220 or 3500. Remember, not all trucks with these Gross Vehicle Weights were Big-Blocks, but all Big-Blocks have these Gross Weights. AGAIN, THIS IS ONLY FOR 1972 1/2 Ton Trucks!!! See examples.
I also look for original rivets on the VIN plate, frame # matching, exhaust brackets, etc. Last edited by DANTIP; 06-22-2011 at 07:30 PM. |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Nice Tip Dan. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super Crew Cab K30 4x4 (collecting parts stage)(tilt, tach, buckets, original black shoulder belts, cruise, dealer cb, dealer 8 track, am/fm) 1987 Silverado K30 (454,sm465,np205,tach) 1996 Silverado 22" lift 49" iroks 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach):2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
So in 1972 at least, the vin will tell you if was a BB, but the vin will not tell you if it was a SWB?+
I SEE IT WONT TELL YOU IF IT WAS A BB, RATHER IF IT DOES NOT HAVE THOSE WEIGHTS IT WAS NOT A BB.
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 06-22-2011 at 09:47 PM. |
![]() Join Date: Feb 2003
Some good info here!
69 short 4x4. "lil devil" Big project! 69 cst/10 396/400 a/c tilt tach. Beater 70cst10 4x4/BB/bkts/posi/tach/auto 70swb/350 (wifes) 71cheyenne104x4/tach/posi/350/auto/plow 70 blazer 4x4 71 blazer 2x4 67 swb big window/bkts/O.D. 65 sport fury conv. 383/auto 65 chry 300 L 413/auto |
DND Trucks
![]() Join Date: Dec 1999
The SPID will have the VIN #, wheel base and the model # info. As mentioned previously by Dan, you look at all these areas to authenticate the truck.
Here is the order I look at when determining the originality of an alleged '72 SWB BB truck.
1) VIN plate/Correct Gross Weights/Original Rivets? 2) Original SPID/Matches VIN Plate? 3) Frame Partial VIN match? 4) Frame Rail Part Numbers Correct for SWB? 5) Correctly Located/attached dual-exhaust brackets? If any of these are not correct, I personally wouldn't be interested. Many other people don't sweat the originality details, but I will definitely pay significantly more for a correct/original SWB BB truck. The other unique Big-Block items can be found and installed to look 100% correct and original. I feel pretty confident I could not be fooled by "put-together" truck. |
Did all big block trucks have dual exhaust?
DND Trucks
Every "factory" big block truck I parted out or owned had dual exhaust hangers.
Still plays with trucks
I too have never seen a factory big block truck or car with single exhaust.
67 C10 Suburban 69 C10 shortbed stepside project 45 ACP http://67-72chevytrucks.com/vboard/s...13#post4899613 69 K20 lwb TBI 350 4L60E NP208 square body chassis http://67-72chevytrucks.com/vboard/s...=1#post3955165 68 Camaro SS / RS 450hp 396 T-400 http://67-72chevytrucks.com/vboard/s...d.php?t=528952 79 Malibu TPI 350 4L60 3.73 gears |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
