Old 10-06-2011, 09:40 PM   #1
WarBeard
WarBeard's Avatar
What's the best oil for a old tired engine?
So I just got this 74 Custom/10 and I want to replace all the fluids and I was wondering what would be the best oil for an old and tired 350?
I don't know how many miles are on this engine and I believe it to be the original 350 2bbl I just want as much life out of it as possible.
I live In eastern Arizona and rarely see outside temps over 90 degrees in the summer and it got to 16 below last winter.
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 10-06-2011, 10:08 PM   #2
cjlinkster
cjlinkster's Avatar
Re: What's the best oil for a old tired engine?
As long as the engine isn't showing signs of excessive blow-by, I would run 10-40w. Some people like to run diesel rated oil like Rotella. I may switch to it at my next oil change. I have been using Rotella in all of my small engines over the last 4 years.
I would not run anything crazy like 20-50w.
1984 C20, 454, 4 speed named "Gold Member"
cjlinkster is offline   Reply With Quote
Old 10-06-2011, 10:15 PM   #3
WarBeard
WarBeard's Avatar
It fires right up and I don't see any smoke at all. The tailpipe is not oily.
The 10-40 is Rotella? Or is Rotella a different weight?
What does Diesel oil do for old engines?
Old 10-06-2011, 10:38 PM   #4
85Bowtie
85Bowtie's Avatar
Rotella is 15w-40. It has more zinc content which is good for flat tappet cams in older engines.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 10-06-2011, 11:18 PM   #5
lilpoindexter
lilpoindexter's Avatar
I use straight 30wt in my '78 straight six. I have no idea how many miles are on the engine. Of course it rarely gets into the high 90's here, and the coldest I've ever seen it in the winter is about 36 for the overnight low.
lilpoindexter is offline   Reply With Quote
Old 10-07-2011, 02:36 AM   #6
78 Big10 454
78 Big10 454's Avatar
I strictly use 30W in my '78.
78 Big10 454 is offline   Reply With Quote
Old 10-07-2011, 05:51 AM   #7
S10Fan
Old Heap Driver
S10Fan's Avatar
From what I've read, zinc has been removed from most all oil, including Rotella. I use regular branded oil and add ZDDP with each oil change.
_____________________________
Bryan
'97 GMC Yukon, 5.7, 4L60, 2 door, 2 wheel drive
'50 Chevy 3100, 307, TH350, S10 Chassis, air ride
'80 C-10, 454, 700R, air ride
'30 Model A Pickup, suicide front end, 350-tri-power. Some call it a "Rat Rod", I call it a Hot Rod!
S10Fan is offline   Reply With Quote
Old 10-07-2011, 06:49 AM   #8
Hazieview
Building Dreams out of Dimes!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 10-07-2011, 09:41 AM   #9
85Bowtie
85Bowtie's Avatar
No, they just have lower concentrations of zinc. Diesel oil still has higher zinc concentrations even after the use of catalytic converters on diesels.
Old 10-07-2011, 10:12 AM   #10
S10Fan
Old Heap Driver
S10Fan's Avatar
Thanks, good information.
Bryan
Old 10-07-2011, 10:22 AM   #11
Dunenutt
Newbee
Dunenutt's Avatar
10w30, or 30wt. I would'nt do anything weird, like diesel oil, or synthetic to a high mileage motor. The motor has probably collected some gunk over the years, and it's best if it just stays where it is. If you break the gunk loose, you can plug the oil pickup and destroy it.
Dunenutt is offline   Reply With Quote
Old 10-07-2011, 08:28 PM   #12
WarBeard
WarBeard's Avatar
ZDDP....Is this something I can get from Napa or Autozone?
Will 30w work in cold climates...We just got our first snow today
Old 10-07-2011, 09:17 PM   #13
S10Fan
Old Heap Driver
S10Fan's Avatar
I haven't seen it at either place. I buy mine in 4oz bottles on eBay. It's not cheap but neither are engine rebuilds.
Bryan
Old 10-07-2011, 09:37 PM   #14
kp110477
kp110477's Avatar
If you want to know WAY more than you ever thought you would know about oil, read this article. It's written really really well, as are the rest of his tech articles. It's on Pirate4x4.com, Here's the link for the whole tech articles page
kp110477 is offline   Reply With Quote
Old 10-08-2011, 02:19 AM   #15
85Bowtie
85Bowtie's Avatar
Just buy a bottle of Comp Cams 152 break-in lube from Summit or wherever you can find it. STP Oil Treatment also has "some" zinc in it as well.
However, if it's a tired worn out engine....who cares what oil you run in it? Zinc acts as a lubricant to keep your cam lobes from going flat. As far as "breaking of gunk and plugging your pick-up"....what? If the engine is at the point that your worried something might "come loose" and plug your pick-up, you're ready for a rebuild.
Just run whatever you want in it, it's not going to blow up or anything. At the worst you'll wipe a cam lobe and end up with a crappy running engine which you would have to rebuild anyway.
Old 10-08-2011, 02:41 AM   #16
WarBeard
WarBeard's Avatar
I think Im going to get some Rotella and let it ride. I just bought the truck so im not ready to rebuild the engine yet. I still need it to get me a few loads of wood for the winter.
Old 10-08-2011, 09:33 AM   #17
spudz
spudz's Avatar
Rotella USED to have zink in it and that was good for keeping things nice and happy. BUT they took most of the zink out of it a couple years ago... Its no more helpfull then some 20w50 now
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 10-08-2011, 09:54 AM   #18
ChevyC102007
ChevyC102007's Avatar
I use Castrol Hi-Mileage or Valvoline High Mileage in my wifes 01 'Ram but I think that has a roller cam in it. I used the Castrol in my '71 with no problems (still wiped a cam lobe in a 39+ year old motor. Bound to happen). Just my .02
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
1980 Chevy C-10 Big 10 350/350
2001 Dodge Ram Sport 1500 4x4. Wifes ride
http://www.cardomain.com/ride/3214337
ChevyC102007 is offline   Reply With Quote
Old 10-08-2011, 10:28 AM   #19
85Bowtie
85Bowtie's Avatar
Another one....
Rotella has MORE "zink" (zinc) than other oils. Actually, ANY diesel oil is going to have more zinc content than other conventional oils, even after they cut back on the zinc content.
The zinc concentration in Rotella is something like 1200-1400 ppm VS. ~600 ppm (or less) for non-diesel oils. So yes, it WAS higher a few years ago, but ~1200ppm is still plenty for an old engine.
Besides, what does zinc content have to do with weight of the oil???
This guy has a worn out old engine. Just run it.
Old 10-08-2011, 10:28 AM   #20
flamingbig10
6.0 powered square
flamingbig10's Avatar
My dads 350 has 270,000 it only burns and leaks a qt every 3,000, still has good oil pressure, and the intake or valve covers never been off, been putting high millage 15w40 since 200,0000
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-08-2011, 12:29 PM   #21
tucsonjwt
I would not spend anything but minimum money on good oil for an old engine. I buy name brand oil on sale by the case at the auto parts store. I currently have 2 cases of Valvoline left which were purchased for $1 per quart about 2 years ago. I use 10w40 in my 83 BB - I think that would be best for you also. I buy oil and air filters the same way and stock up. My BB takes 7 quarts.
tucsonjwt is offline   Reply With Quote
Old 10-08-2011, 01:44 PM   #22
Dunenutt
Newbee
Dunenutt's Avatar
"As far as "breaking of gunk and plugging your pick-up"....what? If the engine is at the point that your worried something might "come loose" and plug your pick-up, you're ready for a rebuild."
Sorry to offend...
Throw six quarts of Royal purple in a 100,000 mile Penzoil motor, drive it for a couple hundred miles, then get back to me.
I have not seen his motor, but have rebuilt quite a few nasty ones. I have a couple of favorites... Tranny fluid added to remove gunk, and diesel fuel added to do the same! Both engines, the pickup was plugged solid.
It was just a "worst case warning", just to be nice.
Old 10-08-2011, 04:41 PM   #23
85Bowtie
85Bowtie's Avatar
Sure...I'm going to buy $7/qt Royal Purple and put it into a 100,000 mile engine and then report back to you just to prove something I already know.... Or were you foolish enough to actually buy $40 worth of Royal Purple and put it into a worn out engine?
Throwing transmission fluid into the crankcase is a little different than trying a different oil....don't you think? Either way, anything ready to "come loose" will do so without worrying about what type of oil your running through the engine, regardless of the amount of detergent. Heat, pressure and thermal expansion have a little more persuasion in breaking things loose than your oil will.
Old 10-08-2011, 06:18 PM   #24
Dunenutt
Newbee
Dunenutt's Avatar
My original post said " Dont do anything weird", and my point was it may do more harm than good.
I digress reluctantly...
Old 10-08-2011, 08:06 PM   #25
electrician42
electrician42's Avatar
I run only 5w-30 penzoil with ac filters on my 350 ,5.3 and in the 6.0 i just purschased and never a problem
2011 silverado 2500hd ext. cab 6.0
2007 tahoe lt
2004 harley-davidson superglide
1982 chevrolet c10 stepside 2 wheeldrive..current project
electrician42 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
