Old 07-21-2011, 03:19 PM   #1
WETOWM
70 chevy cab roof lights
Is it rare to have the lights on the roof of the cab ? Some one told me that was rare to see ??
WETOWM is offline   Reply With Quote
Old 07-21-2011, 03:23 PM   #2
bosco200
bosco200's Avatar
Re: 70 chevy cab roof lights
I also think they were more common on C30s correct me if im wrong.
bosco200 is offline   Reply With Quote
Old 07-21-2011, 03:31 PM   #3
WETOWM
The truck is a 1970 c10 4x4
Old 07-21-2011, 05:50 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
I have a 70 and 71 both with cab lights. Both 1/2 ton, both 4x4. I don't think rare is the right word.
67 gmc custom lwb dakota truck
69 swb 4x4 project
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-21-2011, 08:15 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
uncommon back in the day, considerably more uncommon today.
1/2 ton is the least common, and one ton is quite common (being it was required on anything with dual rear wheels).
Old 07-21-2011, 08:33 PM   #6
farmall
The 1 ton has raised dimples for the lights. My service manual says Subs and Panels had tear drop lights installed on flat roof panel.
I am still trying to figure out where the ICC harness that comes down the left pillar poat hooks up. ???
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd PS PB White With Blue Int 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
71 LT1 Convertible, 72 Coupe
69 CJ5 V6, 75 CJ6 V8
67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 07-21-2011, 10:57 PM   #7
Longhorn Man
all pickups with the clearance/ID lights on top had the raised pads (69 - 72)
The wire hooks to the headlight switch
Old 07-22-2011, 02:14 AM   #8
MistaGavin
MistaGavin's Avatar
My CST/10 is a 1/2 ton 2wd and it has the factory cab lights with raised roof bases. I had never seen them in Alaska before I bought my truck.
You're not old, it IS loud!
1970 CST-10 BB 400
MistaGavin is offline   Reply With Quote
Old 07-22-2011, 09:19 AM   #9
farmall
1 Tons must of had a different switch because there is no provision for the cab light harness on aftermarket headlight swtches.
Old 07-23-2011, 08:38 AM   #10
It is rare to see clearance lamps ordered on 10 & 20 series trucks. I would think the ones you see would most likely be on a truck that was spec'd and ordered by a customer.
Just hook the lamps up to a toggle switch. That's what I've done when adding them. I always added at least the three center lamps to the rear,too. Then you can do the trucker "thanks" when someone gives you the courtesy flash.
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
"Don't call me a rough cut country gentleman. I'm just a redneck"
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 07-24-2011, 09:19 PM   #11
farmall
The factory cab light harness does plug into the aftermarket headlight switch. It goes in the unused slot in the headlight switch harness. After not finding one by feeling around, I pulled the swtch and I saw the light.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
