12-25-2011, 05:59 PM | #1 |
gen lll swap fuel cell?
I purchased an aluminum fuel cell for my 67-72 truck that I am installing an ls based motor. I want to run an external fuel pump and filter. My fuel cell does not have a return bung welded into it. Can i run the return through the roll over vent or do I need to weld a return bung into my tank. I have a truck style motor with a return line coming off of the rail. thanks daniel
12-25-2011, 06:27 PM | #2 |
Re: gen lll swap fuel cell?
Take the tank to a local shop to weld one in. Don't use the vent.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-26-2011, 02:08 PM | #3 |
meowMEOWmeowMEOW
The vent on my cell was a -8 AN bung, so I used the vent for the return and switched to a vented cap.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
12-26-2011, 02:34 PM | #4 | |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 12-26-2011 at 02:41 PM. Reason: first link did not work |
12-26-2011, 05:58 PM | #5 |
These are two fittings on the tank I have. Top is the feed and the brass is the rollover vent. I am thinking of changing all the fittings to AN -6. I can buy all the bungs and have them tig welded on top of the NPT threads. I am thinking of turning the feed line into the return line and tig welding a -6 AN fitting to the bottom right corner for the feed line. Do yall see a problem with this?
12-27-2011, 02:53 PM | #6 |
I would use at least a -10 AN for the supply to the pump, and -8AN for the returns (fuel volume over time consideration)...this will also help keep the fuel cooler.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
12-27-2011, 08:14 PM | #7 |
That seems big to me, this is my first ls motor. I was going to run 3/8 aluminum line for the feed and return and all -6 fittings since it is the same size. Is this to small for a stock ls 5.3 motor?
12-27-2011, 08:19 PM | #8 |
Truck and auto performance nut
my fuel feed is also 1/2" aluminum hard line and -8 stainless flex hose.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
12-27-2011, 11:22 PM | #9 |
meowMEOWmeowMEOW
I'm running 3/8 both ways without issue.
