Old 08-22-2011, 09:27 AM   #1
HotRodYJ
HotRodYJ's Avatar
66 Tandem Stepside
I'm sure several of you have seen this build over in teh suspension section. I thought it was about time to transition it into the Build section instead now that it is well past a suspension only topic.
To catch everyone up, I'll run thru a brief summary first of where the build started and where it is today. Way back int he early 90's the mini truck guys were sticking atrailer axle under the back of there trucks. That is no longer the fad but I've never seen that done to a classic truck and I'm always looking for something a bit different than what everyone else does, so I photoshoped a picture of a nice looking 66 Chevy truck and I liked what I saw. Here is the original concept...
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 08-22-2011, 09:29 AM   #2
HotRodYJ
HotRodYJ's Avatar
Re: 66 Tandem Stepside
Here's the truck I started with after it was dissassebled. Complete rolling truck (less motor and trans) that a guy gave me just to get it out of his yard.
Old 08-22-2011, 09:33 AM   #3
HotRodYJ
HotRodYJ's Avatar
Okay so this is a budget build. Spend money where I need to, but not unless I really NEED to. So out of the box ideas not only save money, but make it that much more different as well. The truck has to be lowered, on air bags obviously, but spindles and tubular arms and dropmembers especially are way outside of my budget. Z'ing the frame just seems crude although very effective and easy. I chose to drop the frame rails 5" down into the front crossmember. Added Z28 steering rack and bolted in some RE7 bags on some off the shelf brackets I picked up second hand for $40.
Old 08-22-2011, 09:41 AM   #4
HotRodYJ
HotRodYJ's Avatar
For the backend, I stepped the frame 6" to get it down in the weeds on the cheap, then stretched the frame 32" to add the second axle. I used a pair of 9" Ford axles for simplicity in fabrication. I couldn't really see sticking a dummy trailer axle under the back for the look. Anything worth doing is worth doing right so I want the second axle to work. USA6x6 and probably others do have products that allow a drive to a second axle but this is a budget build remember. I toook a divorce mounted and bulletproof NP205 transfer case, turned it backwards to give me two drive yokes facing rearward, one for each axle. The rear most axle is offset 9" to align with the secondary output on the t-case. Also fab'd a 3 link set-up for each axle and picked up 4 cheap 2500 bags from the cheap air bag guys on the internet, whoes name I shall not mention. I've got the best RE7's in the front, I can go cheap in the rear for now and see how they do. I can always upgrade later if it becomes necessary.
Old 08-22-2011, 09:47 AM   #5
HotRodYJ
HotRodYJ's Avatar
Obviously I've been doing body work all along as well. The usual stuff, rocker panels, half the floor on both sides, cab supports, cab corners, lower coners of the doors, there isn't a panel on this truck I havn't had to make a patch for or buy a panel when necessary. The bed sides are shot and needed to be longer anyway. The rear fenders are actually really good so I went to a local sheet metal shop and had them bend me two new bedsides (9'-4" long) and two extension panels to stretch the rear fenders. I grafted the old stake pockets and end assemblies from the old bed sides into the new sheet metal and the new longer stepside bed and fenders are born.
Old 08-22-2011, 09:52 AM   #6
HotRodYJ
HotRodYJ's Avatar
For the motor, I have a 4 bolt main 350 already that only has about 10k miles on it that I had in a previous project. I changed the cam in it to an Edelbrock Performer RPM, and stuck a 3 deuce intake on it. A serpentine belt set-up and accessories from a Camaro add's a touch of modern to it and gives me all the accessories including AC for veru near free. I discarded the smog pump and fab'd some brackets and a pulley to install a York compressor instead to supply all the compressed air I will ever need for the suspension set-up. This little $30 york I picked up at a swap meet is rated at 9 scfm. I can run an impact wrech off of this thing if I want. a 7 gallon tank will be installed as well.
Old 08-22-2011, 09:54 AM   #7
HotRodYJ
HotRodYJ's Avatar
And paint. I used a single stage Acrylic Urethane from Summit Racing. So far the front half is in paint, with the bed coming very soon. It's starting to look like something now. Obviousley there are many more details for this build, up to this point, but that's the basics for now.
Old 08-22-2011, 12:46 PM   #8
jimmydean
jimmydean's Avatar
Damn I love this build. Keep up the progress.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-22-2011, 02:10 PM   #9
ejn74
ejn74's Avatar
I think it will turn out cool!
Life is short, Live each day as a new day and keep on Truckin!
ejn74 is offline   Reply With Quote
Old 08-22-2011, 03:11 PM   #10
xpickup
xpickup's Avatar
HotRodYJ, Great looking build. I is good to see something totally different. I love the blue and white paint job. Can not wait to see the whole thing in color.
Shannon
xpickup is offline   Reply With Quote
Old 08-22-2011, 07:05 PM   #11
Dinos63
chevy only
Dinos63's Avatar
Wow thats cool!!! I love the paint its sic!!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 08-22-2011, 07:42 PM   #12
blue64c20
This is an awsome project! cant wait to see it done!
blue64c20 is offline   Reply With Quote
Old 08-22-2011, 07:48 PM   #13
Slammed66
Needs a Big Block
Slammed66's Avatar
You are insane!!
Truck looks sick!! Keep it up , can't wait to see this done!!
1964 short step Dropmember, 8 inch step notch ,4 link and running a carbed 5.3/ th400 on 18's an 20's. may drive again some day.
check its rebuild here.Project: TALL GRASS
http://67-72chevytrucks.com/vboard/s...d.php?t=449019
1972 long fleet 26,000 original miler , bagged with accuair on 20" Coys
1968 Camaro SS/RS relaxing
1978 BIG 10, long 4/5 drop on rallys relaxing
1987 long fleet relaxing
1998 Reg Short Z71 Black, n chrome daily beater
2012 Sierra crew short. All black 6.2 shiny
Slammed66 is offline   Reply With Quote
Old 08-23-2011, 02:20 PM   #14
Maxxd07
Maxxd07's Avatar
Sweet build!!
Couple 80s
Couple 70s
A 68, and a 90 CTD to donate to the 70 4x4.
Maxxd07 is offline   Reply With Quote
Old 08-23-2011, 02:38 PM   #15
Joemomma1
Joemomma1's Avatar
That is nice. Usually when I see a thread with such a wild idea it usually never happens but looks like you mean business.
1965 Chevy C10 Suburban Custom.
http://67-72chevytrucks.com/vboard/s...d.php?t=353227
1966 Chevy K10 Suburban Custom
http://67-72chevytrucks.com/vboard/s...d.php?t=389857
1966 GMC C1000 Build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=340931
“Try as much as possible to be wholly alive, with all your might, and when you laugh, laugh like hell and when you get angry, get good and angry. Try to be alive. You will be dead soon enough.”
-William Saroyan
Joemomma1 is offline   Reply With Quote
Old 08-23-2011, 02:41 PM   #16
HotRodYJ
HotRodYJ's Avatar
It is a slow build but yes it will be completed. Once it's in paint, the rest is downhill.
Old 08-23-2011, 04:21 PM   #17
project 67 sub
project 67 sub's Avatar
just curious, but how do you plan to address the drive shaft issue with the rear diff, seeing as that it (the driveshaft) will run directly into the axel tube on the front diff????
project 67 sub is offline   Reply With Quote
Old 08-23-2011, 04:41 PM   #18
smbrouss70
smbrouss70's Avatar
From his other thread...
Originally Posted by HotRodYJ View Post
I've built a very short stub assembly that amounts to not much more than two yokes and a carrier bearing. This assembly will mount to the forward axle tube to keep the d-shaft nice a tight. Then one d-shaft feeding from t-case to the stub, then another d-shaft from the stub to the rearmost axle. The stub is already built and I checked for clearnace already, it does clear even at this max drop. Obvioulsey ride height will be above this and even greater clearance. Theoretically the set-up I have in mind should cancel out d-line vibes and technically should work flawlessly with no d-line vib's at any ride height. We'll see if theoretical and reality match up.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2012 Chevy Tahoe LT "Powdered Sugar"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 08-23-2011, 04:53 PM   #19
project 67 sub
ahhh ok must have missed it lol
Old 08-29-2011, 08:39 AM   #20
HotRodYJ
HotRodYJ's Avatar
New shiney grill installed. Front air bags plumbed and functional. Used the paddle valves from Boris. Works great, simple, and low cost! and the steering is now finalized and hooked up. The steering and front suspension will make it much easier to roll the truck in and out of the garage now that the fenders have paint on them.
Contemplating the hood mechanisim. Lost the hood springs due to tire clearance and these hoods are VERY heavy. Thinking seriously about using air cylinders for assist.
Old 09-01-2011, 11:42 PM   #21
s11sean11
i lowered my 62 the same way it seemed to work out well
s11sean11 is offline   Reply With Quote
Old 09-02-2011, 12:09 AM   #22
jimmydean
jimmydean's Avatar
Nate's air assist hinges for the 67's are sweet, but he said the hood was too heavy on the 60-66. Maybe something like that with more throw?
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 09-02-2011, 12:42 AM   #23
chad64chevy
chad64chevy's Avatar
hotrodyj- how did you do you tilt hood? any more pictures and advise? im wanting to do the same to mine, just havent figured out how im going to go about it! anyways nice truck and great progress!!
chad64chevy is offline   Reply With Quote
Old 09-02-2011, 04:11 AM   #24
fryer1979
Redneck Hillbilly
fryer1979's Avatar
WOW! I'm hooked.
fryer1979 is offline   Reply With Quote
Old 09-02-2011, 10:21 AM   #25
bama63
bama63's Avatar
subscribed.....nice work and ingenuity
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
