![]() Join Date: Feb 2011
6 lug to 5 lug
i got a 1970 gmc with 6 lug drum what is the cheapest way to get it 2 5 lug maybe with disc brake this rear axle i got a front end for it alrdy with disc on 5 lug
Re: 6 lug to 5 lug
71-72 spindles or order aftermarket
To Be or Not To Be....is not the question, its the reason ur still here....chuck norris lets you live.. MY BUILD....LOTS OF PICS 2003 Toyota Matrix Xr 2003 Chevy Silverado Z71 2006 Kawasaki ZZR600 2001 Ninja 250r...gone... 1968 Chevy SWB...under construction... 1968 Chevy LWB...gone... 1970 Chevy LWB...gone... 1968 Chevy SWB...gone... 1977 Chevy Cheyenne...gone...was my first Chevy 1983 Chevy Suburban 3/4 ton...gone... 2001 Chevy S-10...gone... What can I say, I love Chevy? http://67-72chevytrucks.com/vboard/s...d.php?t=379333 |
Re: 6 lug to 5 lug
Cheapest way is to swap disc brakes from a 71-87 over. You get the 5x5 pattern & it's a direct swap using junkyard parts if desired.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 90SWB Driver All Fleetsides Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive... like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar. Cubic inches is like Indiana Jones with a cheap pistol.... |
#4 | |
Re: 6 lug to 5 lug
edit: can i take the guts from a 96 impala axle and put them in this one? Last edited by 7111127; 09-30-2011 at 11:18 PM. |
Re: 6 lug to 5 lug
I ordered my axles from moser for 300 they are non tapered and 40% stronger. while I was at it I ordered mine with the 5 on 4 3/4 car bolt pattern because you can get wide wheels like drag lights for that bolt pattern. also you can find a lot of used car wheels but truck wheels not so much unless you are going with new style 20s or something. I bought a set of 11x2 rear drums for a late 60 muscle car don't remeber the model but the napa # ended in 1060. I had to enlarge the 7/16 holes to 1/2 because I also opted for 1/2 screw in racing studs. I did this because I wanted the widest tires possible on the back with out narrowing the rear. You can get car wheels 12 wide with a 7.5 bs wich will allow you to stuff a 18.5 mt under there if you want. I know this is not what you are asking but you will have more than 300 in a different rear by the time you swap it and moser will give you a part much stronger and will slip right in. Im happy I went that route. not to mention after reasearching my 68 axle is nearly as narrow as any of the car axles. and there was no welding involved. just my .02 if you go with the truck bolt pattern you can use 71-72 rear drums. they already have your measurements you just need to tell them your lug options
67 short fleet, 4/6 drop, 3in body drop , 6.0/4l80e lsx, 12 bolt,moser axles,strange mini spool, richmond 4.10 gears,w/ 345x55x15 drag radials on the back work in progress ! |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 6 lug to 5 lug
No, that won't work. You can install the complete Impala rear end under your truck. You will have to do some cutting and welding though. It has been done, and I believe it is a bit narrower than the truck 12 bolt, if that is of interest to you.
If it's just the rear disc brakes you're after, I sell the brackets to mount the Impala disc brakes on your truck 12 bolt. But you would still need the conversion axles. Those can be found at ECE, CPP, and Summit.
'75 K5 Blazer 355, T400/205, D60, 14B FF '68 RS Camaro '66 C10 Suburban, 454, T400, 3.42 posi., etc. '66 C30 cab and chassis, factory AC '66 C20 former dd '63 C10 Suburban, future 4x4 project '63 C10 swb, future pro street project '63 C60 292, 5 spd,2 spd rear,cab and chassis Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Impala SS Rear Disc Brake Brackets For Sale HERE Camaro Calipers HERE D52 Calipers HERE http://www.dragtrucks.com |
#7 | |
Re: 6 lug to 5 lug
| Bookmarks |
| Thread Tools | |
| Display Modes | |
