Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 08-18-2011, 02:02 PM   #1
psuedopimp
psuedopimp's Avatar
Heavy half in '95???
i was talking to a guy who has a 95 chevy 2500. we were just bs'ing about the differences in my personal truck (84) and my '11 chevy (work truck). he said have you ever noticed a 6 lug 3/4 ton?? i said that is weird, i wonder if this was just a heavy half with a 2500 badge?... i look at the gvwr and it was only 7200. my work chevy has a GVWR of 7000. i know the new trucks typically have higher ratings, but is that a normal gvwr for a 2500 in 1995?
psuedopimp is offline   Reply With Quote
Old 08-18-2011, 02:19 PM   #2
dishow
dishow's Avatar
Re: Heavy half in '95???
Its actually a light duty 3/4 ton.ive often wondered about what the purpose of this was for.can anyone explain?
90 Chevy 454 ss
Old 08-18-2011, 02:26 PM   #3
Alderson95
Ya basicly the light 3/4ton is a half ton on roids. All gm did is take 3/4ton suspintion and a 3/4 axle and put it on a half. Now as far as i know gm put the 3/4 axle in with large 3:73 gears. They also keept the 4l60e or 700r4. I have not seen any with the 4l80e or th400 doesnt mean they didnt make it.
Alderson95 is offline   Reply With Quote
Old 08-18-2011, 04:46 PM   #4
psuedopimp
psuedopimp's Avatar
but it had 6 lug axles like a half ton
Old 08-19-2011, 08:25 AM   #5
dishow
dishow's Avatar
if it has 3/4 ton axles,why is it six lug.I hope we can get a good explanation.just seems like theres no purpose for a "heavy half" or a "light" 3/4 ton.anyone?
90 Chevy 454 ss
Old 08-19-2011, 09:13 PM   #6
bloertcher
bloertcher's Avatar
They had a semi floating 14 bolt rear,the 6 lug axles are due to the fact that all the front suspension/differential is standard half ton stuff.They had a considerably better springpack,and larger brakes.A really good package,actually,for a daily driver that sees regular towing/hauling duty.
RIP Baby Jack 2-06-07
See You On The Other Side My Little Man
bloertcher is offline   Reply With Quote
Old 08-19-2011, 10:20 PM   #7
scotts62
One day...
scotts62's Avatar
An actual 3/4 ton has a heavier frame. I have a '92 that is considered a heavy half with same frame as half ton only one more leaf in the spring, a 14 bolt rear end and stiffer front springs and 6 lug.
Scott
93 crew cab build
Project 62
Old 08-20-2011, 02:18 AM   #8
89chevsj
error 404
89chevsj's Avatar
a reason i can see is fuel mileage... but back then it wasnt as big of deal. it seems to me that it would help get the full power and torque, for towing instead of wasting it on the heavier frame. just my 2 cents
89 Chevy swb 350 "SJ" DD turned parts truck. SOLD
90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace.
06 Kia sorento wife's car
06 charger srt8 "lucifer" my toy
'12 Kia optima
89chevsj is offline   Reply With Quote
Old 08-20-2011, 08:38 AM   #9
scotts62
One day...
scotts62's Avatar
Still gets bad fuel mileage
Scott
93 crew cab build
Project 62
Old 08-20-2011, 12:11 PM   #10
Edahall
Here's a related question regarding the 14 bolt rear / 6 lug axle. Will a 15" wheel fit on this axle or are the brakes too large for that to happen?
1990 ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 08-20-2011, 08:18 PM   #11
bloertcher
bloertcher's Avatar
Yes,15" wheels still fit.As far as bad fuel mileage goes,I had a 91 light 3/4,350 5 speed 3.73 gears.It had a 3" lift,and 33x12.50s,and consistantly 17mpg,not pulling.I put 170,000 on that truck and was and still to this day the most versatile truck I ever owned.
Old 08-20-2011, 11:34 PM   #12
scotts62
One day...
scotts62's Avatar
Thats pretty good.. Everyone i know that have one get no more than 15 and thats down hill with a tail wind. I get 13 pulling or not but its been a good truck so im not complaining.
Scott
93 crew cab build
Project 62
Old 08-21-2011, 06:59 AM   #13
dishow
dishow's Avatar
did these ever come with a short box like the sqare bodies?
90 Chevy 454 ss
Old 08-21-2011, 01:51 PM   #14
bloertcher
bloertcher's Avatar
I haven't had a truck get that good since,I personally blame the ethanol content in today's fuel.
Old 08-21-2011, 01:55 PM   #15
89chevsj
error 404
89chevsj's Avatar
i never had a light duty one. but my full 3/4 got like 8 maybe 9 on a good day, going down hill, with the engine off.
'12 Kia optima
Old 08-22-2011, 12:12 PM   #16
psuedopimp
psuedopimp's Avatar
this one had a long bed, i think....i see it at least once a week maybe i will remember to remember what bed it has.
Old 08-22-2011, 01:22 PM   #17
Dalaigh
Canadian Trucker
Dalaigh's Avatar
There is an actual heavy half pick up from 88-98, If you have a 1/2 ton truck with an f44 option, it's a heavy 1/2ton. I believe it was a 1/2 ton truck with a 5 bolt sf14 (in 2wd ofcoarse, 6 if 4x4) beefier springpack (not quite 3/4tin springs), g80 was standard and 3.73 or 4.10 gears. Then GM also made two 3/4 tons with two different gvw, mostly because then they covered a wider range of options. If you needed to pull something everyday you got the heavier 3/4 ton or stepped into a 1 ton depending on the trailers weight. If it was only once and a while, then you had the option of the light 3/4 or f44, the light 3/4 had better breaks then the f44 I beleive. Ride quality and comfort was different in each truck. Remember, there was a time when GM had the best option lists out there. It is just a way of covering a broader spectum in the truck market, so people didn't have to go buy a 3/4 ton or higher truck just to pull their camper three times a year, but during the rest of the year suffer throu stiff suspension and hard fuel economy.
Steve
2017 Silverado High Country - 5.3, 8spd, crew cab short box.
1991 C2500 - Silverado Trim, 4" spindle lift, 305, 4l60, 6 Bolt (light duty) 2500
1972 Plymouth Duster - 360, 904 w/ Reverse manual valve body, 8.25 rear w/ sure grip and 3.55's, Petty Blue...
Dalaigh is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
