10-06-2011, 09:33 PM | #1 |
Hollister, CA.
'06 HD Straight Axle Conversion Build Pics...
Hey All....
Once again my long time annoying buddy, Joe, has got me wasting my time on more of his BS builds...this time once again on his weak a$$ truck (always give'n crap about it) Anyway, should'a bought a Diesel, but whatever, 6.0 it is !! When he got this truck a while ago, we lifted it using a PC kit. After that came an airlocker, which took its toll on the halfshafts..three to be exact !! Then snapped a carrier mount...then lost a wheel on the highway !!! So after a long time of slowly collecting parts...here we are !!! ORD supplies the kit, Super Duty witll spring it, and a 3/4 ton Dodge AMM axle will carry it.... Here goes nuthin..... Lets get this sucker on the lift, shall we ? - - - - Some left over carnage: - - What a joke... - - More clearance without this hanging Torsion Xmember.... - - We loosened everything up, and lowered the truck's stock suspension onto a pallet: - - - Front complete 6" Procomp list will be for sale, BTW .... complete with arms, steering, pitman arm, etc....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
10-06-2011, 09:37 PM | #2 |
6>8 Plugless........
Re: '06 HD Straight Axle Conversion Build Pics...
Good luck with it. That's a sweet truck too. Even if it does have a 6.0 in it.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-06-2011, 09:47 PM | #3 |
Hollister, CA.
Here's the Dodge Axle....Another good thing about running this axel, is the Chevy ABS sensors are same, and will plug right into the Dodge axle !! This kit is intended for an older Ford axle, which already has 36" pad centers...
Gonna have to plasma off all the stock coil and fourlink mounts.... - - - Stock mounts removed: - - - - - - (sorry for the small, dark pictures...dont feel like redoing it all....) - - - Front hooks are temporarily removed to install front hangers.... - - - If you notice, the crossmember was removed (even though the kit states that it doesn't need to be removed...DO NOT REMOVE exact words) ... I'm gonna fab up a much cleaner one later !! - - - - Rear hanger mock up ... bolt on as well, but I am gonna burn it in for extra insurance. It only bolts to the inner wall of frame: - - - - - - Stupid Duty Springs in: - - - - CoilOver/Shock mounts locate to stock upper a-arm mounts and stock shock mount... - - Slight trimming required... - - - - - More soon !!!
10-06-2011, 09:58 PM | #4 | |
Hollister, CA.
I would take that 6.0 for my '63 C-10 any day !!! But, he still should of got a DuraMax !! Although a future Cummins swap is up in the air..... Wait a minute, that would mean more of "Joe" in my shop !!!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 10-07-2011 at 10:00 AM. |
10-06-2011, 10:31 PM | #5 |
Grease Monkey
Got me hook. You wanna come help me with mine next? lol j/k I'm gathering info to prep my my 1/2 ton 2wd to SAS silverado.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
10-07-2011, 02:47 AM | #6 |
A cummins in that truck would be awesome!
10-11-2011, 09:42 AM | #7 |
Hollister, CA.
Back with a few more pics.....
- - Welded up the mounts for a little added strength: - - - -
10-11-2011, 09:56 AM | #8 |
Hollister, CA.
Axle is finally prepped and sanded:
- - - Now, the only tuff part about running this Dodge axle was getting the drivers side leaf spring pad to sit correctly. - - Pass side...no brainer: - - The springs have to be set at a 36" pad center....So this DS places the pad part way up onto the center casting....With a little patience, I made it happen !! - - First we trimmed off the pad so it sits level: - - - Then we had to slightly grind away part of the casted in bumpstop contact pad: - - - - - - Once we had the pad over far enough (it didn't take much really, only about 3/16" of material had to be removed) it was time to drill for the u bolt... - - - - - - - - - Simple notch gave clearance for u-bolt: - - - - Before we drilled, we pulled the diff cover and checked to be sure it was in fact a big chunk of casting.... - - The kit supplied us with 3" axle ubolts, and one larger one (the one used). This axle requires 3 1/2" which are coming today....
10-11-2011, 11:05 AM | #9 |
Very nice work! I'm sure that was nerve wracking drilling into the housing!
10-11-2011, 02:27 PM | #10 |
Good info sir. What length springs and rate are you using? And what shocks did you decide to use? By the perches it looks like you plan on running duels straight up. If I ever decided to purchase a new body style GM I would jump right into a SAS.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
10-11-2011, 06:14 PM | #11 |
LSX addict
subscribed. i plan on buying a duramax like this asap, and the IFS will be the FIRST thing to go!
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration] |
10-12-2011, 12:01 PM | #12 |
Very nice..OK I am next for the swap and mine is a dmax..
WTB 1972 CHEVY 3/4 4X4 1971 chevy c30 4x4 NAPCO (project) 1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers 1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete 2006 chevy LBZ crew cab duramax,4 inch,beadlocks 2015 chevy tahoe Z71 my fifth one,love em 2016 chevy 2500HD Z71 LTZ duramax midnite 2018 chevy suburban Z71 midnite |
10-12-2011, 05:14 PM | #13 |
Chevys Kick A$$
Looking badass so far. The drilling part looks scary but it looks like it turned out great. Keep up the good work and good luck with the rest of it
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
10-13-2011, 10:49 AM | #14 | |||
Hollister, CA.
- - I patch up the frame in the area where the stock crossmember was removed: - - - - - - - - - - Next I turned to welding the pads on....letting the axle cool after each pass: - - - - - - - - - Used some temporary ubolts for mock up...I jsut had to see what this sucker was gonna look like..... - - - - -
10-13-2011, 10:52 AM | #15 |
Hollister, CA.
- - - - - So far I and the owner are liking it. Acording to the kit...hanger and Super duty spring provide an equivilant to a 6" lift...but it looks more closer to 8" Next will be some paint...correct u-bolts, then move on to steering !!!!
10-13-2011, 11:04 AM | #16 |
LSX addict
looks damn good!!!
i have no idea what this cost, but this is something i'll be looking into on mine! http://spyntec.com/02-08_dodge_spyntec_overview/
10-13-2011, 01:31 PM | #17 |
So the plan is to see what you get for lift in the front then match the rear?
10-13-2011, 02:10 PM | #18 |
It looks awesome! Nice welds too btw!
10-13-2011, 04:19 PM | #19 |
Windy Corner of a Dirty Street
Now that is just darn right awesome! Just the way the General should have done it the first time. The only place IFS belongs is on ATV’s and little trucks like Toyota Tacomas.
Good work Chief! Looking forward to the final product!
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
10-13-2011, 07:28 PM | #20 |
Hollister, CA.
Thanks guys....
10-14-2011, 02:01 AM | #21 |
Second Chance Program
Damnit thats bad ass!!!
Quick question, How long are the super duty springs? Last edited by y5mgisi; 10-14-2011 at 02:12 AM. |
10-14-2011, 02:08 AM | #22 |
Hollister, CA.
10-14-2011, 02:22 AM | #23 |
These NBS Chevy/GMC look so tough with a SAS, instead of that snowplow IFS lift crap. Nice work man.
10-28-2011, 08:57 AM | #24 |
Hollister, CA.
Hey all !!
I know it's been a while, but we have slowly made some progress. Being that it my buddy and not a 'regular' customer, I work on it when I have spare time to keep the costs down. Anyway, we test fitted the axle, and quickly found that the pinion angle wasn't exactly where I wanted it, so I fabbed up a shim and welded it solid to the existing pad. Now we are perfect !! He picked up a matching diff cover....which only need slight sanding to clear the DS inner ubolt .....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 10-28-2011 at 09:10 AM. |
10-28-2011, 09:09 AM | #25 |
Hollister, CA.
Even though the ABS sensors are the same, the Dodge ones are way longer.
So rather than extend the wires, I going to swap the Dodge pigtails to the Chevy so we can utilize the longer wire without extending. Pics soon !!
Thread Tools | |
Display Modes | |
