Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 99-06 Chevy and GMC Message Board
Old 09-18-2011, 06:11 PM   #1
biggsteve97
Hydro boost/pics/diagrams
I am adding a hydro boost setup to a truck and since I did not pull the parts from the donor truck I am not exactly sure how to run the lines. Does anyone have a picture or diagram for the hose routing or know where I can get one. I do not have access to Mitchell on Demand or All Data nor do I have a service manual and the price on one is outrageous. The hydro boost setup is from a 2000 3/4 ton 2wd with a 6.0L.
biggsteve97 is offline   Reply With Quote
Old 09-19-2011, 03:04 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Hydro boost/pics/diagrams
What truck are you putting this on?
General routing is pressure from pump to HB unit, then pressure from HB to steering gear and returns from HB unit to pump and steering gear to pump. If you are using the non-HB pump you can T the return lines.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 09-19-2011, 05:29 PM   #3
biggsteve97
im putting it on an 02 1/2 ton 4x4 also with 4 wheel disc. Thanks, It just has been better than 10 years since I last looked under the hood of a truck with hydro boost and I couldnt remember how the hoses were suppose to be run.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
