how to decode my engine
chevy engine code 11d140881 t1229cjd
"Where were you in '62?"
![]() Join Date: Jul 2004
The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Engine & Drivetrain
Online engine resources (casting numbers, calculators, etc.) http://67-72chevytrucks.com/vboard/s...d.php?t=382583 Small Block Chevy Engine Block Identification http://67-72chevytrucks.com/vboard/s...d.php?t=353538 Big Block Chevy Engine Block Identification http://67-72chevytrucks.com/vboard/s...d.php?t=357304 Engine I.D. and Codes - YearOne.com http://www.yearone.com/updatedsingle...ngineinfo1.asp http://www.yearone.com/updatedsingle...ngineinfo2.asp http://www.yearone.com/updatedsingle...ngineinfo3.asp http://www.yearone.com/updatedsingle...ngineinfo4.asp http://www.yearone.com/updatedsingle...ngineinfo5.asp http://www.yearone.com/updatedsingle...ngineinfo6.asp By far the fastest and easiest way to I.D. your small block Chevy is to use the casting number found on the driver’s side rear of the block on the top flange that mates with the tranny bell housing. Numbers are raised approx 1/8 of an inch. The are about 3/4 of an inch tall. Even though you may have to scrap grease and dirt away, the numbers may be seen plainly while the engine is still in the car. The casting date can also be very helpful in identification. Found normally on the top or the right side of the same flange that mates to the transmission bell housing. (Behind & below the distributor).They can also be located on the right side of the block next to a freeze plug. You will either find an alpha-numeric date code cast right into the block between the images of two screws cast into the block; these are from the screws that held the date code plate while the block was being cast. This code I.D.s the month, day, and the year of the casting; note that this does not mean that the casting date was also the model year of the vehicle that rolled out of the factory with said engine. While there were a pile of minor changes in the last 40 years to the small block Chevy, the basic design has remained the same for the years we are looking at on this site. The very first small block Chevy, a 265 CID overhead valve v-8, did not even have a provision for an oil filter! The familiar oil filter boss on the small block came around in 56, along with an all new casting. The debut of the 283 in 1957 marked the end of the 265.Chevrolet went to a new motor mounting system placing the mounts near the freeze plugs on the side of the block. The old system had mounts located on the front of the block at either side of the timing cover. Since around 1964 most small block Chevys have had two threaded holes at the rear of the block on the driver’s side near the oil filter boss. These are to accommodate the clutch counter shaft for vehicles equip with manual transmissions. Only one of the holes is required. Some vehicles used a counter shaft located approx 6" further to the rear, thus the need for the rear hole. Early blocks have only one hole and are pretty much worthless to a vehicle that requires the rear hole for their clutch assemblies. Before 63, small block Chevy engine used a "Road Draft Tube" to ventilate the crankcase. Featuring a large hole at the top rear of the block inside the lifter valley, these blocks are from the 50's through to the mid 60's.The PCV (positive crankcase ventilation system) replaced the daft tube in 1963.The vent hole disappeared in 68 when the system was redesigned to ventilate through the oil filler tube located at the front of the intake manifold. Later engine ventilated through the valve cover. In 62 Chevy brought out the Chevy II, or Chevy Deuce. Using an inverted front suspension, the Chevy II had shock towers in the engine bay, which put the steering arms right where an oil pan would go. This little problem was solved for the small block applications (4 and 6 cylinder applications had no problem with this configuration) with a special block with a recessed oil filter boss, and an oil dipstick located on the passenger side. The problem was done away with in 68 with a new chassis and body style. The unique 64-67 blocks are in demand by collectors due to the recessed oil filter boss. With the debut of the 327 in 62, Chevrolet fans were in heaven. Fitted with its own unique valve cover the featured a flat spot for a decal like "327 Turbo Fire”. This design was used until around 1965 and is very popular with collector’s today.1956-1967; small block Chevys also used a cartridge type oil filter inside a steel canister, joining other manufacturers in 68 with a spin on style oil filter. There are adapters available to update the older style blocks to the newer style. Several other changes took place to the small block Chevy in 67.It was the lst year of the 283 and the first year of the 350(Camaro only).It was also the first of three years for the very famous 302 Chevy(283 crank in a 327 block) 1968 was the year that Chevy started making the small blocks with large journal cranks, greatly improving strength and durability to the crank. This also means that small journal (pre 68) cranks do not fit large journal block (post 68) although this change did not occur until around March or April of 68. (This writer had a Mar 68 327 that was a small journal and has a may 68 327 that is a large journal.) 1968 marked the first year of the 307.The 307 utilized the stroke of a 327 and the bore of a 283.Chevy tried again with an economy small block with the 305, most are now boat anchors to the best of this writer’s knowledge. 1969 brought with it 4 bolt main bearing caps further strengthening the bottom end of the small block for high performance and heavy duty applications.69 also marked the last year on the 327 as well as the 302. Growing to its largest factory displacement of 400 cubic inches in 1970, these block required Siamese cylinders to gain the internal space for the displacement. Extra bolt holes were also drilled into the surface of each deck to promote cooling. It is also noted that for the use of a small block 400, you also need the small block 400 heads. Most of the crankshafts and connecting rods from the small block 400's ended up with a better life as part of a 383 build-up. Another year of change was 1986.The two piece rear main seal was replaced with a one piece unit. Displacement of the block was also cast into the block next to the casting number. SBC Engine Block Casting Numbers Casting CID Year Model Aplication Comments 330817 400 73-76 Passenger 2 bolt main,3 freeze plugs/side 330817 400 75-80 Truck 2 bolt main,3 freeze plugs/side 355909 305 76-79 Truck 355909 305 78-79 Pass,Camaro,Malibu,Monte Carlo,Nova 360851 262 75-76 Monza 361979 305 76-79 Truck 361979 305 76-79 Pass,Camaro,Malibu,Monte Carlo,Nova,Chevelle 366245 350 78-79 Pass,Malibu,Camaro,Nova Dipstick in oil pan 460776 305 76-79 Truck 460776 305 78-79 Pass,Malibu,Camaro,Nova,Monte Carlo 460777 305 78-79 Pass,Malibu,Camaro,Nova,Monte Carlo 460778 305 78-79 Pass,Malibu,Camaro,Nova,Monte Carlo 471511 267 79-82 Malibu,Monte Carlo 3703524 265 55 Corvette 195 HP,no oil filter 3703524 265 55 Passenger No oil Filter provision 3720991 265 56 Corvette with no oil filter 3720991 265 56-57 Truck,Pass with no oil filter 3731548 283 57 Corvette,pass,truck no side motor mounts 3737739 283 58-59 Corvette Early 1959 3737739 283 58-61 Passenger 3756519 283 58-61 Corvette 3756519 283 58-62 Passenger,Truck 3782870 327 62-65 Corvette Sm journal 3782870 327 62-65 Passenger,Chevelle,Truck Sm journal 3789817 327 62-65 Passenger,Chevelle,Truck Sm journal 3789935 283 61 Corvette Late 1961 3789935 283 62-64 Truck 3789935 283 63-64 Passenger,Chevelle 3790721 283 64-65 Chevy II Recessed oil filter boss 3791362 327 65-67 Chevy II/Nova Recessed oil filter boss sm journal 3794226 283 58-62 Truck 3794460 327 68-69 Pass,Chevelle,Camaro,Nova Large journal 3837739 283 58-62 Truck 3849852 283 58-63 Passenger 3849852 283 58-67 Truck 3849852 283 64-67 Passenger,Chevelle 3849935 283 62-67 Passenger,Chevelle 3858174 327 64-67 Passenger,Chevelle,Camaro Sm journal 3858174 327 64-67 Truck Sm journal 3858174 327 66 Corvette 300,350 HP Sm journal 3858174 350 67 Camaro 3858180 327 64-67 Pass,Chevelle,Camaro Sm journal 3858180 327 64-67 Truck Sm journal 3858180 327 65 Corvette 3862194 283 66-67 Chevy II Recessed oil filter boss 3864812 283 63-64 Pass,Chevelle,Truck 3889935 283 63 Truck 3892657 327 64-67 Pass,Chevelle Std & Hi Perf sm journal 3892657 327 64-67 Truck sm journal 3892657 327 66-67 Corvette 300,350 HP sm journal 2 bolt main 3892657 302,327 67 Camaro & z28 sm journal 2 bolt main 3896948 283 65-67 Pass,Chevelle,Truck 3903352 327 64-67 Pass,Chevelle,Camaro sm journal 3914635 307 68-73 Pass,Chevelle,Camro, Nova,Truck 3914636 307 68-73 Pass,Chevelle,Camro, Nova,Truck 3914660 327 68-69 Pass,Chevelle,Camro, Nova,Truck 3914678 302,327,350 68 Camaro,Z28 large journal,2 bolt main 3914678 327 68 Corvette 300,350 HP lrg journal 2 bolt main 3914678 327 68-69 Pass,Chevelle,Camaro, Nova,Truck 3914678 350 68-74 Pass,Chevelle,Camaro, Nova,Monte Carlo 3914678 350 69-76 Truck 3914678 350 78-79 Pass,Malibu,Camaro ,Nova 3932371 307 68-73 Pass,Chjevelle,Camaro, Nova 3932371 307 69-73 Truck 3932373 307 69-73 Pass,Chevelle,Camaro, Nova,Truck 3932386 327 68-69 Pass,Chevelle,Camro, Nova Large Journal 3932386 350 69 Corvette 300,350 HP 3932386 350 69-74 Pass,Chevelle, Camaro,Nova,Monte HI perf,4 bolt main 3932388 350 68-74 Pass,Chevelle, Camaro,Nova,Monte 2 bolt main 3932388 350 69-76 Truck 2 bolt main 3932442 350 67 Camaro 3933180 327 68-69 Pass,Chevelle,Camaro, Nova,Truck Large Jounal 3941174 307 68 Truck 3951509 400 73-76 Passenger 2 bolt main, 2 freeze plugs/side 3951509 400 75-80 Truck 2 bolt main, 2 freeze plugs/side Casting # CID Year Model Application Comments 3951511 400 70-73 Pass,Chevelle,Monte 4 bolt main, 3 freeze plugs/side 3951511 400 75-80 Truck 4 bolt main, 3 freeze plugs/side 3955618 327 68-69 Pass,Chevelle, Camaro,Nova Large Journal 3955618 302 69 Camaro,Z28 early 69,4 bolt main 3955618 350 69 Corvette 300,350 HP,4 bolt main 3955618 350 69-74 Pass,Chevelle,Camaro,Nova,Monte Carlo 3955618 350 69-76 Truck 3956632 307 69-73 Pass,Chevelle,Camaro,Nova,Truck 3970010 350 69 Corvette late 69,4 bolt main 3970010 302 69 Camaro Z/28,Late 69, 4 bolt main 3970010 350 69-79 Truck 2&4 bolt main 3970010 350 69-79 Pass,Chevelle,Camaro,Nova,Monte Carlo 2&4 bolt main 3970010 350 70 Corvette 300,350,370 HP 4 bolt main 3970010 350 71 Corvette 270,330 HP 4 bolt main 3970010 350 72 Corvette 200,255 HP 4 bolt main 3970014 350 69-77 Pass,Chevelle,Camaro, Nova,Monte Carlo 2 or 4 bolt main 3970014 350 69-79 Truck 2 or 4 bolt main 3970014 350 72 Corvette late '72,200 HP,255 HP 4 bolt main 3970020 307 68-73 Pass,Chevelle,Camro, Nova 3970020 307 69-73 Truck 3970024 307 69-73 Pass,Chevelle,Camro, Nova,Truck 3992386 327 68-69 Pass,Chevelle,Camro, Nova,Truck Large Jounal 14010201 305 80-85 Pass,Malibu,Monte, Camaro,Nova,Truck 14010202 305 80-85 Pass,Malibu,Monte, Camaro,Nova,Truck 14010203 305 80-85 Pass,Malibu,Monte, Camaro,Nova,Truck 14010205 267 80-82 Malibu,Monte Carlo 14010207 350 80-85 Pass,Malibu,Camaro 14010207 350 80-81 Truck Light Duty 14010209 350 80-81 Pass,Malibu,Camaro 14010209 350 80-85 Truck Heavy Duty 14010280 267 80-82 Malibu,Monte Carlo 14016376 267 80-82 Malibu,Monte Carlo 14016379 350 77-79 Pass,Chevelle,Camaro, Nova,Monte 14016381 305 76-85 Truck 14016381 305 78-85 Pass,Malibu, Camaro,Nova 14016383 305 80-85 Truck 14088526 350 87 Camaro 14088548 350 86-88 Truck One Piece rear main seal 14088551 305 86-88 Truck One Piece rear main seal 14088551 305 86-88 Pass,Malibu One Piece rear main seal 14093627 305 87 Pass,Malibu One Piece rear main seal 14093638 350 86-87 Truck One Piece rear main seal 14093638 350 87 Camaro One Piece rear main seal 14101148 350 87 Camaro One Piece rear main seal 14102058 305 87 Truck One Piece rear main seal 14102058 305 87 Pass,Malibu,Monte Carlo, Camaro One Piece rear main seal 14316379 350 69-85 Truck Two Piece Rear Main Seal 14316379 350 78-81 Pass,Malibu, Camaro,Nova One Piece Rear Main Seal BBC Engine Block Casting Numbers Casting # Year CID Comments 340220 1972-76 427 tall truck 345014 1974-86 454 truck 346236 1974-76 454 215, 2 bolt 359070 1974-90 454 truck 361959 1973-85 454 car & truck 364776 1968-84 427 tall truck 364779 1968-88 366 tall truck 473478 1968-84 427 tall truck 3782870 1968-76 427 tall truck 3855061 1965-67 396 3855961 1966-67 396 325, 360, 2 bolt 3855962 1965-66 396 360, 375, 425, 4 bolt 3855977 1965-67 366 tall truck 3866961 1966-69 396 Chevy, Chevy truck 3869942 1966-67 427 390, 425, 2&4 bolt 3873858 1966 396 375, 4 bolt 3902406 1967 396 325, 350, 375, 2&4 bolt 3902466 1965-67 396 ?? 3904351 1967 427 385, 390, 400, 425, 430, 435, 2&4 bolt 3904354 1966-67 366 tall truck 3916319 1968-85 366 tall truck 3916321 1968 427 385, 390, 400, 425, 430, 435, 2&4 bolt 3916323 1968 396 325, 350, 375, 2&4 bolt 3918319 1966-70 366 Chevy truck, GMC, tall truck 3925521 1968-85 366 tall truck 3928319 1969-73 366 GMC, tall truck 3935439 1968-69 427 335, 390, 400, 425, 430, 435, 2&4 bolt 3935440 1968-69 396 265, 325, 350, 375, 2&4 bolt 3937724 1968-85 366 tall truck 3937726 1968-84 427 tall truck 3955270 1969 427 335, 390, 400, 425, 430, 435, 2&4 bolt 3946052 1969 427 430 ZL-1, 4 bolt, aluminum 3955272 1969 396/402 265, 325, 350, 375, 2&4 bolt 3955274 1968-85 366 tall truck 3955276 1968-84 427 tall truck 3963512 1969-71 427 335, 390, 400, 425 COPO, 430, 435, 454 345, 360, 365, 390, 425, 450 2&4 bolt 3963513 1973-76 454 215 3965440 1968-69 396 3965449 1968-72 396 3965540 1968 396 3969854 1969-72 396/402 240, 265, 300, 325, 330, 350, 375, 454 360, 2&4 bolt 3969858 1968-84 427 tall truck 3999289 1972-78 454 215, 235, 240, 270, 2 bolt, car & truck 3999290 1972 402 240, 2 bolt 3999293 1968-85 366 tall truck 3999294 1968-84 427 tall truck 6272176 1968-76 366 Chevy, GMC, tall truck 6272177 1972 402 210 6272181 1973-76 427 tall truck 1401544 1975-87 454 truck
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread Windows Live SkyDrive Photos PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" LOOK HERE: I have Parts For Sale & Miscellaneous Stuff "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 09-09-2011 at 10:13 PM. |
Re: how to decode my engine
My casting numbers do not have the 3 in front of it all that is there is 61959 and there is no grind marks were the 3 should have been and im asumeing there would have been a 3 cuz the other numbers are on your list . can you tell me if this correct or do I have some half breed thanks
#4 | |
Original engine in truck?
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread Windows Live SkyDrive Photos PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" LOOK HERE: I have Parts For Sale & Miscellaneous Stuff "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
![]() Join Date: Nov 2009
CJD suffix codes were all `71 350 from what I`ve experienced, assuming its a V8....
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip Kids in the back seat may cause accidents, accidents in the back seat may cause kids, so no back seats no accidents..... ![]() http://67-72chevytrucks.com/gallery/...1161&protype=1 |
is a fungineer
![]() Join Date: Jan 2009
11D140881 Chevy 71 Doraville
T1229CJD Tonawonda Dec 29 '71 350 270HP 4bbl Hyd cam T350 trans L-48 engine code
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons 1978 Impala 2-door, race 350/T350 - the new race car, in progress 1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
