Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 06-26-2011, 09:20 PM   #1
BigRed76
BigRed76's Avatar
How do I remove the door hinges??
From what I've seen the door hinges are welded on?
If that is correct then I assume it involves cutting off the old hinges and then welding the new ones on?
If thats the case then how do you make sure that the new ones get welded on in the same place?
Zach
1971 Chevrolet Custom C10, 5.3/4L60E, 3.73's
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
1996 Chevrolet Cheyenne K1500, 5.0L/4L60E, ECSB
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-26-2011, 10:21 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: How do I remove the door hinges??
Follow this link. John Gilbert was the editor of Custom Classic Truck magazine and now is a contributing editor to Classic Trucks as well as editing the LMC sponsored American Trucks magazine.
He's going to do a story about how to replace the door hinges on these trucks. So, just be patient and it will be shown to the world.
http://67-72chevytrucks.com/vboard/s...d.php?t=471310
Member Nr. 2770
Old 06-27-2011, 12:35 AM   #3
benoit454
Chris
benoit454's Avatar
have to ask,
are your doors sagging? if so you can just change the pins and bushings.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 06-27-2011, 12:47 AM   #4
BigRed76
BigRed76's Avatar
The driver door does sag because the center pins dont stay in all the way anymore. The reason I say they need replaced is because on both sides on the upper hinge there is a piece broken that has to do with the door staying open in the middle and fully open. That piece is broken on both sides so neither door stays open without holding it.
And I've heard that there is supposed to be a spring in there somewhere, and none of them have a spring.
Zach
Old 06-27-2011, 04:00 AM   #5
mbgmike
Body shops replace them. The replacement hinges are bolted on. you use a fish wire attached to the bolts and feed it up on the inside. Actually GM has a tech sheet on the replacement procedure. I posted here a few years ago. The hardest part is getting the old ones off. they are a real pain to do. You will have to drill a 1/8in pilot hole and drill out the spots with 1/2in drill. We have done a number of these and I will tell you its not a fun job. Its something anyone can do however. The replacement kits come with the door side hinges and they should be done to. Just for info A Gm dealership charges around 800 to 900 to do one door. Here are some pics of a similiar kit not your year
mbgmike is offline   Reply With Quote
Old 06-27-2011, 10:46 AM   #6
BigRed76
BigRed76's Avatar
So replacing the hinges is a chop, cut, rebuild job So before you cut the old ones off do you have to mark the location of the old ones so that you bolt the new ones up in the correct spot? Or is there another method?
Zach
Old 06-27-2011, 11:02 AM   #7
benoit454
Chris
benoit454's Avatar
that bar/rod that holds the spring or the spring rides on, it's replaceable too without messing with the hinges. My DS one is gone but my PS is there. I checked online.
Chris
GIT R DONE!!!!!!
Old 06-27-2011, 06:13 PM   #8
BigRed76
BigRed76's Avatar
The part that the arrow is pointing to is what has broken, on both hinges. So I'm assuming since that part broke it allowed the spring to come out explaining its absense.
And its not just the black piece that broke, the rod that it rides on broke on the bottom. So is just that rod replaceable?
Zach
Old 07-31-2011, 02:06 PM   #9
reecetas7196
do you know where I can get pins and bushings for both doors for my 69 c20 longbed? My doors are sagging as well and have a gap at the top of them which in order for me to close them I have to slam them, but they still have a gap at the top.
reecetas7196 is offline   Reply With Quote
Old 07-31-2011, 04:32 PM   #10
lha1992
lha1992's Avatar
Your posting in the wrong forum. This is the 88-98 forum.
Post your question over in the 67-72 section.
lha1992 is offline   Reply With Quote
Old 07-31-2011, 04:40 PM   #11
reecetas7196
oh my bad....I just did a search and saw this one so I clicked on it...thanks anyway
Old 07-31-2011, 09:08 PM   #12
benoit454
Chris
benoit454's Avatar
yes that rod the roller thing is on gets changed it's all one piece deal, mines broke off I need the same. I heard you can get em at any parts store with a HELP section?
Chris
GIT R DONE!!!!!!
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
