07-13-2011, 05:22 PM | #1 |
Blazer Large Fuel Tank Install
I had seen everyone elses Blazer tank install and I to had reservations about how low it hung down so I tried something a little different with my rear crossmember so the tank could sit higher. Anyone else done anything like this........???
modified crossmember http://kieth.smugmug.com/Trucks/66-G...005088_DrSmCmf How high the tank sits above the frame: http://kieth.smugmug.com/Trucks/66-G...005429_gWBxmmr where we a locating a angle iron bracket for extra strength: http://kieth.smugmug.com/Trucks/66-G...003673_7qBM5tJ we are welding the nuts for the fuel tank to the bottom frame flange, since it is really hard to get to and will be the last thing installed. The bolts for the tank straps are also being welded in to facilitate installation. Pictures will follow. tomorrow on this part of the install. Click on each picture to see where we are installing permantenty mounted bolts and nuts for the Fuel Tank. http://kieth.smugmug.com/Trucks/66-G...477709_NK7N8DW Last edited by kieth; 07-13-2011 at 05:44 PM. |
07-13-2011, 08:55 PM | #2 |
But Found Her 25yrs Later!
Re: Blazer Large Fuel Tank Install
Thanks for sharing.
I saved some of your pics for future reference. I have a 79 suburban tank I hope to use. I also was concerned about how low it would hang. Your images I saved:
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-14-2011, 08:45 AM | #3 |
I took some more photos this am, will post them later after we get the rear crossmember installed, the bumper brackets, the fuel tank and the bed on so we can see how low it sits and how stable the bed is. I can tell you that with just the bed wood in and installed on all the crossmembers, even without the inner rear fenders installed the bed is rock solid even with the center of the original crossmember missing.
Kieth |
07-19-2011, 01:35 PM | #4 |
How's it going?
I'm getting ready to do mine. If you don't mind, I'll post my progress here so the info is consolidated for others. Thanks, Robert
