Old 11-17-2011, 11:30 PM   #26
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: drill and tap head for temp sender?
Just tap the head. The size the metric hole is vs a 1/8 NPT sensor (I think that's it?) is very little.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'16 Kia Sorento - wife's econo-driver
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-18-2011, 12:38 PM   #27
Thealien
Thealien's Avatar
The temp sensors in 67-72s are 1/2 inch NPT and is much bigger than the threaded metric hole in the LS heads
Old 11-18-2011, 04:13 PM   #28
68GMCCustom
oops....my mistake. I thought we were talking about an LS head and aftermarket sensor. my temp gauge is an autometer and not the OEM.
continue on!
Kurt -
Old 11-20-2011, 02:05 AM   #29
kSStamp0182
LSX addict
kSStamp0182's Avatar
i didnt have any trouble getting it done with the engine in the truck. (A/C stuff is out right now tho). but i just drilled it out and used a ratcheting wrench to tap it. worked great.
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration]
kSStamp0182 is offline   Reply With Quote
Old 11-20-2011, 12:55 PM   #30
SONOSADSACK
SONOSADSACK's Avatar
Originally Posted by farmtrucks View Post
will this work in the back of passenger head and show true temp on the original gauge cluster
http://www.summitracing.com/parts/VDO-323092/
Maybe I'm lazy but for use with a stock gauge, I'm not sure why you would'nt go with this. It's clean looking and easy.
SONOSADSACK is offline   Reply With Quote
Old 11-27-2011, 09:39 AM   #31
farmtrucks
farmtrucks's Avatar
did you drill and tap the head or turn down and tap sender -- I'm wanting to use my stock gauge on a 68.
farmtrucks is offline   Reply With Quote
Old 11-27-2011, 10:01 PM   #32
SONOSADSACK
I purchased 323092 and bolted it on. Have not tested or used it yet though.
Old 11-30-2011, 12:03 PM   #33
ls1nova71
ls1nova71's Avatar
I've drilled and tapped the head on 3 or 4 swaps, it isn't hard if you have the correct size drill bit for the tap, and yes, it's a BIG bit. I start with smaller bits and work my way up, putting grease on the bits and tap to catch the shavings. This is a factory '72 sensor in my current 5.3 swap.
ls1nova71 is offline   Reply With Quote
Old 11-30-2011, 05:34 PM   #34
Chevy4Life
Chevy4Life's Avatar
Nice. It didn't look like there was much room between the hole and my exhaust manifold.
I think now that my engine is in I'll just tap the block plug. I just need to find a 23/32" bit.
Chevy4Life is offline   Reply With Quote
Old 11-30-2011, 05:38 PM   #35
Chevy4Life
Chevy4Life's Avatar
You may want to contact the manufacturer and find out the Ohm range for that sender.
Old 12-01-2011, 02:31 PM   #36
conman585
conman585's Avatar
Originally Posted by CamaroChris View Post
I machined a bunch of SB temp sensors down into a 12mm/1.5 thread so that means NO adapter and NO drilling and tapping the block! Talk about doing it right. If you want one PM me for details. !IF! thats OK with the board? I just need to know which sensor you want because there are like 5 diffrent connector types.
I really like what you did here. PM sent
conman585 is offline   Reply With Quote
Old 12-01-2011, 02:58 PM   #37
farmtrucks
farmtrucks's Avatar
I did and the Ohms are way off - so it will not read right.
Old 12-03-2011, 01:04 AM   #38
Chevy4Life
Chevy4Life's Avatar
Thanks for doing the leg work.
Old 12-04-2013, 12:48 PM   #39
DarkHawk
For the old school sbc some aftermarket intakes have 1/2" npt on the intake near waterneck.
72 GMC Sierra
02 Trans Am Firehawk
91 Firebird Formula 350
06 TBSS (RIP Wife T Boned at intersection )
04 Tahoe 6" Lift
97 AWD Astro Work Vehicle/Beater
DarkHawk is offline   Reply With Quote
Old 12-04-2013, 12:56 PM   #40
DarkHawk
Many of the short waterpumps also have 1/2" npt port on top. I would think this spot would work as well. Haven't tried it so don't quote me on that one. I would think the one on the side of the wp would read the suction side of wp and wouldn't be accurate for engine temp., although it might be handy to know what the outlet temp of the radiator is.
72 GMC Sierra
04 Tahoe 6" Lift
Old 12-04-2013, 12:58 PM   #41
DarkHawk
Yea, old thread I know. Just needed this type of info and thought I would add to it.
72 GMC Sierra
04 Tahoe 6" Lift
Old 12-04-2013, 07:14 PM   #42
solidaxel
solidaxel's Avatar
I'd be willing do donate my 67 temp 1/2" npt sender for the test. the sensor end is about 13mm so, some meat would probably need to be taken off all the way down. I have no idea how much "extra" material there is or how this would effect it's operation.
I could take some basic ohm readings before and after also.
I can't believe the gauge companies haven't jumped on this. I guess the $ is in selling us gauges not senders.
I think you will find there is not enough "meat" on the small 13mm end of the sensor, BUT you will find what you always want to know what is inside !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll ZZ4 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red 327
340hp 4spd 3:36
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wifes cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-06-2013, 08:50 PM   #43
High ho silverado
High ho silverado's Avatar
Don't know if this will help for the original post which was about a 91 gauge cluster, if u get a sender from a 99 firebird it has 3 wire terminals, u can get a pigtail too, the plugs are realllllllyyyy easy to take apart, jus hook the two factory wires in the same spot then use the third for your temp gauge, no adaptors or machining required and the ohms are the same, I did that on mine and it matches the computer reasons exactly and we have measured it with a infered gauge and is right on, hope this helps. Also that sender will fit on either head.
Dan G
Lift it, fat chicks cant jump!
83 Chevy shortbed 4x4: 6.0 ls powered
97 Chevy 3/4 ton ex cab 454: work horse
00 Chevy camaro: daily driver
83 Chevy 3/4 ton: dads old rig
High ho silverado is offline   Reply With Quote
Old 12-06-2013, 08:52 PM   #44
High ho silverado
The sender has to be from a firebird, they were the only ones that had the 3 wire setup!
Dan G
Old 12-07-2013, 01:27 PM   #45
whitels1
whitels1's Avatar
I picked up an M12 x 1.5 die, and a 3/8 factory sender, put the sender probe section in my drill with a file in my vise, spun it until it was the size I needed. then hit it with the dye, worked out great. Pictures here http://carburetorssuck.com/index.php...ulletin&blog=8
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 12-07-2013, 01:29 PM   #46
MalibuSSwagon
I have the three wire sender, so you are saying it matches the ohm range of the 81-91 square body temp gauge?
MalibuSSwagon is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
