Old 09-04-2011, 09:42 PM   #1
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
1963-1966 GMC Frame Schematic
I am looking for a 63-66 GMC frame schematic.
I have found several posts on the site with 60-62 frame schematics and 63-66 suburban schematics but no 63-66 GMC frame schematic.
The GMC has a leaf rear suspension and what I am doing is swapping a 71 GMC leaf frame into my 66. I need some critical dimensions to compare the frames so if anyone has a blueprint/schematic, how about hooking a brother up??
Chris from lovely Downtown Apache Junction AZ.
Master machinist
Advanced fabricator
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 GMC Dually construction on hold
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID RA-V 2X4 fed 1200+ HP Pontiac
Soon to be the fastest Non-Chevy Powered Super truck in the South West U.S. and Maybe even the world... Buhhhwwaaahahahaha...
66-PMD-GMC is offline   Reply With Quote
Old 09-05-2011, 02:36 AM   #2
NorthstarGMC
Re: 1963-1966 GMC Frame Schematic
Here you go: http://67-72chevytrucks.com/vboard/s...92&postcount=8
Oops! That's not the right one.
I guess I could measure mine when I swap the rear end later this month.
1963 GMC Wideside powered by a LH2 32v Northstar
NorthstarGMC is offline   Reply With Quote
Old 09-05-2011, 10:59 AM   #3
kieth
kieth's Avatar
I have a 65 swb gmc bare frame on spring suspension sitting in my yard, call me with the dimensions that you need and I will check them for you. Kieth 918-446-2245
kieth is offline   Reply With Quote
Old 09-05-2011, 11:44 AM   #4
66-PMD-GMC
66-PMD-GMC's Avatar
No, your right, that is not the right one but thanks for the attempt.
In fact, the 63-66 frame schematic that 1bad62pro/street was nice enough to post in other threads is actually a generic, suburban focused, 4X4 plan with a small portion of truck related dimensions included. I do appreciate his willingness to share however but that one doesn't help either.
The dimensions I need are the location of the 2 core support brackets that the core support mounts to. With that information I can back track for the dimensions/location for the core support cross member and the nose of the frame horns. I cut the original frame horns off in the middle of the steering box/idler support bracket so I have a little bit more than a foot to work with.
Actually, I am thinking about shortening up the nose of the frame horns slightly so I can "pull in" the bumper so it sticks out less. It would have a "tighter" look IMO.
The last dimension I need is the depth from top of frame to the mounting face for the front cab mount brackets. I thought I noted that dimension but don't see it on my plans I am drawing.
My hope is to have a full set of plans by the end of this project that will show exactly how to convert a 67-72 frame to use under a 63-66 cab.
Master machinist
Advanced fabricator
Projects..
Old 09-08-2011, 12:59 AM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Do any of these help:
66 Service truck build:
Old 09-08-2011, 01:01 AM   #6
LostMy65
LostMy65's Avatar
Old 09-08-2011, 01:39 AM   #7
bo-w
awsome tech drawing , on velum(?) too . nice work
bo-w is offline   Reply With Quote
Old 09-08-2011, 08:01 PM   #8
66-PMD-GMC
66-PMD-GMC's Avatar
Actually, the first set posted are for a 4X4 suburban. The frame shape and cab mount brackets are wrong for 1/2 and 3/4 ton GMC trucks 63-66.
The second post had the right cab mount locations but it is a coil rear and no dimensions forward of the front wheel centerline.
Those are the critical dimensions, both side and top view, that I need.
I have several trucks now and 1 apart so I can get dimensions now.
I am generating a plan on auto-cad and it will include all dimensions for 1/2 and 3/4 ton GMC trucks and also short and long wheel base.
I am also generating a plan to convert a 67-72 frame to use under a 63-66 GM. Same goes for that plan, both long and short wheel base applications.
Master machinist
Advanced fabricator
Projects..
Old 09-08-2011, 08:08 PM   #9
LostMy65
LostMy65's Avatar
Let me know if there is anything I can do to help.
I use AutoCad.
Old 09-08-2011, 08:31 PM   #10
padresag
it is for a 60-62 4 x 4
ron
padresag is online now   Reply With Quote
Old 09-09-2011, 11:02 AM   #11
Budman56
Budman56's Avatar
do you have the cad file for this? can i get a copy of it.
Budman56 is offline   Reply With Quote
Old 09-09-2011, 11:15 AM   #12
LostMy65
LostMy65's Avatar
^ I wish I had the Cad file.
I found these drawings here in the forums.
The only Cad file I have is of the wiring for a 67-72. I started modding it for the 64-66 but got busy with other things.
Old 09-09-2011, 11:17 AM   #13
LostMy65
LostMy65's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=445453
Old 09-09-2011, 02:59 PM   #14
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
The frame drawings are from the 1963 Chevrolet Manual for companies who wanted to convert Chevrolet trucks from C10 on up. There's not alot of drawings in the manual for the smaller trucks compared to the larger.
Old 10-09-2017, 02:25 PM   #15
LostMy65
LostMy65's Avatar
Any progress on the CAD drawings?
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
