Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 10-07-2011, 01:34 PM   #1
biohazardbill
Welding body panels
A friend told me I could use cleco pins to help in keeping the panels together while welding. It seems to me that would be good for lap joints, what do you use for butt joints, like a cab corner for instance?
biohazardbill is offline   Reply With Quote
Old 10-07-2011, 01:49 PM   #2
bodyman922
bodyman922's Avatar
Re: Welding body panels
Sorry but in my opinion clecko's are worthless, they don't hold the panel tight enough. I use 1/8 inch sheet metal screws, they hold tighter and cost a small fraction of the clecko's and they are reuseable like the clecko's. I would buy a panel flanger instead of butt welding for two reasons: it's a lap joint that is the same depth as a butt, and it's easier to weld.
If you are dead set on using a butt joint then buy the thinest cutting wheels you can for a die grinder. Overlap the new steel with the old and screw in place. Slowly cut along the top of the new steel and carefully unscrew a small section at a time, 2-3 inches, and peel away the overlap. Using a small screwdriver align panels and tack weld in place. Once all the tack welds are in place you can carefully come back to weld the rest being cautious not to warp the panel. Take your time and go slow it will be a better repair in the end. Also make sure to remove any old metal in the jambs so as not to have that overlaped since that should be butt welded anyway. Good luck and have fun!
bodyman922 is offline   Reply With Quote
Old 10-07-2011, 05:57 PM   #3
ebfabman
Cleco's work great for holding a panel in place when you're marking where you want to cut for a butt joint. Check out this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=421690
ebfabman is offline   Reply With Quote
Old 10-07-2011, 07:24 PM   #4
cableguy0
To get a good butt weld use strong magnets. You can also get a good set of welding vice grips. They will have large throats or a long reach etc to get into odd positions. Magnets work well though. You can also tack weld a nail to the panel so that you have a handle to hold it. Once the panel is tacked in place just cut the nail off and grind down the weld. You will have lots of griding to do anyhow one extra tack isnt going to hurt a thing.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-07-2011, 08:40 PM   #5
chris mc bride
chris mc bride's Avatar
For butt wqelds the vise grip clams work great for over lapping clekos work fine but not best as point of weld. We use sheetmetal screw and then just weld the hole up after removal.
chris mc bride is offline   Reply With Quote
Old 10-08-2011, 09:33 AM   #6
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
You can use clecos to hold panels together when doing butt welds.
http://67-72chevytrucks.com/vboard/s...utt+weld+cleco
The tighter the gap the less warpage you will introduce into the panel, the ideal gap is no gap at all. Those so-called butt weld clamps that Eastwoods sells are a complete joke IMO.
Granted vise grips work great but the good ones with enough throat and depth cost about 40 bucks a piece. Even then the longest ones I've seen are about 30 inches long...Eric
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
http://community.webshots.com/user/sevt_chevelle
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
Old 10-08-2011, 11:27 AM   #7
mbgmike
i have used just about everything to hold panels. Even homemade clamps.Clekos work fine if you want to remove and re install the panel they hold it tight enough unless they are worn out.. quicker then sheetmetal screws. i use both at times . you can get clecos that have adjustable tension so thats no big deal. clekos are for speed and saving time.
mbgmike is offline   Reply With Quote
Old 10-08-2011, 03:48 PM   #8
OJ1988
Just a car guy
OJ1988's Avatar
We use be magnets as well as sheet metal screws, depending on the application.
1971 Camaro
1993 C1500
1955 belair Blown Pro Street cruiser
OJ1988 is offline   Reply With Quote
Old 10-10-2011, 10:43 PM   #9
lofly'a
lofly'a's Avatar
these panel clamps are the best and easiest i,ve ever used. eastwood, harbor freight, and northern tool carry them by the set.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 blazer (wuza4by will finish someday after kids)
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
lofly'a is offline   Reply With Quote
Old 10-11-2011, 10:54 AM   #10
mbgmike
we make our own like that. pretty easy to make. they are handy but don't work in every situation. You really need many style clamps.
Old 10-11-2011, 11:14 AM   #11
lofly'a
lofly'a's Avatar
i agree, sometimes i use a few sheet-metal screws or magnets until i make a few tack welds. i also made some of the panel clamps after i bought some, and they are handy if you can get to the back side of the panel to install and remove them.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
