Old 07-16-2011, 06:37 AM   #1
fastwillie 696969
fastwillie 696969's Avatar
turbo 400 shifter linkage
turbo 400 ,where the shifter connects to the tranny on the side ,seams to be leaking heavy fluid from the detent arm ,is there a small seal in that case if so how do you take it out ,its about size of a nickle ,i had this tranny taken apart and had the shop add the trans brake ,they said they resealed the front pump but doesnt remember if the shifter seal was replace or not ,it has been about 6mo. since he did the job,this the first time firing up the engine since putting the tranny in .i lost a few qts of maxshift fluid .i thought it was the new lokar dipstick but its not from there .so added more tranny fluid and it pours out as fast as it goes in .
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-16-2011, 09:19 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: turbo 400 shifter linkage
Trans pan has to come off. As I remember the 400 has a o-ring on the shift-shaft AND a external seal. O-ring does the oil retention, seal is more to keep dirt out.
But that's from an old foggy memory. One thing for sure is the pan has to come off, and the linkage disassembeled from the inside to prelace the seal.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-16-2011, 10:32 AM   #3
'63GENIII's Avatar
Just did mine a couple months ago. Marv's right, pan has to come down, remove the shift shaft, I used a pick and screwdriver to pry / work the seal out. Put the new one in (mine went in rather far into the case before it seated) I don't recall mine having an o-ring but it has stopped leaking anyway. Oh important note: remember to put the detent plate back on the end of the shift shaft BEFORE you put the pan on, reconnect the linkage and fill it with fluid! If you don't it will not go into gear when you start it. Don't ask how I know this!
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install
NV4500 Reverse Build Thread
L29 - 7.4 Vortec Build
'63GENIII is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Copyright 1997-2013
